    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    335 Posts 107 Posters 467.9k Views 107 Watching
      cadmunkey
      Using the new SHAPE class, does the ALIGN function not work with this? No matter how I draw my shape it draws it with a justification of bottom right. Any workaround?
        tak2hata
        Hi,ALL.
        I update this to v2.1.0 in 2014.11.01.
        Some Improves.
        Hi,Cadmunkey.
        "SHAPE" class not support ALIGN option.
        I will consider the method for Align of "SHAPE" in future.
        Thanks.
        by TAK2HATA
          cadmunkey
          @tak2hata said:
          Hi,ALL.
          Some Improves.
          Hi,Cadmunkey.
          Thanks.
          OK, thanks for considering it. Such a great plugin I couldn't live without now 😉
          • facerF Offline
            facer
            T2H,
            Great plugin, keep up the good work!
            V2.1.0 - Question ??
            I am using Skp 2014, W7, 32bit
            1. I note that I can only get the "Draw by click" to work in the SMALL - simple window of
              the Toggle_UI. I find in the SMALL UI it is hard to read the data due to the small text size.
              The LARGER UI is easier for me to read. Can this be achieved?
            2. Is the new STEEL BEAM (ref attachment) data saved for latter use?
              I can not find my new STEEL BEAM in the data.
            Thanks again,
            Ray
            UB207x134 data input
              cadmunkey
              @facer said:
              1. Is the new STEEL BEAM (ref attachment) data saved for latter use?
              Thanks again,
              Ray
              Did you create that in the table editor? If so it seems to shift newly created elements to the bottom of your lists, not in order of actual section size.
                tak2hata
                Hi,all.
                I update this to v2.2.0. in 2014.11.16.
                Apply IFC classification in sketchup2015.
                by TAK2HATA
                  goga63
                  And again great work ! 👍 👍 👍
                  Only after carrying over of function of editing of a profile directly in the table, the button "Profile Schema Edit" shows an empty window.
                  Here new Russian translation to a plug-in.
                  lang_ru.txt
                    cadmunkey
                    @tak2hata said:
                    Hi,all.
                    Genius! Thank you so much for this update 😄 👍
                    • OxerO Offline
                      Oxer
                      Thanks for the update, the Profile Schema Edit window doesn't open because in the line 545 of main.rb file the path isn't correct:
                       line 548-> htmfile = File.join(File.dirname(__FILE__),'bst_profile_creator2.html')
                      You need fix the path to:
                       line 548-> htmfile = File.join(File.dirname(__FILE__),'bst_profile_creator.html')
                        cadmunkey
                        Strange, I'm using the new version and didn't have that issue Oxer.
                          tak2hata
                          Hi,All.
                          I update this to v2.2.1. in 2014.11.22.
                          Some bugs fixed.
                          and Change the sample profile files to have no extension name.
                          I found the point that oxer said.
                          by TAK2HATA
                          • OxerO Offline
                            Oxer
                            Hi tak2hata,
                            When I push Show tool icon it appears this warning window:
                            I suppose this is because default_pflist.xml file isn't included with the plugin. When I install the file by myself in the sample_pflist folder and then I select it through Change Profile-List File, on OSX & SU2015 the Shapes and Multiple Wall are empty in Tool Options window:
                            but in SU2014 the content of these folders appears.
                              tak2hata
                              Hi,oxer.
                              This did not include the default_pflist.xml file in older version,too.
                              Only "sample_pflist_jis_japan.tsv" and "sample_pflist_northAmerica.tsv" and "sample_pflist_UK_AC.tsv" were included.
                              Now "sample_pflist_jis_japan" and "sample_pflist_northAmeric" and "sample_pflist_UK_AC" are included.
                              So I think missing "default_pflist.xml" file is not caused to new version.
                              About Empty when select "MWall" and "Shapes",
                              Does the folders exist in your plguin folder?
                              by TAK2HATA
                              • OxerO Offline
                                Oxer
                                Yes, the folders exist and they have content:
                                This happens in SU2015 only, in SU 2014 the content of the folders appear in the Tool Options window correctly.
                                  tak2hata
                                  Hi,all
                                  I update this to V2.2.4 in 2014-12-07.
                                  Some bugfix and Improve the profile selector.and "Mwall" Work well on MacOSX.
                                  Hi,Oxer.
                                  Please try this version.
                                  by TAK2HATA
                                  • chialiang168C Offline
                                    chialiang168
                                    https://dl.dropboxusercontent.com/u/108539326/001-Share/building_structure_tools/languages.JPG
                                    Chinese and Taiwanese language files
                                    中国と台湾の言語ファイル
                                    中国と台湾の言語ファイル
                                    • OxerO Offline
                                      Oxer
                                      I installed the v2.2.4 and all work fine now on OS X 10.10.1 👍
                                      Thanks tak2hata !!
                                      • sumasterS Offline
                                        sumaster
                                        Hello T2H Sir,
                                        CHK web dialog box its working perfect but not working like your previous version.
                                        Means when i draw wall and set parameters like wall height : 10' and width : 4" and start draw a wall and when i change the wall height : 2' and wall width : 1' and draw continue in view-port the tool not get new parameters . . . . . .
                                        plz chk.
                                        thanks for your advance tool . . . . 😄
                                        Thank you,
                                        SUmaster
                                          Ryucarlos
                                          esta merda não estar completo com,o o da video aula
                                          • E Offline
                                            Esense3d
                                            Hello
                                            The Newest German Translation
                                            Roland F. Swiss
                                            and Thank you very much
                                            German Files Feb 2015
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
