    [Plugin] Add Layer [1.1.0]
    58 Posts 23 Posters 15.5k Views 23 Watching
    • O Offline
      otb designworks
      Yeah, TIG, you had every right to be confused as my original post was, in fact jumbling layers and scenes. I have edited it to reflect what I am seeing correctly.
      In short, no matter the settings I choose in the plugin, I get a new layer that is visible on all existing and new scenes.
      Sorry for the confusion.
      Cheers, Chuck
      OTB Designworks is on Youtube
        OK, maybe Jim needs to test/comment...
          Jim
          Are you hitting the Apply button?
          • O Offline
            otb designworks
            I am. It is creating the layer after I do, but the layer visibility is as if I set it to always visible for existing and new scenes, regardless of what I input. I went back to using your old create hidden layer plugin which has been indispensable to me for years and it works fine in SU2015
            Cheers, Chuck
            • O Offline
              otb designworks
              Well, no I wasn't actually. I just went back and realized that I created the new layer name, made my visibility chooses, and then hit done. doh.
              It is amazing how well it works when one hits apply first.
              Thanks guys, I'm sorry to waste everyone's time
              Cheers, Chuck
                Jim
                Not wasted at all - the fact that my guess was correct validates a suspicion I had that the plugin is not as intuitive as it needs to be. Thanks for reporting.
                I find the core of many plugins can be written in few lines of code. It is far more difficult to create a good user experience.
                • O Offline
                  otb designworks
                  I think it pretty slick how you have set up so one can make multiple changes without closing the dialogue. I guess I just assumed that the apply button was for changing the attributes of an existing layer and that, if I was making a new layer, that the done button would create the layer with the choices made as a default. Love the plugin, btw! Thanks for updating it.
                  Cheers, Chuck
                    sketchydog
                    This is NOT working for the primary task. Add a new layer for This Scene Only.
                    When I do this, the layer shows up in every scene. Nothing different than making a new layer narmally.
                    What is going on?
                    SU 2015/Win 7 64 bit
                      Jim
                      What is going on?
                      Make sure to press the Apply button?
                      • JClementsJ Offline
                        JClements
                        Would it be possible to have a button (or mouse-over) in the UI which would display a temporary dialog with a summary of which layers have the "Add Layer's HIDDEN attribute" assigned to them and their type of HIDDEN attribute (eg. for a specific scene only, new scenes, etc.)?
                        • O Offline
                          otb designworks
                          Hi Jim,
                          I am experiencing an odd behavior with your Plugin.
                          If I open the Plugin window everything works as expected.
                          If I close the window, however, I can never get it to come back on without completely quitting SU and starting over.
                          Also, I flip between SU and LO with command/tab shortcut on my Mac. If the Plugin window is open while I am doing this, then, when I flip from LO to SU, the curser is unable to click or change tools unless I click up in the menu bar first. If the Plugin window is not open, then everything works as expected.
                          I am using SU 15.0.9349 and LO 15.0.9349 and OS X 10.10.1
                          Cheers, Chuck
                            jwhida
                            I get the following error when I have multiple sketchup documents open (Document1, Document2).
                            The error occurs when I try to use this tool in Document 2, and have previously created a new layer '-section-PLAN-L0' using this tool in Document 1.
                            Error; #<ArgumentError; '-section-PLAN-L0' not valid values in list.>
                            /Users/me/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jf_add_layer/SKUI/listbox.rb;207;in `value='
                            /Users/me/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jf_add_layer/main.rb;37;in `main'
                            /Users/me/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jf_add_layer/main.rb;205;in `block in <module;AddLayer>'
                            SketchUp;1;in `call'
                            Using SU-2015-15.3.329 on OSX Yosemite 10.10.2
                              balaskes
                              I really whish for an option in the dialogue box to choose layer visibility states in future creations of scenes to behave as they would normaly do, meaning copying exact layer visibility states from the scene used as the creation source. As it is now the dialogue offers you to choose eiter visible or invisible layer states in future scene creations. If this is implemented I will save a lot of time an be extremely greatfull!! Thanks!!!
                              • greenskpG Offline
                                greenskp
                                When i rename a layer - 00_Equip --> 00_Equip.01 - and Add Layer[1.1.0] is open, if i closed and open it again, the ruby console show me the following error:
                                Error; #<ArgumentError; '00_Equip' not valid values in list.>
                                D;/Plugins/jf_add_layer/SKUI/listbox.rb;207;in `value='
                                D;/plugins/jf_add_layer/main.rb;37;in `main'
                                D;/Plugins/jf_add_layer/main.rb;205;in `block in <module;AddLayer>'
                                • jujuJ Offline
                                  juju
                                  have you tried 00_Equip --> 00_Equip_01 ?
                                    Jim
                                    I updated the plugin to fix this error. The version is 1.1.1.
                                    Note however the dialog needs closed and reopened to recognize a renamed layer.
                                    • greenskpG Offline
                                      greenskp
                                      Thank you Jim. Working fine now.
                                        ASistGar
                                        Thanks so much!! Running perfectly
                                          SK_Man_2020
                                          I realize that this is an oldish plugin, but it's really useful, and seems to work great in v2017.
                                          However, the layers in the pull-down list are shown in apparently random order... Is there any way of changing that, so they are in alphabetical order, just like in the actual SK "Layers" window?
                                          I often have many dozens (or even hundreds) of layers in my models, so it's a real pain to scroll through a long list, looking for the ones I want. It would be great to have the option to sort that list in alphabetical order, and even better if it could be set to either ascending or descending order.
                                            glro
                                            when i click on 'name' (title of the column) in the window that shows layers, they are put in alphabetical order...
                                            • 3 / 3
