    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    335 Posts 107 Posters 468.3k Views 107 Watching
    • facerF Offline
      facer
      T2H,
      Great plugin, keep up the good work!
      V2.1.0 - Question ??
      I am using Skp 2014, W7, 32bit
      1. I note that I can only get the "Draw by click" to work in the SMALL - simple window of
        the Toggle_UI. I find in the SMALL UI it is hard to read the data due to the small text size.
        The LARGER UI is easier for me to read. Can this be achieved?
      2. Is the new STEEL BEAM (ref attachment) data saved for latter use?
        I can not find my new STEEL BEAM in the data.
      Thanks again,
      Ray
      UB207x134 data input
        cadmunkey
        @facer said:
        1. Is the new STEEL BEAM (ref attachment) data saved for latter use?
        Thanks again,
        Ray
        Did you create that in the table editor? If so it seems to shift newly created elements to the bottom of your lists, not in order of actual section size.
          tak2hata
          Hi,all.
          I update this to v2.2.0. in 2014.11.16.
          Apply IFC classification in sketchup2015.
          by TAK2HATA
            goga63
            And again great work ! 👍 👍 👍
            Only after carrying over of function of editing of a profile directly in the table, the button "Profile Schema Edit" shows an empty window.
            Here new Russian translation to a plug-in.
            lang_ru.txt
              cadmunkey
              @tak2hata said:
              Hi,all.
              Genius! Thank you so much for this update 😄 👍
              • OxerO Offline
                Oxer
                Thanks for the update, the Profile Schema Edit window doesn't open because in the line 545 of main.rb file the path isn't correct:
                 line 548-> htmfile = File.join(File.dirname(__FILE__),'bst_profile_creator2.html')
                You need fix the path to:
                 line 548-> htmfile = File.join(File.dirname(__FILE__),'bst_profile_creator.html')
                  cadmunkey
                  Strange, I'm using the new version and didn't have that issue Oxer.
                    tak2hata
                    Hi,All.
                    I update this to v2.2.1. in 2014.11.22.
                    Some bugs fixed.
                    and Change the sample profile files to have no extension name.
                    I found the point that oxer said.
                    by TAK2HATA
                    • OxerO Offline
                      Oxer
                      Hi tak2hata,
                      When I push Show tool icon it appears this warning window:
                      I suppose this is because default_pflist.xml file isn't included with the plugin. When I install the file by myself in the sample_pflist folder and then I select it through Change Profile-List File, on OSX & SU2015 the Shapes and Multiple Wall are empty in Tool Options window:
                      but in SU2014 the content of these folders appears.
                        tak2hata
                        Hi,oxer.
                        This did not include the default_pflist.xml file in older version,too.
                        Only "sample_pflist_jis_japan.tsv" and "sample_pflist_northAmerica.tsv" and "sample_pflist_UK_AC.tsv" were included.
                        Now "sample_pflist_jis_japan" and "sample_pflist_northAmeric" and "sample_pflist_UK_AC" are included.
                        So I think missing "default_pflist.xml" file is not caused to new version.
                        About Empty when select "MWall" and "Shapes",
                        Does the folders exist in your plguin folder?
                        by TAK2HATA
                        • OxerO Offline
                          Oxer
                          Yes, the folders exist and they have content:
                          This happens in SU2015 only, in SU 2014 the content of the folders appear in the Tool Options window correctly.
                            tak2hata
                            Hi,all
                            I update this to V2.2.4 in 2014-12-07.
                            Some bugfix and Improve the profile selector.and "Mwall" Work well on MacOSX.
                            Hi,Oxer.
                            Please try this version.
                            by TAK2HATA
                            • chialiang168C Offline
                              chialiang168
                              https://dl.dropboxusercontent.com/u/108539326/001-Share/building_structure_tools/languages.JPG
                              Chinese and Taiwanese language files
                              中国と台湾の言語ファイル
                              中国と台湾の言語ファイル
                              • OxerO Offline
                                Oxer
                                I installed the v2.2.4 and all work fine now on OS X 10.10.1 👍
                                Thanks tak2hata !!
                                • sumasterS Offline
                                  sumaster
                                  Hello T2H Sir,
                                  CHK web dialog box its working perfect but not working like your previous version.
                                  Means when i draw wall and set parameters like wall height : 10' and width : 4" and start draw a wall and when i change the wall height : 2' and wall width : 1' and draw continue in view-port the tool not get new parameters . . . . . .
                                  plz chk.
                                  thanks for your advance tool . . . . 😄
                                  Thank you,
                                  SUmaster
                                    Ryucarlos
                                    esta merda não estar completo com,o o da video aula
                                    • E Offline
                                      Esense3d
                                      Hello
                                      The Newest German Translation
                                      Roland F. Swiss
                                      and Thank you very much
                                      German Files Feb 2015
                                        AcesHigh
                                        It simply doesn´t work for me in Sketchup 2015.
                                        nothing happens when I click the Show Tools Icon (the one with the magnifying glass).
                                        In fact, nothing happens when I click any icon, except the "Profile Schema" icon.
                                        ps: nothing changes if I use the "Change the Profiles List File" option in the extensions menu. I can choose the profiles file, but still no icon of the tools functions...
                                        edit: it worked on Sketchup 8, which I still have installed.
                                          cadmunkey
                                          run into a problem, not sure if its 2105 specific as I no longer have 14 and before installed.
                                          When I have the rotation set to default (0) the member follows the line path fine (on the left in the picture).
                                          On the right, I wanted the RHS to be rotated about 90 degrees, so typed '90' in the rotation box but when I apply it I get something more like 35 degrees. I've tried with different inputs but the output never corresponds to the angle I have chosen. Any ideas?
                                            cadmunkey
                                            No one come across this issue before?
                                            • 16
                                            • 17
                                            • 3 / 17
