    [Plugin] 3D Parametric Shapes - makes placeable components
    76 Posts 21 Posters 27.6k Views 21 Watching
      johnwmcc
      I wonder, TIG, if you can help me understand what's gone wrong in trying to separate the code here from that in the older SU Shapes on the Extension Warehouse.
      The current problem is a name error: I get this error for the Dome and Sphere tools now, which both try to call mesh_additions.rb and fail. The other shapes don't need mesh_additions.rb, so still work properly.
      Error; #<NameError; uninitialized constant JWM;;JWMShapes;;Sphere;;PolygonMeshHelper>
      My overall code structure for the Sphere tool goes as follows (Dome has just the same structure), and I don't really understand it (just copied from SU Shapes!).
      file jwm_shapes.rb has:
      module JWM;;JWMShapes
        class Sphere < Parametric
        end # class Sphere
      end # module JWMShapes
      file parametric.rb has:
        class Parametric
        end # class Parametric
      end #module JWM;;JWMShapes
      file mesh_additions.rb has:
      module JWM;;Shapes
        class PolygonMeshHelper
        end #class PolygonMeshHelper
      end #module JWM;;Shapes
      Apparently, instead of (as I expected) the Sphere class looking for
      JWMShapes;;Shapes;;PolygonMeshHelper
      it is looking instead for
      What have I done wrong here, and how do I fix it? If you can help, I'll be most grateful
      [Later] The original SU Shapes named the overall module CommunityExtensions instead of JWM, and the mesh_additions.rb code says
      module CommunityExtensions;;Shapes
        module PolygonMeshHelper
        end # module PolygonMeshHelper
      end #module CommunityExtensions;;Shapes
      I.E., as well as the name change JWM<-->CommunityExtensions and JWM::JWMShapes<-->CommunityExtensions::Shapes, PolygonMeshHelper was a module, not a class.
      Changing it back from class to module doesn't seem to fix the problem.
      Looking at the above, I see that my mesh_additions.rb SHOULD say JWM::JWMShapes instead of JWM::Shapes
      , but changing that doesn't seem to fix things either.
      Help please, if you can! I'm temporarily stuck, and thoroughly confused.
        johnwmcc
        I see you posted again while I was replying. Many thanks.
        Will make the changes asap.
          I made the three simple changes which I suggested earlier... and it works without errors.
          You are getting yourself into a tangle... πŸ˜•
          Once you put a sub-module named within your all-encompassing 'JWM' module, then its name can be the same as similar names used in others' code...
          The nesting separates them...
          Calling them by your path JWM::... will avoid any that are poorly written by others and are 'global'...
          So be consistent use 'JWM::Shapes', OR if you must 'JWM::JWMshapes' etc consistently...
          Use Notepad++ with all affected files open and fine replace in all so they are internally consistent...
          Perhaps draw out on a sheet of A4 the nested relationships of these modules/classes.
          The full path I changed to works...
            johnwmcc
            Once again, TIG, thank you for cleaning up my muddle, and for explaining what's gone on.
            I will make the changes on my original copy here too, and go back to just called the sub-modules by the same name as the SU Shapes ones - simply Shapes.
            Have you updated the Plugin Store rbz file, or do I still need to fix the files here then upload them? And would it now be better to delete the attached file in the first post, and replace that by a link to the Plugin Store?
            Must stop now for a while - will resume later tonight.
              Please update your own files / RBZ in the PluginStore.
              But please remember to click on Publish afterwards πŸ˜‰
              I would recommend that you just have the one RBZ in the PluginStore, and add a link to its entry inside 'download' tags.
              Put that in the very first post: when I update a plugin I usually also add it into that announcement post - a one-click direct-link means that the reader doesn't have to find it again, either in the first-post or by looking within the PluginStore itself...
              The proper linking URL is http://sketchucation.com/pluginstore?pln=jwm_shapes
                johnwmcc
                Plugin store updated to v2.5.3, and first post in this thread now links to it.
                Downloaded and tested it here in SU2015.
                • B
                  blajnov
                  Works... Thanks!!! 😍
                  • JBJDesignsJ
                    JBJDesigns
                    @johnwmcc said:
                    Jo Ann - have you ever had another version of Shapes installed, whether from the SketchUcation Plugin store, or SketchUp or Trimble Extension Warehouse? There may still be a conflict, if so.
                    Please go to your AppData/Roaming/Sketchup/SU 2014/Sketchup/Plugins folder, and delete any existing file(s) called shapes.rb or su_shapes.rb, jwm_shapes.rb or jwm_shapes_loader.rb; and delete any existing folder(s) with the name su_shapes or jwm_shapes (including all that folder's contents).
                    Then reinstall the current version (v2.5 at time of writing) of the plugin from the Plugin Store here.
                    If that doesn't work, I'm stumped.
                    Best wishes, and I hope this works.
                    John McC
                    Hi John -- I just updated your 3D Parametric Shapes script, and after restarting SketchUp, it works!!!!! Yeah!!!!!. -- Jo Ann
                    ...you send them to school, you give them books, and they eat the pages...
                    • JBJDesignsJ
                      JBJDesigns
                      Hi John--
                      I get the following error message when I open SketchUp 2014; can you fix this? Thanks! Jo Ann πŸ˜„
                      • JBJDesignsJ
                        JBJDesigns
                        @tig said:
                        I can't get it to do that !
                        What's the start of the error message say ?
                        Hi TIG,
                        Doesn't matter... I just downloaded (updated) John's 3D Parametric Shapes script and it works!
                        Thanks,
                        Jo Ann
                          johnwmcc
                          Glad you got it going again with little trouble.
                          • E
                            Einstein
                            Great thanks, johnwmcc, for this plugin! Did you consider designing a toolbar for it? I'm sure for many users it became one of the very basic tools in SU. Having it accessible on top of the screen would be nice πŸ˜„
                              johnwmcc
                              Thanks for your appreciate comment.
                              Not sure I know how to do that, but will consider it when I have time (probably not for at least weeks) - I have several other higher priority projects on the go at the moment, leaving me little time to update this one.
                              • 4 / 4
