    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 545.1k Views 172 Watching
      No, i didn't overwrite. I binned those duds.
      I am using 2015 with the plugin.
      I am not using the cloud
      I emailed you the library
        driven
        here's what I see on mac after extracting and adding icons...2014-11-19 03.32.18 pm.png
          Well I saved them all as v8 SKPs and then they ALL add into the dialog as thumbnails in v8 to v2015 !
          The hidden-geom needs switching off in the SKP so the thumbnail is clean...
            ok, feel free to add them to the tool if you want
              I'll zip them and post it here asap...
                Here's Rich O'Brien's set of nine 'ivyleaf_' SKPs - all evergreen ivy leaves...
                They are in SUp v8 format, with the hidden-geometry OFF, so their thumbnails look better.
                You can either add those to your existing set in the ../Plugins/LiveIvy/Textures folder [they are named with a final 'ROB' so as not to clash], or of course you can remove any 'ivyleaf' SKPs you don't want to choose from - perhaps move them into a 'Disabled' subfolder...
                ivyleaf_ROB's.zip
                • OxerO
                  Oxer
                  Incredible new feature to select different leafs, thanks you very much TIG 😍 πŸ‘
                  With your permission TIG, I rebuild the leafs to decrease the leafs files size, only one or two planes for the leafs, I deleted the unnecessary edges. I made a new leafs with some skp files found in this topic, I made components for some parts of the leafs (minor file size) and I made new textures.
                  The new leafs are named like 11, 12, 13a, 13b, 13c, 14a and 14b, to the leafs 1 to 10 I made a cleaning only, all are saved in SU8 format.
                  The plugins works fine in SU2014/15 & OSX 10.9.5 only one problem with the leafs list alphabetic order, some leafs aren't ordered correctly, I marked the incorrect leaf, see the image below, I don't why.
                  New Leafs
                  New Leafs 1 to 10
                  New Leafs 11 to 14b
                  • pbacotP
                    Thanks Oxer and thanks Tig! Maybe time for me to try this again.
                      Thanks Oxer.
                      There are several recent posts about adding these new 'ivyleaf_' SKPs to your ../Plugins/LiveIvy/Textures folder...
                      Clearly you might want to manage what you have loading from that folder, by 'disabling' some little-used or un-used SKPs...
                      Regarding the ordering...
                      The default ordering would be 1,10,11,2,3..9 etc
                      I adjusted it to use 1,2,3..9,10,11 etc
                      BUT having names like 13a, 13b etc currently confuses it as there is no inherent way to sort by the final 'suffix'...
                      This can be done... I'll look at it... πŸ€“
                      πŸ˜„
                      • OxerO
                        Oxer
                        Thanks for the info TIG!!
                          Here's v0.6.6x which now sorts the 'ivy_leaf_' thumbnails logically, names with number+letter suffixes are sorted after any pure numerical suffixes http://sketchucation.com/pluginstore?pln=SketchupIvy
                            Jorgensen
                            Hi tig
                            This is a very nice plugin, even though I have a problem.
                            I have a wall, that is 20 meter high wall and 100 meters long, and somehow I need to green (not the right word I guess) whis wall.
                            But I have a struggle to find the right settings. No matter what settings I use, it seems that I can't get the ivy higher than 4-5 meters before it gets to heavy / dence. Can anyone guide me here πŸ˜„
                            If I can create some of the Ives I can use them as proxies in max / octane, but it might not be possible at all to create ivys this big?
                            • KrisidiousK
                              Krisidious
                              @jorgensen said:
                              Hi tig
                              You might want to look at my Green Wall thread. I don't know that this is what you want. Ivy is probably not for larger areas.
                              404 Not Found
                              (sketchucation.com)
                              By: Kristoff Rand
                                Jorgensen
                                Thank kristoff
                                I haven't thought of using make fur. I sure will try that out.
                                • KrisidiousK
                                  Krisidious
                                  You can always ad ivy leaves into the grass proxies/comps. Make sure to post back and show us how it turns out.
                                  By: Kristoff Rand
                                  • P
                                    pankaj_tamore
                                    Dear Mr.Pierreden,
                                    Thank you very much for this incredibly magical plugin some i had in my mind for long time for making creeper in desired way but unfortunately i have encountered problem in using this plugin smoothly. please guide to fix the problem.problem i experienced i explained in attached PDF file please go through the same.
                                    Thanks & regards
                                    Pankaj T
                                    IVY Problem report on 21.11.14.pdf
                                    • KrisidiousK
                                      Krisidious
                                      @pankaj_tamore said:
                                      Dear Mr.Pierreden,
                                      Thanks & regards
                                      Pankaj T
                                      Read this guide and see if that doesn't help you.
                                      http://www.sketchup-house-plans.com/Live-Ivy-Settings-Guide.zip
                                      By: Kristoff Rand
                                        @kris
                                        can we get this up as a tut on the site?
                                        the file is a winner
                                        • KrisidiousK
                                          Krisidious
                                          Absolutely... How do you want it?
                                          By: Kristoff Rand
                                            however you want it to appear.
                                            of course article will heavily incorporate schema tags and author info box for you so feel free to go wild
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 36
                                            • 37
                                            • 30 / 37
