    Guidelines at fibonacci series spacing?
    28 Posts 7 Posters 1.4k Views 7 Watching
    • john2J Offline
      john2
      Can I make guidelines spaced as per fibonacci series?
      I am manually doing this. I made a fibonacci calculation spreadsheet in another software, then I am manually feeding the dimensions.
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
      • cottyC Offline
        cotty
        There's a plugin parametric copy (never tried it).
        From the description:
        • You can use predefined formulas, such as Fibonacci and Exponential, or write your own formulas as freeform expressions.
        • You can also use the output of another program or process, expressed as a list of numbers.
        my SketchUp gallery
        • KrisidiousK Offline
          Krisidious
          Golden Gauge Plugin gives you Fibonacci divisions.
          (www.smustard.com)
          Curve Maker will give you a Fibonacci Spiral.
          (www.drawmetal.com)
          By: Kristoff Rand
          • john2J Offline
            john2
            You guys are seriously awesome...seriously seriously aweseome.. πŸ‘ πŸ‘ . If I'd met you in person, I'd be having a cup of cold coffee with dark chocolate with you guys. Thanks a ton.
              Krisidious
              We're here to help... πŸ˜„
              By: Kristoff Rand
              • john2J Offline
                john2
                I'm somehow not able to understand the functioning of the golden gauge plugin. Can anyone make a step by step tutorial for it? Reading on smustard didn't help
                • BoxB Offline
                  If you are not understanding how to draw the gauge and you are using 2015, then it's because it doesn't work in 2015.
                  • john2J Offline
                    john2
                    Okay. Thanks. Again. I've broken records for saying thanks on a forum in single day today. πŸ‘ πŸ˜„
                      Krisidious
                      It works in 2015...
                      Face to gauge
                      select GG from extensions menu.
                      Select the first corner of the face to gauge.
                      Select the second corner of the face to gauge.
                      Select the third corner of the face to gauge.
                      viola
                      viola
                      By: Kristoff Rand
                      • BoxB Offline
                        There must be some sort of conflict for me then as it works perfectly in 2014 and does nothing in 2015.
                        • john2J Offline
                          john2
                          Alrighty, in 2015 it works on vertical faces but not horizontal faces. Thanks a lot for replying. πŸ‘ πŸ‘
                            Krisidious
                            strange... I guess I didn't try vertical. gimmie a minute.
                            confirmed... doesn't work when second point is clicked in a Z axis... second point must be X or Y. third point can then be Z axis.
                            something's wrong.
                            By: Kristoff Rand
                            • BoxB Offline
                              Personally I don't think it functions correctly in 14 or 15. It's erratic and needs to be updated.
                                Krisidious
                                I don't know how active Rick is anymore...
                                By: Kristoff Rand
                                  The GoldenGauge.rb file requires select.rb
                                  That is the file with an issue if the old 'examples' has not been set up and which would have made $exStrings - but this is not likely in the newer SketchUp versions !
                                  To fix it - edit select.rb using Notepad/Notepad++ - near the start add the two green lines shown, below the first ' require':
                                  require 'sketchup.rb' **%(#008000)[require 'langhandler.rb' $exStrings = LanguageHandler.new('examples.strings') unless $exStrings]**
                                  It'll now work in all versions of SketchUp...
                                  • BoxB Offline
                                    Yep that works.
                                    Am I right in thinking it isn't designed to work on the Z Plane, ie: you can't draw one flat on the floor.
                                      @box said:
                                      Yep that works.
                                      I see what you mean !
                                      I only ever used it on vertical wall-faces !
                                      I'll look at it...
                                        The code transforms in the Z, so if all Z's are the same it won't work [i.e. it's a flat horizontal face].
                                        Is suppose the clue is in the prompts: 'select width' p2 and 'select width' p3 - suggesting walls - after all such proportions are usually in elevations, fenestration etc...
                                        It'd be quite possible to make non-plane specific version - but it's more work than a minor 'tweak'...
                                        • BoxB Offline
                                          Doesn't matter to me, just wanted to clarify.
                                          It's simple to flip on its side if you want it on the floor.
                                            Krisidious
                                            πŸ‘
                                            By: Kristoff Rand
