    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 128.3k Views 84 Watching
      acatalyst
      @gábor said:
      The current version of the plugin has no log out feature. I'll PM you a method what will let you to log in with an other account.
      i actually figured it out. thank you.
      i wish there was a "logout feature"
      • shake1S Offline
        shake1
        @gábor said:
        @shake1: PM was sent to you.
        I'm sorry I can not answer in a personal, if you do not mind I'll answer here
        @gábor said:
        I have some questions regarding your error. Please answer them to let us find the reason:
        Did you have the same problem with the previous (v.2.6.0) version of the plugin?
        Do you have this unzip issue only with one specific plugin file or installing any plugin throws this error?
        What happens when you download the .rbz file and manually install it at Preferences/Install Extension?
        • version 2.6.0 had the same problem
        • this error when installing/updating any plug
        • each file is installed successfully from Preferences/Install Extension
        AND... if you have the Ruby Console open, are there any messages ?
        Also, if you download some RBZ files can you auto-install using SketchUcation / Install Archive... submenu item ?
        • Ruby console does not display any messages
        • from SketchUcation / Install Archive... installed without problems
          Gábor
          Collecting the good ideas for the next release. Log out feature is one of them. 😄
            Gábor
            @shake1: Thank you for the answers. We are looking for the possible cause. Will let you know if we have any other questions or if we have the fix for it.
            • shake1S Offline
              shake1
              Hi! Solved my problem - in the name of the computer was Cyrillic. Renamed to letters and began working plugin. Thank you guys, I'm happy again!
                Maybe we need to look at encoding/decoding the user's computer-name to avoid this [it's needed for the 'Bundles' feature]...
                • Z Offline
                  zhenning
                  I just updated to sketchucation 2.6.1. Some errors appears when loading sketchup:
                  Error: #<LoadError: 127: The specified procedure could not be found. - C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/platform_specific/zlib.so>
                  C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                  c:/users/toshiba/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/scf-rbztools.rbs:185:in <module:RBZtool>' c:/users/toshiba/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/scf-rbztools.rbs:157:in <main>'
                  C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:28:in eval' C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:28:in load'
                  C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:28:in block in <top (required)>' C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:17:in each'
                  C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:17:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                  C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:191:in register_extension'
                  C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:191:in <module:SCF>' C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:16:in <top (required)>'
                  Error Loading File examples/exampleScripts.rb
                  Could not find included file 'examples/exampleScripts.rb'
                  Error Loading File ocean/ocean.rb
                  Could not find included file 'ocean/ocean.rb'
                  Anyone can help? Thanks in advance.
                    This a strange and rare problem, which is actually unrelated to the toolset itself, but rather to your 'system' files.
                    I personally discovered it when v2014 was released, but at that time I seemed to be the only person who could create the issue.
                    The 'zlib.so' and its related 'zlib1.dll' are shipped with Ruby2 and should simply load when needed by any Ruby tools doing 'zip/unzip' processes...
                    However, if the zlib has already been loaded 'universally' from another source, AND that zlib version is somehow significantly different, then it causes the Ruby2 one to have issues and so it fails to load.
                    I discovered that several programs come with zlib etc as part of their toolset, but these are located in the app's own folder and load as they need.
                    However, some old program seems to have once upon a time put its copy of zlib into a system folder [perhaps InkScape?] - this means it loads as your PC starts up, AND unfortunately that zlib version also had some silly changes incorporated into it, which breaks the standard zlib processes used by all others programs...
                    So to fix it...
                    Find the rogue zlib* file[s] and remove it/them.
                    Look in your C:\Windows, C:\Windows\System32\ and C:\Windows\SysWOW64\ folders... there should be NO 'zlib' files in these folders.
                    [Other 'zlib' files supplied within other app's own subfolders should not present an issue]
                    Restart your PC.
                    You should find that the v2014 Ruby2 zlib.so version is now properly loaded and so works !
                    This will mean that SketchUcation Toolset v2.6.1, AND any other tools using zlib's zip/unzip functions should now work correctly !
                    • Z Offline
                      zhenning
                      Nice. That did the trick. My zlibs are in Windows/ and SysWOW64\ . Thanks!
                        bimbachi
                        I have two problems 😞
                        1./ my plugin don't show (anymore) updates for my plugin instaled.
                        I noticed it for those of fredo6.
                        I'm on mac osx 10.10.1 and skp8
                        2./ skp window toolbar dose not retain tool icons setup after next skp start
                        can somen advice on those ?
                        thanks
                          Gábor
                          thanks
                          Which version of the plugin are you using?
                            bimbachi
                            @Gábor
                            2.6.1
                            @gábor said:
                              Have you changed your SketchUcation user-name ?
                              It will only remember what you have downloaded per user-name...
                                bimbachi
                                No
                                Same user name
                                Mac os system upgraded to Yosemite
                                  Yosemite has some incompatibilities up to v2014 - v2015 seems stable - so unfortunately v8 is likely to be flaky using that OS ! You are FOUR SketchUp version behind... so you can't expect full compatibility with the latest OS ??
                                    bimbachi
                                    Same was with previous os version.
                                    As far skp version i tested 2015 and deleted because of plenty unstability 😄
                                    Personaly, since trimble I see no real progres off skp 😞
                                      Jim
                                      I have an unpublished extension (cli-select) which shows up when I did a search for "ruby"
                                      I doubt unpublished extensions were meant to be listed. Thanks for looking into this.
                                        @Jim
                                        You are right that unpublished plugins should not be listed in a search. 😕
                                        Indeed if you search for "cli-select" or list by author "Jim" it returns nothing.
                                        So it's somehow still including the unpublished item's description/usage text when it's searching, because "things", "Ruby" and "Ruby Console" all return a hit on your unpublished entry.
                                        I see that this only occurs in the Sketchup based web-dialog - the PluginStore web-site search works as expected and never returns matches in unpublished entries.
                                        So I suspect that Gábor uses to similar but different search code setups...
                                        I've PM'd him this post and hopefully he'll be able to see the issue and fix it.
                                        It's already working web-site side, and partially server-side for the web-dialog - so it seems quite doable 😮
                                          Gábor
                                          Now it is corrected in versions 2.6.1 and 2.6.2[beta]. Thank you for notifying us about the problem.
                                          Also thanks to TIG for notifying me by PM as I was away from the forums for a few days.
                                          • josephkim626J Offline
                                            josephkim626
                                            now its been updated to 3.0! some glitches tho.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 19
                                            • 20
                                            • 13 / 20
