    Mini-Challenge #2
    26 Posts 7 Posters 3.9k Views 7 Watching
    • jeff hammondJ
      @slbaumgartner said:
      For shapes with an odd number of corners more info is necessary, as there is no innate definition of "opposite corner".
      right- once you've come up with a method, more info would be needed in the case of odd or multi numbered corners.. though i think the initial problem boils down to 'fit a rectangle between two angles".. the number of sides is irrelevant..
        slbaumgartner
        [attachment=0:qfxswsu7]<!-- ia0 -->Untitled.jpg<!-- ia0 -->[/attachment:qfxswsu7]
        Right, but when you eliminate the full shape you have to provide more info to pin down the problem. You can move and rotate either corner without changing its angle!
        • jeff hammondJ
          ok
            You need to know several things...
            The distance between the two points where the angles are located [the line forming one diagonal of the quad']
            You also need to know the four angles subtended to that line by each of the four lines forming the two angles.
            From that you can do some calculations to give the range of x/y sizes for the potential rectangles that will touch all four lines [aka the sides of the quad'].
            And i assume that no one quad' internal angle can be >180 deg ?
            Does a rectangle that touches a side at the vertex itself 'in the limit', also 'count' ?
            • jeff hammondJ
              @tig said:
              Does a rectangle that touches a side at the vertex itself 'count' ?
              i suppose there are a few cases where a corner of the rectangle would coincide with a vertex of the quad (it would be the point at which if the angles were offset any further, that particular quad wouldn't have a solution at all.. not all quadrangles will be solvable)
              for all intents and purposes, the .skp in the original post has an unsolved shape in which all the things which need to be known are known.. so, using that one as an example, can you find a solution for it?
              • BoxB
                There could be hidden unknowns or maybe known unknowns, perhaps even unknown unknowns that we either do or don't, may or may not, have known about whether we know about not knowing about them or not.
                • jeff hammondJ
                  πŸ˜†
                    slbaumgartner
                    I don't know about that...
                      Who knows ?
                      Someone does...
                      πŸ˜‰
                      • P
                        pgarmyn
                        From TIG's drawing
                        There are 6 constraints A1, A2, B1, B2, distance A-B and "thickness" of the inscribed rectangle
                        Thus we need, twice, a 7*7 matrix to solve each of the two corners (A-B). Who can define them?
                        The solution must give the distance (radius of the tangent circle) between the axe of the inscribed rectangle and each point (A and B).
                        • sdmitchS
                          sdmitch
                          http://youtu.be/_0TY6HHL25Y
                          A graphical solution.
                          http://sdmitch.blogspot.com/
                          • jeff hammondJ
                            hey sdmitch..
                            that's only doing one side of it though.. the difficulty comes when trying to fit the rectangle between two corners.
                            do you have a solution for that?
                            • sdmitchS
                              sdmitch
                              @jeff hammond said:
                              hey sdmitch..
                              You have to repeat the process on the other end also of course. Connecting those lines to create a face produces a slightly skewed rectangle. Rotating the ends to create a regular rectangle moves the ends but, in my test, by less than 0.01" from the edge. The perfect solution would require several iterations.
                                Each of the two corners have two extreme limits.
                                Where the 'x' width of the inscribed rectangle's end meet at 90 degrees.
                                These limits have an 'overlap' at each end.
                                If the corner's angle is <=90 degrees then the possible range is limited.
                                if is the 'overlap' of the two possible solutions.
                                If its > 90 degrees the range is 'x' set off from the corner vertex itself [of course only the full range applies if the quads angles are 90 degrees]
                                You only need to test one 'corner'.
                                You take a series of pairs of points which fall within the two 'overlap' zones on the two edges sharing that corner's vertex - which of course must also be exactly 'x' apart when measured at the angle.
                                of an inscribed rectangle.
                                To do that we need to project a line from the two end vertices, at a vector that is transformed to be perpendicular to that line [x], and check if it intersects with the lines of the other two edges [i.e. those which are not shared the 'corner']; and where it does, if that intersected point is between the two ends of the tested line, and then of the length of the two tested vectors from each of the x.vertex.position to the hit.point is the same length, then the two long sides of the rectangle would be corrected so we have a match.
                                To minimize the number of tests the two corners could be compared and the overlap lengths compared - the shortest set then have the fewest tests...
                                Now potentially there is a whole series of solutions for 'x' in the minimum corner's zone set that would fit an inscribed rectangle into the quad...
                                Now to code it...
                                  slbaumgartner
                                  I worked out an analytic geometry solution using the formulas for the distance between two points and for the intersection point of two given lines. Solving is "just" a matter of algebra. However, the remaining difficulty is that the math formulation covers various configurations that have no real-value solution (e.g. attached image) and it is difficult (or at least confusing) to weed these out of the formulas.
                                  • sdmitchS
                                    sdmitch
                                    [attachment=1:2acewcov]<!-- ia1 -->Screen Shot 2014-12-02 at 9.43.20 AM.png<!-- ia1 -->[/attachment:2acewcov]
