    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 313.4k Views 172 Watching
      Did you read the usage guidance ?
      Did you remove the ../Plugins/LiveIvy/Textures folder and then install the toolset ??
      It loads ALL of the SKPs it has found in the ../Plugins/LiveIvy/Textures folder...
      BUT ONLY IF they are named 'ivyleaf_.skp', where the '' can be any text you like, but to keep things ordered I recommend a numerical part.
      If you have other SKP names these are ignored, and NOT loaded...
      So rename them and restart the tool's dialog...
      The thumbnails are made from the loaded SKPs.
      It comes with 10 as the default set, others can be added into the folder as desired...
      The initial default Leaf Type has NO ivyleaf_ thumbnail selected - so initially branches would be bare.
      However, you can choose any number of available components you wish - all 10 if you want !
      Click a thumbnail to select and highlight it 'blue', or click again to de-select it...
      The last used 'set' of selected ivyleaf_ components is re-selected when the dialog opens, this is remembered across sessions.
      Also ensure that the new custom ivyleaf_ SKP is properly purged, and has no guides or section planes in it: they are best with transparent PNG texture and simple outline hidden edges around the leaf's face...
      Also setup the default view so the SKP's thumbnail looks good...
      • Rich O BrienR Online
        Yes, I did re-read...
        Here's my textures folder saved as v2015 .skp
          it loads 3 only
            So you have overwritten the default set of SKPs. πŸ˜’
            If you saved them as v2015 SKPs, then they'll only load into v2015, that's why I recommended they were saved as v8 in the guidance, then they load in all versions of SketchUp...
            Are you using the tool on sketchUcloud or a shared Plugins folder? - if so, then earlier versions of SketchUp will be messed up and only load SKP versions <= their version.
            It loads all available SKPs named 'ivyleaf_*', so maybe only 3 are suitable versions in that SketchUp ?
            Can you give me your set of 9 SKPs so I can look at them...
              No, i didn't overwrite. I binned those duds.
              I am using 2015 with the plugin.
              I am not using the cloud
              I emailed you the library
                driven
                here's what I see on mac after extracting and adding icons...2014-11-19 03.32.18 pm.png
                  Well I saved them all as v8 SKPs and then they ALL add into the dialog as thumbnails in v8 to v2015 !
                  The hidden-geom needs switching off in the SKP so the thumbnail is clean...
                    ok, feel free to add them to the tool if you want
                      I'll zip them and post it here asap...
                        Here's Rich O'Brien's set of nine 'ivyleaf_' SKPs - all evergreen ivy leaves...
                        They are in SUp v8 format, with the hidden-geometry OFF, so their thumbnails look better.
                        You can either add those to your existing set in the ../Plugins/LiveIvy/Textures folder [they are named with a final 'ROB' so as not to clash], or of course you can remove any 'ivyleaf' SKPs you don't want to choose from - perhaps move them into a 'Disabled' subfolder...
                        ivyleaf_ROB's.zip
                        • OxerO Offline
                          Oxer
                          Incredible new feature to select different leafs, thanks you very much TIG 😍 πŸ‘
                          With your permission TIG, I rebuild the leafs to decrease the leafs files size, only one or two planes for the leafs, I deleted the unnecessary edges. I made a new leafs with some skp files found in this topic, I made components for some parts of the leafs (minor file size) and I made new textures.
                          The new leafs are named like 11, 12, 13a, 13b, 13c, 14a and 14b, to the leafs 1 to 10 I made a cleaning only, all are saved in SU8 format.
                          The plugins works fine in SU2014/15 & OSX 10.9.5 only one problem with the leafs list alphabetic order, some leafs aren't ordered correctly, I marked the incorrect leaf, see the image below, I don't why.
                          New Leafs
                          New Leafs 1 to 10
                          New Leafs 11 to 14b
                          • pbacotP Offline
                            Thanks Oxer and thanks Tig! Maybe time for me to try this again.
                              Thanks Oxer.
                              There are several recent posts about adding these new 'ivyleaf_' SKPs to your ../Plugins/LiveIvy/Textures folder...
                              Clearly you might want to manage what you have loading from that folder, by 'disabling' some little-used or un-used SKPs...
                              Regarding the ordering...
                              The default ordering would be 1,10,11,2,3..9 etc
                              I adjusted it to use 1,2,3..9,10,11 etc
                              BUT having names like 13a, 13b etc currently confuses it as there is no inherent way to sort by the final 'suffix'...
                              This can be done... I'll look at it... πŸ€“
                              πŸ˜„
                              • OxerO Offline
                                Oxer
                                Thanks for the info TIG!!
                                  Here's v0.6.6x which now sorts the 'ivy_leaf_' thumbnails logically, names with number+letter suffixes are sorted after any pure numerical suffixes http://sketchucation.com/pluginstore?pln=SketchupIvy
                                    Jorgensen
                                    Hi tig
                                    This is a very nice plugin, even though I have a problem.
                                    I have a wall, that is 20 meter high wall and 100 meters long, and somehow I need to green (not the right word I guess) whis wall.
                                    But I have a struggle to find the right settings. No matter what settings I use, it seems that I can't get the ivy higher than 4-5 meters before it gets to heavy / dence. Can anyone guide me here πŸ˜„
                                    If I can create some of the Ives I can use them as proxies in max / octane, but it might not be possible at all to create ivys this big?
                                    • KrisidiousK Offline
                                      Krisidious
                                      @jorgensen said:
                                      Hi tig
                                      You might want to look at my Green Wall thread. I don't know that this is what you want. Ivy is probably not for larger areas.
                                      http://sketchucation.com/forums/viewtopic.php?f=40%26amp;t=59390
                                      By: Kristoff Rand
                                        Jorgensen
                                        Thank kristoff
                                        I haven't thought of using make fur. I sure will try that out.
                                          Krisidious
                                          You can always ad ivy leaves into the grass proxies/comps. Make sure to post back and show us how it turns out.
                                          By: Kristoff Rand
                                            pankaj_tamore
                                            Dear Mr.Pierreden,
                                            Thank you very much for this incredibly magical plugin some i had in my mind for long time for making creeper in desired way but unfortunately i have encountered problem in using this plugin smoothly. please guide to fix the problem.problem i experienced i explained in attached PDF file please go through the same.
                                            Thanks & regards
                                            Pankaj T
                                            IVY Problem report on 21.11.14.pdf
                                            • 11
                                            • 12
                                            • 13
                                            • 36
                                            • 37
                                            • 11 / 37
