    Guidelines at fibonacci series spacing?
    28 Posts 7 Posters 1.6k Views 7 Watching
    • john2J Offline
      john2
      @box said:
      If you are not understanding how to draw the gauge and you are using 2015, then it's because it doesn't work in 2015.
      Okay. Thanks. Again. I've broken records for saying thanks on a forum in single day today. πŸ‘ πŸ˜„
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
      • KrisidiousK Offline
        Krisidious
        It works in 2015...
        Face to gauge
        select GG from extensions menu.
        Select the first corner of the face to gauge.
        Select the second corner of the face to gauge.
        Select the third corner of the face to gauge.
        viola
        viola
        By: Kristoff Rand
        • BoxB Offline
          There must be some sort of conflict for me then as it works perfectly in 2014 and does nothing in 2015.
          • john2J Offline
            john2
            Alrighty, in 2015 it works on vertical faces but not horizontal faces. Thanks a lot for replying. πŸ‘ πŸ‘
              Krisidious
              strange... I guess I didn't try vertical. gimmie a minute.
              confirmed... doesn't work when second point is clicked in a Z axis... second point must be X or Y. third point can then be Z axis.
              something's wrong.
              By: Kristoff Rand
              • BoxB Offline
                Personally I don't think it functions correctly in 14 or 15. It's erratic and needs to be updated.
                  Krisidious
                  I don't know how active Rick is anymore...
                  By: Kristoff Rand
                    The GoldenGauge.rb file requires select.rb
                    That is the file with an issue if the old 'examples' has not been set up and which would have made $exStrings - but this is not likely in the newer SketchUp versions !
                    To fix it - edit select.rb using Notepad/Notepad++ - near the start add the two green lines shown, below the first ' require':
                    require 'sketchup.rb' **%(#008000)[require 'langhandler.rb' $exStrings = LanguageHandler.new('examples.strings') unless $exStrings]**
                    It'll now work in all versions of SketchUp...
                    • BoxB Offline
                      Yep that works.
                      Am I right in thinking it isn't designed to work on the Z Plane, ie: you can't draw one flat on the floor.
                        @box said:
                        Yep that works.
                        I see what you mean !
                        I only ever used it on vertical wall-faces !
                        I'll look at it...
                          The code transforms in the Z, so if all Z's are the same it won't work [i.e. it's a flat horizontal face].
                          Is suppose the clue is in the prompts: 'select width' p2 and 'select width' p3 - suggesting walls - after all such proportions are usually in elevations, fenestration etc...
                          It'd be quite possible to make non-plane specific version - but it's more work than a minor 'tweak'...
                          • BoxB Offline
                            Doesn't matter to me, just wanted to clarify.
                            It's simple to flip on its side if you want it on the floor.
                              Krisidious
                              πŸ‘
                              By: Kristoff Rand
                              • john2J Offline
                                john2
                                Thanks TIG sir! Well, is it ethical that the moderator or the admin modifies the plugin uploaded on Smustard website for the betterment of its use by the common people who don't know coding? And posts it here? πŸ’­
                                It is available free of cost anyway. So, there is no legal issues.
                                It doesn't matter. A better stuff is available on SCF rather than the outdated thing. Don't you think sir? πŸ’­
                                  kaas
                                  you could also make a group / component with 3 lines spaced at the golden gauge intervals. If you need to divide any other/new surface just move the group/component and scale it to the desired endpoints. The 'middle' line (golden gauge) will be at the correct scaled position.
                                    driven
                                    tig hasn't 'redistributed' a modified version of the ruby, he has shared how he fixed his version to make it fit for purpose...
                                    If you chose to modify your version, then any ethical dilemma is yours...
                                    I might add that in the UK [at least] modifying your own copies of software for your own use, is considered a consumer right, and overrides any 'license' or 'copy-write' conditions forbidding the activity...
                                      Krisidious
                                      I think he was asking Tig to do so permanently, not questioning whether he had broken any ethic.
                                      By: Kristoff Rand
                                        Yes, I have done nothing wrong in suggesting a fix which YOU might apply to a freely download-able file - the infringement of copyright is entirely yours... The select.rb file does state it is copyright.
                                        Do not copy it, but if you modify it for your own use, then no one will ever know. This fix is one which the author might have done, had he been arsed to do it. He is probably still around... but he does not seem to support/fix his older toolsets...
                                        The reason I did not suggest a similar fix for his GoldenGauge.rb, was because it needed such a change in thew way it works that it was difficult to fix with a single 'tweak'. It could be recoded... but that is a very different issue...
                                        πŸ˜’
                                        • john2J Offline
                                          john2
                                          πŸ˜’
                                          Pardon my lack of techie knowledge about tweak, recoded. I'm not understanding the different issue thing.
                                          Kindly bear with me.
                                          All I am saying is this. You add the suggested lines in the original golden gauge rb file and upload it here on SCF forums as "Tweaked Golden gauge plugin" . That would completely okay and legal right? Rick won't get annoyed if this happens. πŸ’­
                                            Krisidious
                                            The Rick I know would not mind one bit...
                                            By: Kristoff Rand
