    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 107.7k Views 69 Watching
    • jolranJ
      jolran
      but.. it says su8 is supported..
      Ah, yeah you are right. Then I guess he just probably forgot to set up some conditions for Su8. Well see when he get's back.
      Meanwhile do a testspin in 2014. πŸ˜„
      It may have be a condition set on line 26 in the loader rb
      "file = FILE.dup.force_encoding("UTF-8")"
      If I remember correctly Ruby 1.8 (Su8) does not have that method..
      I'm not gonna mess with that since I don't know how he has things set up with TT_Lib so I suggest waiting for his return..
      • panixiaP
        panixia
        never thought for a second to fix the code by myself πŸ˜†
        anyway i downloaded su15 and it works perfectly.. too bad su2015 doesn't fit my needs at the moment (mainly for the other 31454535 plugin i use)
        this tool is great! sort of pseudo-nurb brother of vertex tools..
        waiting for su8 news.. πŸŽ‰
        • U
          unclex
          Yes
          For 2013 or 8 user
          just change that like this
          "file = FILE"
          • BoxB
            Did you restart Sketchup after installing it?
            • jolranJ
              jolran
              Yes
              For 2013 or 8 user
              "file = FILE"
              Like I said, better let Thomthom do it properly. Even if it looks like a simple fix, it "may" have consequences for TT_lib since removing encoding.
              Although, nothing "bad" should happend if you only experiment at 1 place..
              • U
                unclex
                It's just always updating...
                Cannot Click or DoubleClick
                and when SU opening, nothing prompt
                  @jolran said:
                  Do you use Knotvectors for the patches ? Or are they interval-based type powerbasis functions ?
                  Edit: Ah right, they are not spline-based, (duh). So you go through the C-extensioncode right ?
                  It's simple bezier quad patches with 4x4 control points each. The bezier calculation is based on the bezier example script posted by @last many years ago, I just ported it to C for faster calculations. You can see the source in TT_Lib2.
                    @jolran said:
                    How do you add Tripatch to Qaudpatch ? Possible ?
                    No, this was on my todo, once the quad patches was done. I removed the main toolbar button for it right before release, but forgot there was menu items and that second webdialog toolbar. I should push a new update the removes the unused controls in the dialog.
                      @box said:
                      This rough test torso is less than five minutes work.
                      Really? 😲 I didn't expect the extension to be that useful in it's current state. I hope people do post back more picture.
                      • OxerO
                        Oxer
                        Thanks you very much for the plugin!! πŸ‘ πŸ‘
                        I installed it in SU2014 & SU2015 on Mac but the plugin didn't work, I found a conflict with smartdrop.rb and Sketchyphysics, I deleted smartdrop.rb (I use tt.raytracer now to drop components) and I have deactivated Sketchyphysics on SU2014 with Sketchucation Plugins Manager and Bezier Surface work fine now.
                          @panixia said:
                          it looks super nice thank you but it doesn't work for me (sketchup 8 on win7).. 😒
                          i suppose i installed it properly and also updated ttlib to last version..
                          i suspect it may depends on some conflict with tons of other plugins.. πŸ˜’
                          Should work with SU7 and up, I think. Any error messages?
                            Same here. I only had it working in 2014.
                            Error "defined method `force_encoding' for #String:0xb10993c"
                            This is "probably" and Ruby 1.8 error. I have the impression that many authors will stop supporting SU 8 soon.
                            Yea, with my new subdivison extension I'm certainly dropping support for anything older than SU2014.
                            Though this was written before SU2014 and it should work. (Though might have introduced a bug when I added SU2014 support. Can you provide the full error message and exact SketchUp version and OS?)
                              @panixia said:
                              yeah. force encoding blablabla.. getting similar message when loading sketchup
                              The bla bla bla bit of error message is in fact very useful for developers when debugging errors - please post all of it when reporting issues.
                                Ah - right, I'll fix that and push an update next week.
                                  Like the GIF[attachment=0:1br0oo34]<!-- ia0 -->8.gif<!-- ia0 -->[/attachment:1br0oo34]
                                  Any errors in the Ruby Console?
                                  What SketchUp version?
                                    SketchyPhysics is known to clash with extensions. I think an update is coming.
                                    Not sure about smartdrop.rb - not familiar with that one.
                                    • OxerO
                                      Oxer
                                      A quick test taking like reference the torso of Box.
                                      • panixiaP
                                        panixia
                                        i'm pretty much sure that the "blablabla" part of the message returned ad least 3 different values with different tries (that's pretty odd i suppose) the last try being: "Loading File tt_bezier_surface.rb
                                        undefined method `force_encoding' for #String:0xec947b8no such file to load --" 😲
                                        hope this can help
                                          I'll mainly focus on my subdivision extension over this one. Though I'll try to maintain small bug fixes and pull requests. I'll see after SUbD is done what I do with this project.
                                          Btw, I have a fix for the compatibility bug with SU2013 and older. I'll be pushing an update.
                                          • jolranJ
                                            jolran
                                            I understand.
                                            πŸ‘
                                            • 11
                                            • 12
                                            • 13
                                            • 8 / 13
