    [Plugin] 3D Parametric Shapes - makes placeable components
    76 Posts 21 Posters 26.6k Views 21 Watching
      I can't get it to do that !
      What's the start of the error message say ?
        johnwmcc
        Jo Ann - have you ever had another version of Shapes installed, whether from the SketchUcation Plugin store, or SketchUp or Trimble Extension Warehouse? There may still be a conflict, if so.
        Please go to your AppData/Roaming/Sketchup/SU 2014/Sketchup/Plugins folder, and delete any existing file(s) called shapes.rb or su_shapes.rb, jwm_shapes.rb or jwm_shapes_loader.rb; and delete any existing folder(s) with the name su_shapes or jwm_shapes (including all that folder's contents).
        Then reinstall the current version (v2.5 at time of writing) of the plugin from the Plugin Store here.
        If that doesn't work, I'm stumped.
        Best wishes, and I hope this works.
        John McC
          torbjornhirsch
          I get the following error message when loading SU 2014 after installing the plugin. Is this another instance of problems related to a non-ASCII user name? Or what else might cause this problem? Grateful for any tips!
          Error Loading File C:/Users/Torbjörn/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/jwm_shapes.rb
          Error: cannot load such file -- C:/Users/Torbjörn/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/parametric.rb
          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
          C:/Users/Torbjörn/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/jwm_shapes.rb:8:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/Torbjörn/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes_loader.rb:24:in register_extension'
          C:/Users/Torbjörn/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes_loader.rb:24:in <module:JWMShapes>' C:/Users/Torbjörn/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes_loader.rb:12:in module:JWM'
          C:/Users/Torbjörn/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes_loader.rb:11:in `<top (required)>'
            Jim
            John, in the loader file you should change the line extension.version = "2.2.8 to match the version (2.5?) you refer to in the latest release.
              johnwmcc
              Thanks for reminding me - will do later this evening.
                johnwmcc
                Version number updated to 2.51 in both jwm_shapes_loader.rb and jwm_shapes.rb files, and the Plugin Store. Makes no difference to operation, but should now show correct version internally
                • E Offline
                  Extractor
                  Hi John,
                  I can´t install the last version of the plugin (Sketchucation Plugin Store: v 2.51). The previous versions ran properly.
                  Here the “Load Errors”:
                  Error: #<NameError: uninitialized constant JWM::JWMShapes::Parametric>
                  C:/Users/Frangenberg/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jwm_shapes/jwm_shapes.rb:99:in <module:JWMShapes>' C:/Users/Frangenberg/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jwm_shapes/jwm_shapes.rb:11:in <top (required)>'
                  C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load'
                  C:/Users/Frangenberg/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jwm_shapes_loader.rb:24:in register_extension' C:/Users/Frangenberg/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jwm_shapes_loader.rb:24:in module:JWMShapes'
                  C:/Users/Frangenberg/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jwm_shapes_loader.rb:12:in <module:JWM>' C:/Users/Frangenberg/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jwm_shapes_loader.rb:11:in <top (required)>'
                    johnwmcc
                    Hmmm. I get the same error. Sorry all round. Not sure what's happened, as I though I had only changed some internal references.
                    Will investigate and update asap.
                    John McC
                      johnwmcc
                      Bug now fixed in v2.5.2 - I'd made a typo in parametric.rb in the Module name - sorry.
                      Works for me now.
                      RBZ file uploaded both to Plugin Store and to the first post in this thread.
                        I assume you forgot to 'Publish' it yet again... 😒
                        I did it for for.
                        If you didn't want that you'll need to Un-Publish it ! 😕
                          johnwmcc
                          So sorry - I DID publish it at least once! But maybe not after my very last edit. Thanks again.
                          J
                            blajnov
                            Works for me now.
                            Dear johnwmcc, in your build tool does not work sphere ...
                            I use SketchUp PRO 2015
                            PS: By the way, in SketchUp PRO 8, the same Problem
                              I have just tested it and the sphere-tool works correctly.
                              What values are you entering into the dialog for the sphere's radius and segments ?
                              What "doesn't work" ?
                                blajnov
                                Does not work with the default settings, as well as changing the radius and number of segments in a big way, nothing happens, ie the scope does not appear in the scene ...
                                • ChisainaC Offline
                                  Chisaina
                                  Hello, I have a similar volume (sphere) will not appear on the stage
                                    johnwmcc
                                    I find I now get the same thing (not working) here - nothing is drawn.
                                    Will investigate asap.
                                      Using the default of 10mm [or anything else!] the error message is:
                                      Error: #<NameError: uninitialized constant JWM::JWMShapes::Sphere::PolygonMeshHelper>
                                      C:/Users/TIG/sketchUcloud/plugins/jwm_shapes/jwm_shapes.rb:984:in draw_sphere' C:/Users/TIG/sketchUcloud/plugins/jwm_shapes/jwm_shapes.rb:956:in create_entities'
                                      C:/Users/TIG/sketchUcloud/plugins/jwm_shapes/parametric.rb:49:in initialize' C:/Users/TIG/sketchUcloud/plugins/jwm_shapes/jwm_shapes.rb:946:in new'
                                      C:/Users/TIG/sketchUcloud/plugins/jwm_shapes/jwm_shapes.rb:946:in create' C:/Users/TIG/sketchUcloud/plugins/jwm_shapes/jwm_shapes.rb:1731:in block in module:JWMShapes'
                                      SketchUp:1:in `call'
                                      This is weird as it worked for me before !
                                      Looks like a missing module/class ?
                                      I also get the error with Dome etc...
                                        mesh.extend(PolygonMeshHelper)
                                        should be
                                        mesh.extend(JWM::Shapes::PolygonMeshHelper)
                                        three times...
                                          johnwmcc
                                          I wonder, TIG, if you can help me understand what's gone wrong in trying to separate the code here from that in the older SU Shapes on the Extension Warehouse.
                                          The current problem is a name error: I get this error for the Dome and Sphere tools now, which both try to call mesh_additions.rb and fail. The other shapes don't need mesh_additions.rb, so still work properly.
                                          Error; #<NameError; uninitialized constant JWM;;JWMShapes;;Sphere;;PolygonMeshHelper>
                                          My overall code structure for the Sphere tool goes as follows (Dome has just the same structure), and I don't really understand it (just copied from SU Shapes!).
                                          file jwm_shapes.rb has:
                                          module JWM;;JWMShapes
                                            class Sphere < Parametric
                                            end # class Sphere
                                          end # module JWMShapes
                                          file parametric.rb has:
                                            class Parametric
                                            end # class Parametric
                                          end #module JWM;;JWMShapes
                                          file mesh_additions.rb has:
                                          module JWM;;Shapes
                                            class PolygonMeshHelper
                                            end #class PolygonMeshHelper
                                          end #module JWM;;Shapes
                                          Apparently, instead of (as I expected) the Sphere class looking for
                                          JWMShapes;;Shapes;;PolygonMeshHelper
                                          it is looking instead for
                                          What have I done wrong here, and how do I fix it? If you can help, I'll be most grateful
                                          [Later] The original SU Shapes named the overall module CommunityExtensions instead of JWM, and the mesh_additions.rb code says
                                          module CommunityExtensions;;Shapes
                                            module PolygonMeshHelper
                                            end # module PolygonMeshHelper
                                          end #module CommunityExtensions;;Shapes
                                          I.E., as well as the name change JWM<-->CommunityExtensions and JWM::JWMShapes<-->CommunityExtensions::Shapes, PolygonMeshHelper was a module, not a class.
                                          Changing it back from class to module doesn't seem to fix the problem.
                                          Looking at the above, I see that my mesh_additions.rb SHOULD say JWM::JWMShapes instead of JWM::Shapes
                                          , but changing that doesn't seem to fix things either.
                                          Help please, if you can! I'm temporarily stuck, and thoroughly confused.
                                            johnwmcc
                                            I see you posted again while I was replying. Many thanks.
                                            Will make the changes asap.
                                            • 3 / 4
