    [Plugin] Components manager plugin
    156 Posts 15 Posters 55.7k Views 15 Watching
    • inteloideI Offline
      inteloide
      Ok Pherim, thank you for this information.
      These troubles come from plugin name which was a mix between French and English, therefore I changed it to full English...
      That's why you had to delete previous version, and that's why ini file name was with old name (this is still an issue, but if no other users claim, I'll won't change it to avoid anymore issue).
      In any case, I hope you will continue to use my plugins ;o)
      Inteloide
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
        Pherim
        I'm afraid it causes crashes again when I use RoundCorner inside Components.
          inteloide
          You're right !
          I get where the issue comes from. Next version will correct it.
          Inteloide
            inteloide
            just posted ;o)
              Pherim
              It works again, thanks!
                Pherim
                It did work on my desktop PC when I wrote the last reply, but since then I was not at home and got a new laptop in the meantime on which also I use SU2015 64bit now, and again it crashes for me when RoundCorner is used inside components. Installed everything with the Plugin Store.
                • HumpmetwiceH Offline
                  Humpmetwice
                  Could someone tell me whats going wrong? Great plugin by the way!!
                  Thanks Kurt
                    Have you also installed the author's 'Library' and restarted SketchUp ?
                    http://sketchucation.com/pluginstore?pauthor=inteloide
                    It is clearly explained in the plugin's download entry:
                    http://sketchucation.com/pluginstore?pln=Composants
                      Humpmetwice
                      I've downloaded all updated plugins plus the library and still get the same message.
                      windows 7 and sketchup 2013.
                      Thanks Kurt
                        Have you tried a PM or email direct to the author ?
                          LawArchitects
                          Is this plugin dead? Is there another xref management option?
                          • 8 / 8
