    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 264.1k Views 84 Watching
      This a strange and rare problem, which is actually unrelated to the toolset itself, but rather to your 'system' files.
      I personally discovered it when v2014 was released, but at that time I seemed to be the only person who could create the issue.
      The 'zlib.so' and its related 'zlib1.dll' are shipped with Ruby2 and should simply load when needed by any Ruby tools doing 'zip/unzip' processes...
      However, if the zlib has already been loaded 'universally' from another source, AND that zlib version is somehow significantly different, then it causes the Ruby2 one to have issues and so it fails to load.
      I discovered that several programs come with zlib etc as part of their toolset, but these are located in the app's own folder and load as they need.
      However, some old program seems to have once upon a time put its copy of zlib into a system folder [perhaps InkScape?] - this means it loads as your PC starts up, AND unfortunately that zlib version also had some silly changes incorporated into it, which breaks the standard zlib processes used by all others programs...
      So to fix it...
      Find the rogue zlib* file[s] and remove it/them.
      Look in your C:\Windows, C:\Windows\System32\ and C:\Windows\SysWOW64\ folders... there should be NO 'zlib' files in these folders.
      [Other 'zlib' files supplied within other app's own subfolders should not present an issue]
      Restart your PC.
      You should find that the v2014 Ruby2 zlib.so version is now properly loaded and so works !
      This will mean that SketchUcation Toolset v2.6.1, AND any other tools using zlib's zip/unzip functions should now work correctly !
      • Z
        zhenning
        Nice. That did the trick. My zlibs are in Windows/ and SysWOW64\ . Thanks!
        • B
          bimbachi
          I have two problems 😞
          1./ my plugin don't show (anymore) updates for my plugin instaled.
          I noticed it for those of fredo6.
          I'm on mac osx 10.10.1 and skp8
          2./ skp window toolbar dose not retain tool icons setup after next skp start
          can somen advice on those ?
          thanks
          • G
            GĂĄbor
            thanks
            Which version of the plugin are you using?
            • B
              bimbachi
              @GĂĄbor
              2.6.1
              @gĂĄbor said:
                Have you changed your SketchUcation user-name ?
                It will only remember what you have downloaded per user-name...
                • B
                  bimbachi
                  No
                  Same user name
                  Mac os system upgraded to Yosemite
                    Yosemite has some incompatibilities up to v2014 - v2015 seems stable - so unfortunately v8 is likely to be flaky using that OS ! You are FOUR SketchUp version behind... so you can't expect full compatibility with the latest OS ??
                    • B
                      bimbachi
                      Same was with previous os version.
                      As far skp version i tested 2015 and deleted because of plenty unstability 😄
                      Personaly, since trimble I see no real progres off skp 😞
                        Jim
                        I have an unpublished extension (cli-select) which shows up when I did a search for "ruby"
                        I doubt unpublished extensions were meant to be listed. Thanks for looking into this.
                          @Jim
                          You are right that unpublished plugins should not be listed in a search. 😕
                          Indeed if you search for "cli-select" or list by author "Jim" it returns nothing.
                          So it's somehow still including the unpublished item's description/usage text when it's searching, because "things", "Ruby" and "Ruby Console" all return a hit on your unpublished entry.
                          I see that this only occurs in the Sketchup based web-dialog - the PluginStore web-site search works as expected and never returns matches in unpublished entries.
                          So I suspect that GĂĄbor uses to similar but different search code setups...
                          I've PM'd him this post and hopefully he'll be able to see the issue and fix it.
                          It's already working web-site side, and partially server-side for the web-dialog - so it seems quite doable 😮
                          • G
                            GĂĄbor
                            Now it is corrected in versions 2.6.1 and 2.6.2[beta]. Thank you for notifying us about the problem.
                            Also thanks to TIG for notifying me by PM as I was away from the forums for a few days.
                            • josephkim626J
                              josephkim626
                              now its been updated to 3.0! some glitches tho.
                              • dereiD
                                derei
                                Neat update this version 3... but I'm wondering who is making such a big effort to make this tool WORSE than better?
                                Why worse?
                                1. Now the plugins have NO information about them Except the name. There is a fancy heart and a big download button.
                                  What the hell am I downloading? What that extension does? Can't find that anymore...
                                2. Bundles STILL CAN'T BE DELETED - but yey, we have a new interface. Why was that needed anyway? The previous one had much more USEFUL information.
                                3. Now the window has two "dead" areas - status bars, whatever:
                                  -The top one where is ONLY one settings button (yup, that's it... the rest is just white space)
                                  -The bottom one with filters, favorites, search, logoff.
                                  Does this app comes with FREE BIGGER DISPLAYS ? Because I can't afford bigger one right now.
                                4. There is no button to send me to plugin's page (either on the forum or on author's website)
                                5. There is no button to UNINSTALL a installed plugin/extension. It wasn't before, but as you still install a feature on user's computer why can't you make the things easier instead of more complicated? If I install it from there, why can't I UNINSTALL it from the same place?
                                And again: still can't delete bundles... but I can clone them. Wow, such feature. So useless (if I can't delete).
                                Now, I apologize for being so sarcastic (but I'm not sorry). I was expecting much more from some people with so much experience in making plugins, interfaces, user-friendly menus, etc. So, all my sarcasm came from this huge disappointment. Is like you take Ergonomics lessons from Google (yeah, they love to mess-up with everything that works).
                                EDIT: another "fancy feature" is that fade when doing any command... like a cheap action movie. And NO setting to control the fade duration or just to cut it off.
                                the new and so much useless V3
                                DESIGNER AND ARTIST DEREI.UK
                                  Live with it for a few days. Really test it out and let us know the features you'd like and not like.
                                  Click things. Explore it. Break it.
                                  • robertWanR
                                    robertWan
                                    It work with SU8 (Win XP)?
                                    Robert
                                      I didn't test it. But your operating system is 12years old so backward compatibility is harder and harder to do.
                                      Sent from my iPhone using Tapatalk
                                      • irwanwrI
                                        irwanwr
                                        Got this pop-up message every time SketchUp 8 starting lately
                                        Is there something can be done about it?
                                          As far as I know after the proper installation of the plugin's latest RBZ you will be reminded to restart - just ONCE.
                                          This is irrespective of the SketchUp version...
                                          After that it should be re-installed properly and not need to remind you.
                                          Did you install using Preferences > Extensions > Install Extension... ?
                                          Do you have FULL [read/write] Security permissions set under the Plugins folder's Properties ?
                                          Before v2014 these permissions could be flaky - then the user's Plugins folder was relocated...
                                          Version 8 is no longer supported by Trimble, v2013 will be deprecated soon...
                                          Why not upgrade your SketchUp [and perhaps Windows version?] ?
                                          • irwanwrI
                                            irwanwr
                                            Yes, using Preferences > Extension > Install Extension
                                            Still it keep popping up every time SketchUp 8 starting.
                                            Ah yes, just changed the properties. It seems it's Read Only here.
                                            Thank you very much. Hope it would work normally updated afterwards. 😄
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 19
                                            • 20
                                            • 13 / 20
