    [Plugin] 3D Parametric Shapes - makes placeable components
    76 Posts 21 Posters 20.6k Views 21 Watching
      I assume you forgot to 'Publish' it yet again... ๐Ÿ˜’
      I did it for for.
      If you didn't want that you'll need to Un-Publish it ! ๐Ÿ˜•
        johnwmcc
        So sorry - I DID publish it at least once! But maybe not after my very last edit. Thanks again.
        J
          blajnov
          @johnwmcc said:
          Bug now fixed in v2.5.2 - I'd made a typo in parametric.rb in the Module name - sorry.
          Works for me now.
          RBZ file uploaded both to Plugin Store and to the first post in this thread.
          Dear johnwmcc, in your build tool does not work sphere ...
          I use SketchUp PRO 2015
          PS: By the way, in SketchUp PRO 8, the same Problem
            I have just tested it and the sphere-tool works correctly.
            What values are you entering into the dialog for the sphere's radius and segments ?
            What "doesn't work" ?
              blajnov
              Does not work with the default settings, as well as changing the radius and number of segments in a big way, nothing happens, ie the scope does not appear in the scene ...
              • ChisainaC Offline
                Chisaina
                Hello, I have a similar volume (sphere) will not appear on the stage
                  johnwmcc
                  I find I now get the same thing (not working) here - nothing is drawn.
                  Will investigate asap.
                    Using the default of 10mm [or anything else!] the error message is:
                    Error: #<NameError: uninitialized constant JWM::JWMShapes::Sphere::PolygonMeshHelper>
                    C:/Users/TIG/sketchUcloud/plugins/jwm_shapes/jwm_shapes.rb:984:in draw_sphere' C:/Users/TIG/sketchUcloud/plugins/jwm_shapes/jwm_shapes.rb:956:in create_entities'
                    C:/Users/TIG/sketchUcloud/plugins/jwm_shapes/parametric.rb:49:in initialize' C:/Users/TIG/sketchUcloud/plugins/jwm_shapes/jwm_shapes.rb:946:in new'
                    C:/Users/TIG/sketchUcloud/plugins/jwm_shapes/jwm_shapes.rb:946:in create' C:/Users/TIG/sketchUcloud/plugins/jwm_shapes/jwm_shapes.rb:1731:in block in module:JWMShapes'
                    SketchUp:1:in `call'
                    This is weird as it worked for me before !
                    Looks like a missing module/class ?
                    I also get the error with Dome etc...
                      mesh.extend(PolygonMeshHelper)
                      should be
                      mesh.extend(JWM::Shapes::PolygonMeshHelper)
                      three times...
                        johnwmcc
                        I wonder, TIG, if you can help me understand what's gone wrong in trying to separate the code here from that in the older SU Shapes on the Extension Warehouse.
                        The current problem is a name error: I get this error for the Dome and Sphere tools now, which both try to call mesh_additions.rb and fail. The other shapes don't need mesh_additions.rb, so still work properly.
                        Error; #<NameError; uninitialized constant JWM;;JWMShapes;;Sphere;;PolygonMeshHelper>
                        My overall code structure for the Sphere tool goes as follows (Dome has just the same structure), and I don't really understand it (just copied from SU Shapes!).
                        file jwm_shapes.rb has:
                        module JWM;;JWMShapes
                          class Sphere < Parametric
                          end # class Sphere
                        end # module JWMShapes
                        file parametric.rb has:
                          class Parametric
                          end # class Parametric
                        end #module JWM;;JWMShapes
                        file mesh_additions.rb has:
                        module JWM;;Shapes
                          class PolygonMeshHelper
                          end #class PolygonMeshHelper
                        end #module JWM;;Shapes
                        Apparently, instead of (as I expected) the Sphere class looking for
                        JWMShapes;;Shapes;;PolygonMeshHelper
                        it is looking instead for
                        What have I done wrong here, and how do I fix it? If you can help, I'll be most grateful
                        [Later] The original SU Shapes named the overall module CommunityExtensions instead of JWM, and the mesh_additions.rb code says
                        module CommunityExtensions;;Shapes
                          module PolygonMeshHelper
                          end # module PolygonMeshHelper
                        end #module CommunityExtensions;;Shapes
                        I.E., as well as the name change JWM<-->CommunityExtensions and JWM::JWMShapes<-->CommunityExtensions::Shapes, PolygonMeshHelper was a module, not a class.
                        Changing it back from class to module doesn't seem to fix the problem.
                        Looking at the above, I see that my mesh_additions.rb SHOULD say JWM::JWMShapes instead of JWM::Shapes
                        , but changing that doesn't seem to fix things either.
                        Help please, if you can! I'm temporarily stuck, and thoroughly confused.
                          johnwmcc
                          I see you posted again while I was replying. Many thanks.
                          Will make the changes asap.
                            I made the three simple changes which I suggested earlier... and it works without errors.
                            You are getting yourself into a tangle... ๐Ÿ˜•
                            Once you put a sub-module named within your all-encompassing 'JWM' module, then its name can be the same as similar names used in others' code...
                            The nesting separates them...
                            Calling them by your path JWM::... will avoid any that are poorly written by others and are 'global'...
                            So be consistent use 'JWM::Shapes', OR if you must 'JWM::JWMshapes' etc consistently...
                            Use Notepad++ with all affected files open and fine replace in all so they are internally consistent...
                            Perhaps draw out on a sheet of A4 the nested relationships of these modules/classes.
                            The full path I changed to works...
                              johnwmcc
                              Once again, TIG, thank you for cleaning up my muddle, and for explaining what's gone on.
                              I will make the changes on my original copy here too, and go back to just called the sub-modules by the same name as the SU Shapes ones - simply Shapes.
                              Have you updated the Plugin Store rbz file, or do I still need to fix the files here then upload them? And would it now be better to delete the attached file in the first post, and replace that by a link to the Plugin Store?
                              Must stop now for a while - will resume later tonight.
                                Please update your own files / RBZ in the PluginStore.
                                But please remember to click on Publish afterwards ๐Ÿ˜‰
                                I would recommend that you just have the one RBZ in the PluginStore, and add a link to its entry inside 'download' tags.
                                Put that in the very first post: when I update a plugin I usually also add it into that announcement post - a one-click direct-link means that the reader doesn't have to find it again, either in the first-post or by looking within the PluginStore itself...
                                The proper linking URL is http://sketchucation.com/pluginstore?pln=jwm_shapes
                                  johnwmcc
                                  Plugin store updated to v2.5.3, and first post in this thread now links to it.
                                  Downloaded and tested it here in SU2015.
                                    blajnov
                                    Works... Thanks!!! ๐Ÿ˜
                                    • JBJDesignsJ Offline
                                      JBJDesigns
                                      @johnwmcc said:
                                      Jo Ann - have you ever had another version of Shapes installed, whether from the SketchUcation Plugin store, or SketchUp or Trimble Extension Warehouse? There may still be a conflict, if so.
                                      Please go to your AppData/Roaming/Sketchup/SU 2014/Sketchup/Plugins folder, and delete any existing file(s) called shapes.rb or su_shapes.rb, jwm_shapes.rb or jwm_shapes_loader.rb; and delete any existing folder(s) with the name su_shapes or jwm_shapes (including all that folder's contents).
                                      Then reinstall the current version (v2.5 at time of writing) of the plugin from the Plugin Store here.
                                      If that doesn't work, I'm stumped.
                                      Best wishes, and I hope this works.
                                      John McC
                                      Hi John -- I just updated your 3D Parametric Shapes script, and after restarting SketchUp, it works!!!!! Yeah!!!!!. -- Jo Ann
                                      ...you send them to school, you give them books, and they eat the pages...
                                        JBJDesigns
                                        Hi John--
                                        I get the following error message when I open SketchUp 2014; can you fix this? Thanks! Jo Ann ๐Ÿ˜„
                                          JBJDesigns
                                          @tig said:
                                          I can't get it to do that !
                                          What's the start of the error message say ?
                                          Hi TIG,
                                          Doesn't matter... I just downloaded (updated) John's 3D Parametric Shapes script and it works!
                                          Thanks,
                                          Jo Ann
                                            johnwmcc
                                            Glad you got it going again with little trouble.
                                            • 4 / 4
