    [Plugin] Components manager plugin
    156 Posts 15 Posters 71.6k Views 15 Watching
    • inteloideI
      inteloide
      Hello,
      To Oxer : Next plugin version will integrate a Library presence control, with prompt if not present and an alert if an update of the plugin is available...
      To TIG : Thank you for your support ;o)
      To flyer50 : I've seen your mail, I'll work on your issue. Thank you for your work on Italian translation (rb file received) Please send me your file in html, I will create the pdf file.
      Inteloide
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
      • OxerO
        Oxer
        Thanks for the info inteloide, I have installed BGSketchup_Library file and the plugin works fine now on SU2014 & SU2015.
          arquiman5000
          64bit problem, please update...
          • inteloideI
            inteloide
            Hello, Could you please be more precise ?
            • P
              Pherim
              Hey, the new version 2.0 always asks on startup if I want to use my system's language (German), which I don't, and it says in the window that there is a new version available although I have the latest, and then the custom toolbars I built with Toolbar Editor don't load anymore. Last but not least, it doesn't overwrite the old version but that still remains installed and usable, apparently.
              Right now I can't use this in its current version with these issues.
              • inteloideI
                inteloide
                Hello Pherim,
                Sorry that this version doesn't worked as required for you. I'll try to correct this asap.
                • always asks on startup if I want to use my system's language
                  That's strange : do you have a file BGSketchup_Components_manager.ini in your plugin folder ?
                • it says in the window that there is a new version available although I have the latest :
                  It should be solved now
                • then the custom toolbars I built with Toolbar Editor don't load anymore.
                  I tested on my computer, on SU 2014 and 2015 : it works perfectly...
                • it doesn't overwrite the old version but that still remains installed and usable, apparently :
                  Yes, I forgot to tell that previous version should be removed...
                Please keep me informed.
                Best regards
                Inteloide
                • inteloideI
                  inteloide
                  Well, I correct some little things :
                    Actually, on SU2014, after some use the icon disappeared... On SU2015 it's ok. Also I noticed that due to language change issue, the icon disappear from Toolbar editor because button name is translated in your language. So, when bug for language will be solved, your toolbar will remains.
                  Inteloide
                  • P
                    Pherim
                    About the toolbars: It's not like they don't work at all, but they are not loaded properly, some are missing a few symbols, others are missing all of them. When I disable this plugin with Sketchucation Plugin manager, they work again.
                    Oh, and yeah, it's SU 2015.
                    No, I don't.
                    • inteloideI
                      inteloide
                      Hello Pherim,
                      Thank you for your explainations.
                      About toolbar editor, I'll contact plugin author to try understand where the issue comes.
                      About translation issue, if you don't have the ini file, this means that your options are not solved.
                      Could you make a search for file BGSketchup_Composants.ini (sorry I made a mistake in previous file name) ?
                      You may find this file in root folder of plugins files : C:\Users*Pherim*\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
                      Or in :
                      C:\Users*Pherim*\AppData\Local\Temp
                      If this file doesn't exist, this means that Sketchup don't have permission to modify this folder.
                      If this file exists, please send it to me (after you change your translation option and close Sketchup).
                      Thank you
                      Regards
                      Inteloide
                      • P
                        Pherim
                        Alright, I do have this ini. I deleted it before because I thought it belonged to the old version, as you gave me the wrong file name before. When I reactivated the plugin and saved the settings, a new ini was generated, but I had the same issue as before. Then I tried changing the language and then everything worked, the toolbars were loading again, as well. After changing the language back to English, everything still works as it should!
                        Maybe there is something wrong with the initial creation of the ini, but changing the language back and forth seems to help.
                        • inteloideI
                          inteloide
                          Ok Pherim, thank you for this information.
                          These troubles come from plugin name which was a mix between French and English, therefore I changed it to full English...
                          That's why you had to delete previous version, and that's why ini file name was with old name (this is still an issue, but if no other users claim, I'll won't change it to avoid anymore issue).
                          In any case, I hope you will continue to use my plugins ;o)
                          Inteloide
                          • P
                            Pherim
                            I'm afraid it causes crashes again when I use RoundCorner inside Components.
                            • inteloideI
                              inteloide
                              You're right !
                              I get where the issue comes from. Next version will correct it.
                              Inteloide
                              • inteloideI
                                inteloide
                                just posted ;o)
                                • P
                                  Pherim
                                  It works again, thanks!
                                  • P
                                    Pherim
                                    It did work on my desktop PC when I wrote the last reply, but since then I was not at home and got a new laptop in the meantime on which also I use SU2015 64bit now, and again it crashes for me when RoundCorner is used inside components. Installed everything with the Plugin Store.
                                    • HumpmetwiceH
                                      Humpmetwice
                                      Could someone tell me whats going wrong? Great plugin by the way!!
                                      Thanks Kurt
                                        Have you also installed the author's 'Library' and restarted SketchUp ?
                                        http://sketchucation.com/pluginstore?pauthor=inteloide
                                        It is clearly explained in the plugin's download entry:
                                        http://sketchucation.com/pluginstore?pln=Composants
                                        • HumpmetwiceH
                                          Humpmetwice
                                          I've downloaded all updated plugins plus the library and still get the same message.
                                          windows 7 and sketchup 2013.
                                          Thanks Kurt
                                            Have you tried a PM or email direct to the author ?
                                            • 8 / 8
