    [Plugin] Components manager plugin
    156 Posts 15 Posters 71.6k Views 15 Watching
    • inteloideI
      inteloide
      Hello, Could you please be more precise ?
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
      • P
        Pherim
        Hey, the new version 2.0 always asks on startup if I want to use my system's language (German), which I don't, and it says in the window that there is a new version available although I have the latest, and then the custom toolbars I built with Toolbar Editor don't load anymore. Last but not least, it doesn't overwrite the old version but that still remains installed and usable, apparently.
        Right now I can't use this in its current version with these issues.
        • inteloideI
          inteloide
          Hello Pherim,
          Sorry that this version doesn't worked as required for you. I'll try to correct this asap.
          • always asks on startup if I want to use my system's language
            That's strange : do you have a file BGSketchup_Components_manager.ini in your plugin folder ?
          • it says in the window that there is a new version available although I have the latest :
            It should be solved now
          • then the custom toolbars I built with Toolbar Editor don't load anymore.
            I tested on my computer, on SU 2014 and 2015 : it works perfectly...
          • it doesn't overwrite the old version but that still remains installed and usable, apparently :
            Yes, I forgot to tell that previous version should be removed...
          Please keep me informed.
          Best regards
          Inteloide
          • inteloideI
            inteloide
            Well, I correct some little things :
              Actually, on SU2014, after some use the icon disappeared... On SU2015 it's ok. Also I noticed that due to language change issue, the icon disappear from Toolbar editor because button name is translated in your language. So, when bug for language will be solved, your toolbar will remains.
            Inteloide
            • P
              Pherim
              About the toolbars: It's not like they don't work at all, but they are not loaded properly, some are missing a few symbols, others are missing all of them. When I disable this plugin with Sketchucation Plugin manager, they work again.
              Oh, and yeah, it's SU 2015.
              No, I don't.
              • inteloideI
                inteloide
                Hello Pherim,
                Thank you for your explainations.
                About toolbar editor, I'll contact plugin author to try understand where the issue comes.
                About translation issue, if you don't have the ini file, this means that your options are not solved.
                Could you make a search for file BGSketchup_Composants.ini (sorry I made a mistake in previous file name) ?
                You may find this file in root folder of plugins files : C:\Users*Pherim*\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
                Or in :
                C:\Users*Pherim*\AppData\Local\Temp
                If this file doesn't exist, this means that Sketchup don't have permission to modify this folder.
                If this file exists, please send it to me (after you change your translation option and close Sketchup).
                Thank you
                Regards
                Inteloide
                • P
                  Pherim
                  Alright, I do have this ini. I deleted it before because I thought it belonged to the old version, as you gave me the wrong file name before. When I reactivated the plugin and saved the settings, a new ini was generated, but I had the same issue as before. Then I tried changing the language and then everything worked, the toolbars were loading again, as well. After changing the language back to English, everything still works as it should!
                  Maybe there is something wrong with the initial creation of the ini, but changing the language back and forth seems to help.
                  • inteloideI
                    inteloide
                    Ok Pherim, thank you for this information.
                    These troubles come from plugin name which was a mix between French and English, therefore I changed it to full English...
                    That's why you had to delete previous version, and that's why ini file name was with old name (this is still an issue, but if no other users claim, I'll won't change it to avoid anymore issue).
                    In any case, I hope you will continue to use my plugins ;o)
                    Inteloide
                    • P
                      Pherim
                      I'm afraid it causes crashes again when I use RoundCorner inside Components.
                      • inteloideI
                        inteloide
                        You're right !
                        I get where the issue comes from. Next version will correct it.
                        Inteloide
                        • inteloideI
                          inteloide
                          just posted ;o)
                          • P
                            Pherim
                            It works again, thanks!
                            • P
                              Pherim
                              It did work on my desktop PC when I wrote the last reply, but since then I was not at home and got a new laptop in the meantime on which also I use SU2015 64bit now, and again it crashes for me when RoundCorner is used inside components. Installed everything with the Plugin Store.
                              • HumpmetwiceH
                                Humpmetwice
                                Could someone tell me whats going wrong? Great plugin by the way!!
                                Thanks Kurt
                                  Have you also installed the author's 'Library' and restarted SketchUp ?
                                  http://sketchucation.com/pluginstore?pauthor=inteloide
                                  It is clearly explained in the plugin's download entry:
                                  http://sketchucation.com/pluginstore?pln=Composants
                                  • HumpmetwiceH
                                    Humpmetwice
                                    I've downloaded all updated plugins plus the library and still get the same message.
                                    windows 7 and sketchup 2013.
                                    Thanks Kurt
                                      Have you tried a PM or email direct to the author ?
                                      • L
                                        LawArchitects
                                        Is this plugin dead? Is there another xref management option?
                                        • 8 / 8
