    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 951.0k Views 155 Watching
    • fredo6F
      @mvsuriano,
      Could you open the Ruby Console before clicking on the JPP icon, in case there are error messages displayed
        mvsuriano
        @fredo6 said:
        @mvsuriano,
        HI Fredo - turns out I do have an error. I did update to FredoLib 6.3a prior to install. This is the error I get.
        Error: #<NameError: uninitialized constant G6::ShapeGrid>
        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb:101:in initialize' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb:64:in new'
        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb:64:in action__mapping' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:133:in call'
        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:133:in launch_action' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/bootstrap_JointPushPull.rb:81:in launch_action'
        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/bootstrap_JointPushPull.rb:128:in block in declare_command' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1080:in call'
        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1080:in command_invoke' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1062:in block (2 levels) in build_config_commands'
        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:1077:in call' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:1077:in block in add_command'
        -e:1:in `call'
          Try deleting the LibFredo6 files/folder from the Plugins folder and install the current version again. I had a problem due to some file not getting removed/overwritten when I installed the latest version. Deleting and installing fresh took care of it though.
            mvsuriano
            Just did a fresh install per your prompt, but still the same result:
            Error: #<NameError: uninitialized class variable @@lib_fredo_folder in LibFredo6>
            C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/libfredo6.rb:67:in folder' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:79:in use_single_library'
            C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:70:in block in use_libraries' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:70:in each'
            C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:70:in use_libraries' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1085:in usage_use'
            C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1079:in command_invoke' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1062:in block (2 levels) in build_config_commands'
            -e:1:in `call'
            • fredo6F
              You definitely have a problem with installation of LibFredo6 6.3.
              Where does this file "libfredo6.rb" comes from ?
              I mean C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/libfredo6.rb
              Please delete it, and retry.
                mvsuriano
                Old library file! Removed and it works just fine. Thanks Fredo!
                • frankflafyF
                  frankflafy
                  is this compatible with sketchup 2015 32 bit? i cant make the plugin select the face.
                    Yes. It is compatible.
                    Why don't you post a sample SKP file that illustrates the problem you're having? Help us help you.
                      Should be compatible.
                      Does it load properly ?
                      Have you read and understood its usage/instructions ?
                      Are there any error messages in the Ruby Console when you try to use it ?
                      Have you installed the latest LibFredo ? You need to do this as well, and restart SketchUp...
                      • BoxB
                        Be sure you are doing it the right way, it is click and drag.
                          That error message will be very useful to Fredo in establishing what's wrong...
                          Over to him... πŸ˜•
                          • frankflafyF
                            frankflafy
                            should i PM him?
                              You could, but Fredo regularly visits here, so he should see your post/plight soon...
                              • frankflafyF
                                frankflafy
                                Does it load properly ? Yes it load properly
                                Have you read and understood its usage/instructions ? i understand the usage, in older version of SU i used it everyday.
                                Have you installed the latest LibFredo ? I installed latest and restarted my SU.
                                I have delete the lib and reinstall. but it dont help.
                                -and yes, this is the error i found on my ruby console-
                                This when i load the plugin
                                Error; #<NoMethodError; undefined method `entityID' for #<Sketchup;;Model;0x9ee8468 @cache_file_name=nil>>
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/body_Lib6FacePicker.rb;791;in `selection_add_remove_faces'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/body_Lib6FacePicker.rb;731;in `selection_initial'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb;565;in `handle_initial_selection'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb;514;in `activate'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb;64;in `select_tool'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb;64;in `action__mapping'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb;133;in `call'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb;133;in `launch_action'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/bootstrap_JointPushPull.rb;81;in `launch_action'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/bootstrap_JointPushPull.rb;128;in `block in declare_command'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb;1080;in `call'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb;1080;in `command_invoke'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb;1062;in `block (2 levels) in build_config_commands'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;1077;in `call'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;1077;in `block in add_command'
                                SketchUp;1;in `call'
                                This when i select the face
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/body_Lib6FacePicker.rb;744;in `selection_validate'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/body_Lib6FacePicker.rb;622;in `selection_validate_if_add'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb;676;in `selection_freeze_positions'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb;1283;in `onLButtonDown'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/body_Lib6FacePicker.rb;916;in `onLButtonUp'
                                C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb;1315;in `onLButtonUp'
                                Please Help. πŸŽ‰
                                • fredo6F
                                  @frankflafy
                                  The error on <model>.entityID is very strange because in Sketchup this is valid (it returns "Model".
                                  Do you get this error for a sepcific model or always?
                                  • tt_suT
                                    tt_su
                                    @fredo6 said:
                                    @frankflafy
                                    Actually, this is Dynamic Component that adds that to the Model class. It adds a few methods to make the Model class blend with the regular Entity class.
                                    The changes DC do to the SketchUp API classes makes sense - but unfortunately they where added as part of DC and not the API. So if DC is disabled they won't work.
                                    I personally want them merged into the official API - though there are challenges as some of them are not ideal for the API, as they have some failing edge cases that was good enough for DC, but not for an API. Need to be careful to reduce breaking things. Hence it's not been done yet.
                                    • frankflafyF
                                      frankflafy
                                      @fredo6 said:
                                      @frankflafy
                                      its fixed after i enabled the DC.
                                      yes i disable the DC because of never used it. thanx for the respond.
                                        Marko87
                                        Everytime I try to use Joint push pull, it freezes at 63 %.. Please help, I really need that tool for shape I'm working on it.. I'm using SU 15 pro. Thank you!!
                                          Do you mean by 'every time' - 'whatever I try to use it on [even the simplest box]...'
                                          OR do you mean - 'whenever I try to use it on a particular set of geometry...'
                                          First off, we must assume you have installed the latest version of this tool and the required Lib ??
                                          If it's the first problem, then something is up with either the way the tool is installed or you are trying to use it - as it works faultlessly for most of us.
                                          What settings etc are you using ?
                                          If it's the second problem, then there's probably something wrong with your geometry...
                                          Can you post a SKP of it so that we can check it out, and thereafter advise you more constructively...
                                          • josephkim626J
                                            josephkim626
                                            Feature Request.
                                            Hi, Fredo.
                                            I love your plugin, and have been using it very well for awhile now.
                                            Because of my workflow, there is a tiny feature request I would like to make if it isn't too difficult.
                                            Joint Push Pull
                                            Let me know if there is a way to produce the result that is shown on the right, as supposed to the one on the left.
                                            (Maybe there is a way, I suspect with "Borders" and different type of push-pull modes, but no luck so far)
                                            I would like two or more faces connected to be pushed all-together, but no edges created on the sides.
                                            Thank you in advance.
                                            • 11
                                            • 30
                                            • 31
                                            • 9 / 31
