    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 887.4k Views 155 Watching
      littleche
      "Dave R" & "Box" Thanks for your help ...
      revers and oriant face does not affect the performance of jointP&P plugin.
      Yes, I agree my linework is bad but in bad line plugin good working !
      I have tried many different ways But according to the your advice I still was not able to reach my goal.Another way to tell if it is possible ...
      Is not this a bug in the plugin?
        It would be nice to blame the plugin because your bad line work is causing the problem, wouldn't it? 😒
        • BoxB Offline
          It's not a fault with the plugin, it is attempting to follow what you have drawn.
          Get everything on the same layer and clean up your geometry and the plugin works.
          I've no idea how you drew it in the first place but perhaps it would be easier to start again and get the geometry right rather than trying to repair it.
            littleche
            This problem was solved! Thank you for your help ... my worklin was very bad .I got to practice tips that you said and Finally I drew a good workline with tools on surface plugin and jointpull&push It's nice to end. 😍
            and Again, thanks ... 👍
            • BoxB Offline
              Well done.
              Learning to get your structure right in the first place is far better for you than getting a plugin to work.
              • fredo6F Offline
                NEW RELEASE: JointPush Pull Interactive v3.3a - 19 Oct 14
                JointPushPull Interactive 3.3a is required for the support of usernames with non-ascii characters in Sketchup 2014
                See main post of this thread for Download of JointPushPull.
                  mvsuriano
                  Hello - I've been using the old version of JPP for some time - its awesome. Recently tried to install the newest version via SketchUcation tools in SU 2014.
                  I see the toolbar, however, clicking on any button/tool in the JPP toolbar doesn't do anything, it just defaults to the tool I had selected prior.
                  Any suggestions?
                  Mike
                  • cottyC Offline
                    cotty
                    Any suggestions?
                    Mike
                    Did you update LibFredo to version >=6.3? Are there error messages in the ruby console?
                    my SketchUp gallery
                    • fredo6F Offline
                      @mvsuriano,
                      Could you open the Ruby Console before clicking on the JPP icon, in case there are error messages displayed
                        mvsuriano
                        @fredo6 said:
                        @mvsuriano,
                        HI Fredo - turns out I do have an error. I did update to FredoLib 6.3a prior to install. This is the error I get.
                        Error: #<NameError: uninitialized constant G6::ShapeGrid>
                        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb:101:in initialize' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb:64:in new'
                        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb:64:in action__mapping' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:133:in call'
                        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:133:in launch_action' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/bootstrap_JointPushPull.rb:81:in launch_action'
                        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/bootstrap_JointPushPull.rb:128:in block in declare_command' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1080:in call'
                        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1080:in command_invoke' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1062:in block (2 levels) in build_config_commands'
                        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:1077:in call' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:1077:in block in add_command'
                        -e:1:in `call'
                          Try deleting the LibFredo6 files/folder from the Plugins folder and install the current version again. I had a problem due to some file not getting removed/overwritten when I installed the latest version. Deleting and installing fresh took care of it though.
                            mvsuriano
                            Just did a fresh install per your prompt, but still the same result:
                            Error: #<NameError: uninitialized class variable @@lib_fredo_folder in LibFredo6>
                            C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/libfredo6.rb:67:in folder' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:79:in use_single_library'
                            C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:70:in block in use_libraries' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:70:in each'
                            C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:70:in use_libraries' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1085:in usage_use'
                            C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1079:in command_invoke' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1062:in block (2 levels) in build_config_commands'
                            -e:1:in `call'
                            • fredo6F Offline
                              You definitely have a problem with installation of LibFredo6 6.3.
                              Where does this file "libfredo6.rb" comes from ?
                              I mean C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/libfredo6.rb
                              Please delete it, and retry.
                                mvsuriano
                                Old library file! Removed and it works just fine. Thanks Fredo!
                                • frankflafyF Offline
                                  frankflafy
                                  is this compatible with sketchup 2015 32 bit? i cant make the plugin select the face.
                                    Yes. It is compatible.
                                    Why don't you post a sample SKP file that illustrates the problem you're having? Help us help you.
                                      Should be compatible.
                                      Does it load properly ?
                                      Have you read and understood its usage/instructions ?
                                      Are there any error messages in the Ruby Console when you try to use it ?
                                      Have you installed the latest LibFredo ? You need to do this as well, and restart SketchUp...
                                      • BoxB Offline
                                        Be sure you are doing it the right way, it is click and drag.
                                          That error message will be very useful to Fredo in establishing what's wrong...
                                          Over to him... 😕
                                            frankflafy
                                            should i PM him?
                                            • 30
                                            • 31
                                            • 8 / 31
