    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 454.4k Views 172 Watching
      Thanks Oxer.
      There are several recent posts about adding these new 'ivyleaf_' SKPs to your ../Plugins/LiveIvy/Textures folder...
      Clearly you might want to manage what you have loading from that folder, by 'disabling' some little-used or un-used SKPs...
      Regarding the ordering...
      The default ordering would be 1,10,11,2,3..9 etc
      I adjusted it to use 1,2,3..9,10,11 etc
      BUT having names like 13a, 13b etc currently confuses it as there is no inherent way to sort by the final 'suffix'...
      This can be done... I'll look at it... πŸ€“
      πŸ˜„
      • OxerO Offline
        Oxer
        Thanks for the info TIG!!
          Here's v0.6.6x which now sorts the 'ivy_leaf_' thumbnails logically, names with number+letter suffixes are sorted after any pure numerical suffixes http://sketchucation.com/pluginstore?pln=SketchupIvy
            Jorgensen
            Hi tig
            This is a very nice plugin, even though I have a problem.
            I have a wall, that is 20 meter high wall and 100 meters long, and somehow I need to green (not the right word I guess) whis wall.
            But I have a struggle to find the right settings. No matter what settings I use, it seems that I can't get the ivy higher than 4-5 meters before it gets to heavy / dence. Can anyone guide me here πŸ˜„
            If I can create some of the Ives I can use them as proxies in max / octane, but it might not be possible at all to create ivys this big?
            • KrisidiousK Offline
              Krisidious
              @jorgensen said:
              Hi tig
              You might want to look at my Green Wall thread. I don't know that this is what you want. Ivy is probably not for larger areas.
              404 Not Found
              (sketchucation.com)
              By: Kristoff Rand
                Jorgensen
                Thank kristoff
                I haven't thought of using make fur. I sure will try that out.
                  Krisidious
                  You can always ad ivy leaves into the grass proxies/comps. Make sure to post back and show us how it turns out.
                  By: Kristoff Rand
                    pankaj_tamore
                    Dear Mr.Pierreden,
                    Thank you very much for this incredibly magical plugin some i had in my mind for long time for making creeper in desired way but unfortunately i have encountered problem in using this plugin smoothly. please guide to fix the problem.problem i experienced i explained in attached PDF file please go through the same.
                    Thanks & regards
                    Pankaj T
                    IVY Problem report on 21.11.14.pdf
                      Krisidious
                      @pankaj_tamore said:
                      Dear Mr.Pierreden,
                      Thanks & regards
                      Pankaj T
                      Read this guide and see if that doesn't help you.
                      http://www.sketchup-house-plans.com/Live-Ivy-Settings-Guide.zip
                      By: Kristoff Rand
                        @kris
                        can we get this up as a tut on the site?
                        the file is a winner
                          Krisidious
                          Absolutely... How do you want it?
                          By: Kristoff Rand
                            however you want it to appear.
                            of course article will heavily incorporate schema tags and author info box for you so feel free to go wild
                              Krisidious
                              I don't know if I'm the author or not... I did a lot of testing and made some tuts for this plugin back in the day, but can't remember if I did this or if someone else gave it to me.
                              Regardless, it's a great resource and I'll bring it out of SU and put in a better format.
                              By: Kristoff Rand
                                Krisidious
                                Driven has pointed out to me that one of the textures on the file belongs to a "Gordon"... Anyone remember someone named Gordon?
                                Well, Gordon... Wherever you are... We'll credit you with this resource.
                                By: Kristoff Rand
                                  driven
                                  Search is a wonderful tool
                                  [anchor= goto=http://sketchucation.com/forums/viewtopic.php?f=323&t=36882&start=450#p460919:1fdzrjgt]Gordy_Z[/anchor:1fdzrjgt]
                                    [anchor= goto=http://sketchucation.com/forums/viewtopic.php?f=323&t=36882&start=450#p460919:26ycz78i]Gordy_Z[/anchor:26ycz78i]
                                    He's been inactive for the best part of two years ?
                                      Krisidious
                                      Because someone's name is Gordy they are the same Gordon we are looking for? Gordon is the name of the user on their computer... Don't know if it would be the user on the SCF board. Doesn't ring any bells for me. But, who knows... Could be him.
                                      I did a search on the 17-18 pages on this thread and didn't find any mention of a Gordon.
                                      By: Kristoff Rand
                                        Krisidious
                                        Rich, I sent all of those guide/experiments to you in a PM. You might want to hit them will spell check. and just use find/replace to change the directory for all the images.
                                        By: Kristoff Rand
                                          chris87
                                          Sketchup 8 pro error !!!
                                            ... and what happens when you click on 'continue' ?
                                            The sliders/ivyleaf icons depend on that lib...
                                            That js error is from one of the standard jquery code libraries - it's relating to 'msie'.
                                            What version of Internet Explorer do you have ?
                                            Try updating it...
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 36
                                            • 37
                                            • 30 / 37
