    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
    • G
      goga63
      And again great work ! 👍 👍 👍
      Only after carrying over of function of editing of a profile directly in the table, the button "Profile Schema Edit" shows an empty window.
      Here new Russian translation to a plug-in.
      lang_ru.txt
      • C
        cadmunkey
        @tak2hata said:
        Hi,all.
        I update this to v2.2.0. in 2014.11.16.
        Apply IFC classification in sketchup2015.
        Genius! Thank you so much for this update 😄 👍
        • OxerO
          Oxer
          Thanks for the update, the Profile Schema Edit window doesn't open because in the line 545 of main.rb file the path isn't correct:
           line 548-> htmfile = File.join(File.dirname(__FILE__),'bst_profile_creator2.html')
          You need fix the path to:
           line 548-> htmfile = File.join(File.dirname(__FILE__),'bst_profile_creator.html')
          • C
            cadmunkey
            Strange, I'm using the new version and didn't have that issue Oxer.
            • T
              tak2hata
              Hi,All.
              I update this to v2.2.1. in 2014.11.22.
              Some bugs fixed.
              and Change the sample profile files to have no extension name.
              I found the point that oxer said.
              by TAK2HATA
              • OxerO
                Oxer
                Hi tak2hata,
                When I push Show tool icon it appears this warning window:
                I suppose this is because default_pflist.xml file isn't included with the plugin. When I install the file by myself in the sample_pflist folder and then I select it through Change Profile-List File, on OSX & SU2015 the Shapes and Multiple Wall are empty in Tool Options window:
                but in SU2014 the content of these folders appears.
                • T
                  tak2hata
                  Hi,oxer.
                  This did not include the default_pflist.xml file in older version,too.
                  Only "sample_pflist_jis_japan.tsv" and "sample_pflist_northAmerica.tsv" and "sample_pflist_UK_AC.tsv" were included.
                  Now "sample_pflist_jis_japan" and "sample_pflist_northAmeric" and "sample_pflist_UK_AC" are included.
                  So I think missing "default_pflist.xml" file is not caused to new version.
                  About Empty when select "MWall" and "Shapes",
                  Does the folders exist in your plguin folder?
                  by TAK2HATA
                  • OxerO
                    Oxer
                    Yes, the folders exist and they have content:
                    This happens in SU2015 only, in SU 2014 the content of the folders appear in the Tool Options window correctly.
                    • T
                      tak2hata
                      Hi,all
                      I update this to V2.2.4 in 2014-12-07.
                      Some bugfix and Improve the profile selector.and "Mwall" Work well on MacOSX.
                      Hi,Oxer.
                      Please try this version.
                      by TAK2HATA
                      • chialiang168C
                        chialiang168
                        https://dl.dropboxusercontent.com/u/108539326/001-Share/building_structure_tools/languages.JPG
                        Chinese and Taiwanese language files
                        中国と台湾の言語ファイル
                        中国と台湾の言語ファイル
                        • OxerO
                          Oxer
                          I installed the v2.2.4 and all work fine now on OS X 10.10.1 👍
                          Thanks tak2hata !!
                          • sumasterS
                            sumaster
                            Hello T2H Sir,
                            CHK web dialog box its working perfect but not working like your previous version.
                            Means when i draw wall and set parameters like wall height : 10' and width : 4" and start draw a wall and when i change the wall height : 2' and wall width : 1' and draw continue in view-port the tool not get new parameters . . . . . .
                            plz chk.
                            thanks for your advance tool . . . . 😄
                            Thank you,
                            SUmaster
                              Ryucarlos
                              esta merda não estar completo com,o o da video aula
                              • E
                                Esense3d
                                Hello
                                The Newest German Translation
                                Roland F. Swiss
                                and Thank you very much
                                German Files Feb 2015
                                  AcesHigh
                                  It simply doesn´t work for me in Sketchup 2015.
                                  nothing happens when I click the Show Tools Icon (the one with the magnifying glass).
                                  In fact, nothing happens when I click any icon, except the "Profile Schema" icon.
                                  ps: nothing changes if I use the "Change the Profiles List File" option in the extensions menu. I can choose the profiles file, but still no icon of the tools functions...
                                  edit: it worked on Sketchup 8, which I still have installed.
                                  • C
                                    cadmunkey
                                    run into a problem, not sure if its 2105 specific as I no longer have 14 and before installed.
                                    When I have the rotation set to default (0) the member follows the line path fine (on the left in the picture).
                                    On the right, I wanted the RHS to be rotated about 90 degrees, so typed '90' in the rotation box but when I apply it I get something more like 35 degrees. I've tried with different inputs but the output never corresponds to the angle I have chosen. Any ideas?
                                    • C
                                      cadmunkey
                                      No one come across this issue before?
                                        rodman100
                                        I noticed this happens in SU2015 also.
                                          driven
                                          I don't have it installed, but what happens if you enter radians?
                                          1.57079633
                                          • C
                                            cadmunkey
                                            1.57079633
                                            Great, that works! What's going on then?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
