    Texture orientation question
    9 Posts 5 Posters 306 Views 5 Watching
    • pmolsonP Offline
      pmolson
      Please see the images below.
      I am using the follow me tool to create a flared shingle detail above a stone cap. When the follow me path turns a corner the size and or orientation of the applied material changes. It also changes differently from one end to the other.(again please see images.)
      Anyone know Whats going on here and how I correct?
      Paul
      • TIGT Online
        Is the material applied onto a 'container' [group?] or onto the [sur]faces themselves ?
        • pmolsonP Offline
          pmolson
          tig, applied to the surface itself.
          • pmolsonP Offline
            pmolson
            So I kept messing around and achieved what i wanted, but it is a little fussy.
            Turns out that if I unsmooth the group so I see each segmnet line that makes up the curved surface, and then open the group, select one face, right click-texture-reset position , then use the material eye dropper to select the just reset material and then apply that material to each of the other segments of the curved surface, close group, soften group.
            Then the materials match as shown below.
            Easier way to do this?
            • pbacotP Offline
              My first reaction would be to use Thrupaint, but I think your method is the best native one.
              • N Offline
                numerobis
                no, this is how it works (without plugins).
                You can use a plugin like ThruPaint to do all faces at once http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=44552
                  KrisM
                  I am just now working on a project where I have created the exact same kind of flare out. Thru paint works perfectly for the texture.
                  • pmolsonP Offline
                    pmolson
                    thank you, going to get thrupaint now.
                    • pmolsonP Offline
                      pmolson
                      I did get thrupaint...havent quite got it mastered though. Need to read the instructions:)
                      Just for the heck of it, I tried using the followmeandkeep plugin even though it is a straight forward follow me situation and so far the materials are staying oriented correctly around corners...not sure why that would be, but it works.
                      p
