    Re: [Plugin] Flatten to Plane v1.2 20101023
    77 Posts 27 Posters 93.0k Views 27 Watching
      mqt101
      Heloo, I can't seem to download this on my mac. Could someone help me please?
        Explain your problem better, and we might help sort something...
        Can't you see the download link?
        Can't you download the file?
        Can't you install it?
        Can't you find the tool when it is installed?
        Can't you use the tool when you find it?
        etc
        etc...
          schaferron1
          have installed this plugin through sketchucation plugin store, says installed, does not show up in tools, plugins anywhere. I have restarted sketchup 2013 3 times.
          Thanks! πŸ˜„
          R
            Is there a folder permissions issue? Make sure you have full permissions set for the Plugins folder. Did you also install workplane.rb?
            • T
              Tseifert
              Is Flatten extension updated for SU 2014? I used it in SU8. Now I can't seem to load it onto SU2014 for use.
              Thank you,
                It works just fine in SU2014. How are did you install it? Did you also install the required WorkPlane as indicated in the first post of this thread?
                • T
                  Tseifert
                  Dave R, I installed it through Smustard. I do not believe I downloaded the workplane rd plugin.
                  Can I still do this?
                  Thank you.
                    You should be installing the curent version of the plugin as well as WorkPlane through the Sketchucation Plugin Store. That way you can be assured of getting the most recent version. And it isn't too late to install WorkPlane.
                      Thank you.
                      My current script should only be available through the PluginStore ??
                      So something is adrift...... πŸ˜•
                      • T
                        Tseifert
                        Thank you for your replies to this. I noticed that the 2014 version already comes with a flatten option in the right click, 'flatten faces' this is all I really need. Thought it would be nice to take a 3D component from warehouse such as a plant, flatten it on the red or green axis so I can use it in 'Top' camera view, so I can use it like a plant symbol in site plan. I have noticed Sketchup and layout has limited 2D flat plant symbols I can use for Landscape Design.
                        Thanks,
                        • L
                          LillianBorges
                          Thank you so much! I'm an art student, and my specialty is traditional 2D media, but I need to model an object for a required 3D design course. My line work was going everywhere; I couldn't get the lines to all stay in the same plane at all! This was a lifesaver for someone who isn't used to 3D modeling programs.
                          • I
                            ittayd
                            Trying to use the plugin, I select a work plane and a group and click flatten to plane and I get:
                            Error: #<NoMethodError: undefined method transformation' for #<Sketchup::ComponentDefinition:0x0000004f028fb0>> C:/Users/idror/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/#FlattenToPlane.rb:93:in activate'
                            C:/Users/idror/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/#FlattenToPlane.rb:186:in select_tool' C:/Users/idror/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/#FlattenToPlane.rb:186:in flattentoplane'
                            C:/Users/idror/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/#FlattenToPlane.rb:192:in block in <top (required)>' SketchUp:1:in call'
                            When I load a simple model everything works
                              I'll add to the list of things to look at...
                              It is almost 7 years old !
                              Did you get/install the latest RBZ from the PluginStore ?
                              • I
                                ittayd
                                I used the sketchucation plugin to install
                                  johnwmcc
                                  I have a model of a rotating plate with simple pivots and cranks. I've simplified it a bit, manually, into three different planes, and can if necessary use that.
                                  But I wanted to flatten it completely, and tried this plugin for the first time, installed, along with Workplane.rb, today via the Sketchucation plugin.
                                  Here's an image of the simple three-plane model, with pivot pins in 3D.
                                  Original model
                                  Here's the result of running Flatten to Plane:
                                  The elements have all got misaligned.
                                  Here's the simple model itself:
                                  Simple Model
                                  And here's what I tried originally while it was part of a more complex model:
                                  Original model
                                  Is this a bug in the plugin used in SU 2017?
                                  When I first tried the plugin on the original component inside a more complex model, I got only an empty group returned.
                                  Is there a workaround? Would it work if I use it in an earlier version of SU make? I have different ones back to SU8 M2.
                                  Seems like a very useful plugin, and I for one would be happy to see it working again, if it does have problems in SU 2017. I'm using it on iMac 5K 27" with AMD Radeon R9 M395 2048 MB graphics.
                                  [EDIT}
                                  I did eventually get the original 3D model to flatten, but it too moved the pieces around relative to each other, including rotating the original round plate back to its original location, rotated back 165 degrees, and way off centre.
                                    This tool is 7 years old.
                                    It was reported a few weeks ago that it had issues with v2017.
                                    It's already on the list of things to fix for v2017 compatibility over the next few weeks...
                                    Thanks for the examples and info - I can use those in my testing...
                                    • P
                                      pritam8888
                                      as soon as I installed workplane.rbz my sketchup 2017 crashed.? Had to manually remove it for skp to run. what could be the prob?
                                      • P
                                        pritam8888
                                        Oh
                                        • W
                                          Whitewave
                                          Hi.
                                          Anyone done any work on this yet?
                                          It's May 2021.
                                          I just got this pop up on my brand new subscription to SU Pro 2021:
                                          Error Loading File #FlattenToPlane.rb
                                          Error: #<LoadError: cannot load such file -- #WorkPlane.rb>
                                          C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require'
                                          C:/Users/jenni/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/#FlattenToPlane.rb:51:in `<top (required)>'
                                          This plugin would be super useful to me.
                                          But, if your life has taken a different turn, I understand.
                                          Bless you and have a good one.
                                          ~Ww
                                            It has had issues with some newer SketchUp versions, but...
                                            If you read the details in detail...
                                            'Flatten to Plane' needs you to have WorkPlane.rb installed and then a WorkPlane defined - that is how the Flatten tool knows where it is to flatten to...
                                            However, then its functionality is not guaranteed...
                                            • 4 / 4
