    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 97.5k Views 69 Watching
    • BoxB Offline
      Sorry About that Jolran, I misread your question, didn't realise it was specifically the tris you were after.
      In case anyone is wondering how useful and fast this is to work with.
      This rough test torso is less than five minutes work.
        Rodin! πŸ˜„
        • jolranJ Offline
          jolran
          No worries πŸ˜„ Nice chest.
          • panixiaP Offline
            panixia
            it looks super nice thank you but it doesn't work for me (sketchup 8 on win7).. 😒
            i suppose i installed it properly and also updated ttlib to last version..
            i suspect it may depends on some conflict with tons of other plugins.. πŸ˜’
            • jolranJ Offline
              jolran
              Same here. I only had it working in 2014.
              Error "defined method `force_encoding' for #String:0xb10993c"
              This is "probably" and Ruby 1.8 error. I have the impression that many authors will stop supporting SU 8 soon.
              • panixiaP Offline
                panixia
                yeah. force encoding blablabla.. getting similar message when loading sketchup
                but.. it says su8 is supported..
                  d12dozr
                  Thanks, Thomthom. Time to play!
                  http://goo.gl/f7ooYh
                  • jolranJ Offline
                    jolran
                    Ah, yeah you are right. Then I guess he just probably forgot to set up some conditions for Su8. Well see when he get's back.
                    Meanwhile do a testspin in 2014. πŸ˜„
                    It may have be a condition set on line 26 in the loader rb
                    "file = FILE.dup.force_encoding("UTF-8")"
                    If I remember correctly Ruby 1.8 (Su8) does not have that method..
                    I'm not gonna mess with that since I don't know how he has things set up with TT_Lib so I suggest waiting for his return..
                    • panixiaP Offline
                      panixia
                      never thought for a second to fix the code by myself πŸ˜†
                      anyway i downloaded su15 and it works perfectly.. too bad su2015 doesn't fit my needs at the moment (mainly for the other 31454535 plugin i use)
                      this tool is great! sort of pseudo-nurb brother of vertex tools..
                      waiting for su8 news.. πŸŽ‰
                      • U Offline
                        unclex
                        Yes
                        For 2013 or 8 user
                        just change that like this
                        "file = FILE"
                        • BoxB Offline
                          Did you restart Sketchup after installing it?
                          • jolranJ Offline
                            jolran
                            Yes
                            For 2013 or 8 user
                            "file = FILE"
                            Like I said, better let Thomthom do it properly. Even if it looks like a simple fix, it "may" have consequences for TT_lib since removing encoding.
                            Although, nothing "bad" should happend if you only experiment at 1 place..
                            • U Offline
                              unclex
                              It's just always updating...
                              Cannot Click or DoubleClick
                              and when SU opening, nothing prompt
                                @jolran said:
                                Do you use Knotvectors for the patches ? Or are they interval-based type powerbasis functions ?
                                Edit: Ah right, they are not spline-based, (duh). So you go through the C-extensioncode right ?
                                It's simple bezier quad patches with 4x4 control points each. The bezier calculation is based on the bezier example script posted by @last many years ago, I just ported it to C for faster calculations. You can see the source in TT_Lib2.
                                  @jolran said:
                                  How do you add Tripatch to Qaudpatch ? Possible ?
                                  No, this was on my todo, once the quad patches was done. I removed the main toolbar button for it right before release, but forgot there was menu items and that second webdialog toolbar. I should push a new update the removes the unused controls in the dialog.
                                    Really? 😲 I didn't expect the extension to be that useful in it's current state. I hope people do post back more picture.
                                    • OxerO Offline
                                      Oxer
                                      Thanks you very much for the plugin!! πŸ‘ πŸ‘
                                      I installed it in SU2014 & SU2015 on Mac but the plugin didn't work, I found a conflict with smartdrop.rb and Sketchyphysics, I deleted smartdrop.rb (I use tt.raytracer now to drop components) and I have deactivated Sketchyphysics on SU2014 with Sketchucation Plugins Manager and Bezier Surface work fine now.
                                        Should work with SU7 and up, I think. Any error messages?
                                          Yea, with my new subdivison extension I'm certainly dropping support for anything older than SU2014.
                                          Though this was written before SU2014 and it should work. (Though might have introduced a bug when I added SU2014 support. Can you provide the full error message and exact SketchUp version and OS?)
                                            The bla bla bla bit of error message is in fact very useful for developers when debugging errors - please post all of it when reporting issues.
                                            • 11
                                            • 12
                                            • 13
                                            • 8 / 13
