    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 264.1k Views 84 Watching
      matt.gordon320
      I wanted to see if I could also request that the version compatibility be put in at a glance if possible from the main store window. It shows downloads, and sometimes usage, but it'd be nice to show compatibility too for installing across multiple versions.
      • G
        Gábor
        @shake1: PM was sent to you.
        @matt.gordon320: Thank you for the good ideas. You might see these features in the 3.0 version coming soon. 😄
          acatalyst
          how do yo log out of the plugin in SketchUp? I need to change user accounts
          • G
            Gábor
            The current version of the plugin has no log out feature. I'll PM you a method what will let you to log in with an other account.
              acatalyst
              i actually figured it out. thank you.
              i wish there was a "logout feature"
              • shake1S
                shake1
                I'm sorry I can not answer in a personal, if you do not mind I'll answer here
                @gábor said:
                I have some questions regarding your error. Please answer them to let us find the reason:
                Did you have the same problem with the previous (v.2.6.0) version of the plugin?
                Do you have this unzip issue only with one specific plugin file or installing any plugin throws this error?
                What happens when you download the .rbz file and manually install it at Preferences/Install Extension?
                • version 2.6.0 had the same problem
                • this error when installing/updating any plug
                • each file is installed successfully from Preferences/Install Extension
                AND... if you have the Ruby Console open, are there any messages ?
                Also, if you download some RBZ files can you auto-install using SketchUcation / Install Archive... submenu item ?
                • Ruby console does not display any messages
                • from SketchUcation / Install Archive... installed without problems
                • G
                  Gábor
                  Collecting the good ideas for the next release. Log out feature is one of them. 😄
                  • G
                    Gábor
                    @shake1: Thank you for the answers. We are looking for the possible cause. Will let you know if we have any other questions or if we have the fix for it.
                    • shake1S
                      shake1
                      Hi! Solved my problem - in the name of the computer was Cyrillic. Renamed to letters and began working plugin. Thank you guys, I'm happy again!
                        Maybe we need to look at encoding/decoding the user's computer-name to avoid this [it's needed for the 'Bundles' feature]...
                        • Z
                          zhenning
                          I just updated to sketchucation 2.6.1. Some errors appears when loading sketchup:
                          Error: #<LoadError: 127: The specified procedure could not be found. - C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/platform_specific/zlib.so>
                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                          c:/users/toshiba/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/scf-rbztools.rbs:185:in <module:RBZtool>' c:/users/toshiba/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/scf-rbztools.rbs:157:in <main>'
                          C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:28:in eval' C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:28:in load'
                          C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:28:in block in <top (required)>' C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:17:in each'
                          C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:17:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:191:in register_extension'
                          C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:191:in <module:SCF>' C:/Users/Toshiba/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:16:in <top (required)>'
                          Error Loading File examples/exampleScripts.rb
                          Could not find included file 'examples/exampleScripts.rb'
                          Error Loading File ocean/ocean.rb
                          Could not find included file 'ocean/ocean.rb'
                          Anyone can help? Thanks in advance.
                            This a strange and rare problem, which is actually unrelated to the toolset itself, but rather to your 'system' files.
                            I personally discovered it when v2014 was released, but at that time I seemed to be the only person who could create the issue.
                            The 'zlib.so' and its related 'zlib1.dll' are shipped with Ruby2 and should simply load when needed by any Ruby tools doing 'zip/unzip' processes...
                            However, if the zlib has already been loaded 'universally' from another source, AND that zlib version is somehow significantly different, then it causes the Ruby2 one to have issues and so it fails to load.
                            I discovered that several programs come with zlib etc as part of their toolset, but these are located in the app's own folder and load as they need.
                            However, some old program seems to have once upon a time put its copy of zlib into a system folder [perhaps InkScape?] - this means it loads as your PC starts up, AND unfortunately that zlib version also had some silly changes incorporated into it, which breaks the standard zlib processes used by all others programs...
                            So to fix it...
                            Find the rogue zlib* file[s] and remove it/them.
                            Look in your C:\Windows, C:\Windows\System32\ and C:\Windows\SysWOW64\ folders... there should be NO 'zlib' files in these folders.
                            [Other 'zlib' files supplied within other app's own subfolders should not present an issue]
                            Restart your PC.
                            You should find that the v2014 Ruby2 zlib.so version is now properly loaded and so works !
                            This will mean that SketchUcation Toolset v2.6.1, AND any other tools using zlib's zip/unzip functions should now work correctly !
                            • Z
                              zhenning
                              Nice. That did the trick. My zlibs are in Windows/ and SysWOW64\ . Thanks!
                              • B
                                bimbachi
                                I have two problems 😞
                                1./ my plugin don't show (anymore) updates for my plugin instaled.
                                I noticed it for those of fredo6.
                                I'm on mac osx 10.10.1 and skp8
                                2./ skp window toolbar dose not retain tool icons setup after next skp start
                                can somen advice on those ?
                                thanks
                                • G
                                  Gábor
                                  thanks
                                  Which version of the plugin are you using?
                                  • B
                                    bimbachi
                                    @Gábor
                                    2.6.1
                                    @gábor said:
                                      Have you changed your SketchUcation user-name ?
                                      It will only remember what you have downloaded per user-name...
                                      • B
                                        bimbachi
                                        No
                                        Same user name
                                        Mac os system upgraded to Yosemite
                                          Yosemite has some incompatibilities up to v2014 - v2015 seems stable - so unfortunately v8 is likely to be flaky using that OS ! You are FOUR SketchUp version behind... so you can't expect full compatibility with the latest OS ??
                                          • B
                                            bimbachi
                                            Same was with previous os version.
                                            As far skp version i tested 2015 and deleted because of plenty unstability 😄
                                            Personaly, since trimble I see no real progres off skp 😞
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 19
                                            • 20
                                            • 12 / 20
