    [Plugin] Components manager plugin
    156 Posts 15 Posters 54.1k Views 15 Watching
    • inteloideI Offline
      inteloide
      Hello Pherim,
      Please try version 1.14.10 which should solve your issue and let me know.
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
        Pherim
        Alright, it works again! Thanks!
        • OxerO Offline
          Oxer
          I have installed the v1.14.10 on Mac OS X & SU2015 Make and it appears a Load Errors window with this message:
          Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb Error: #<LoadError: cannot load such file -- BGSketchup/BGSketchup.rb> /Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:45:inrequire'
          /Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:45:in require' /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:13:in module:BGSketchup_Composants'
          /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:5:in <top (required)>' /Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in require'
          /Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in load' /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BGSketchup_Composants.rb:232:in register_extension'
          /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BGSketchup_Composants.rb:232:in <top (required)>'
            Have you also installed his necessary 'Lib' ?
            http://sketchucation.com/pluginstore?pln=BGSketchup_Library
            • OxerO Offline
              Oxer
              No, I haven't installed it, I 'll try to install it.
              Thanks TIG for the info!
              • flyer50F Offline
                flyer50
                HI
                I downloaded the file manager component for sketchup ver 1.14.8
                I use Win 8 Pro 64bit and SU 8 pro
                During the installation I always get the following three errors.
                line 38 char 2 permission denied
                file:///D:/programmi/Sketchup/Plugins/BGSketchup/JQUERY/jquery-1.10.2.js
                line 19 char 1 permission denied
                file:///D:/programmi/Sketchup/Plugins/BGSketchup/JQUERY/jquery.contextmenu.r2.js
                line 193 char 3 Property or method not supported by the object
                file:///D:/programmi/Sketchup/Plugins/BGSketchup/Composants/Html/treeview.html
                how can I solve this problem?
                the program seems to work with many problems but working and is fantastic
                I have uploaded the localisation file adding the italian version.
                I have translated the help file too but I can't manage pdf file and I have transformed the 7 pdf pages in 7 single pages in html format .
                Now I have the 7 page in html and transalted in italian language.
                how can I trasform it in one only pdf file?
                ciao
                • flyer50F Offline
                  flyer50
                  sorry something went wrong
                  this is the file
                  localisation with italian version added
                    inteloide
                    Hello,
                    To Oxer : Next plugin version will integrate a Library presence control, with prompt if not present and an alert if an update of the plugin is available...
                    To TIG : Thank you for your support ;o)
                    To flyer50 : I've seen your mail, I'll work on your issue. Thank you for your work on Italian translation (rb file received) Please send me your file in html, I will create the pdf file.
                    Inteloide
                    • OxerO Offline
                      Oxer
                      Thanks for the info inteloide, I have installed BGSketchup_Library file and the plugin works fine now on SU2014 & SU2015.
                        arquiman5000
                        64bit problem, please update...
                          inteloide
                          Hello, Could you please be more precise ?
                            Pherim
                            Hey, the new version 2.0 always asks on startup if I want to use my system's language (German), which I don't, and it says in the window that there is a new version available although I have the latest, and then the custom toolbars I built with Toolbar Editor don't load anymore. Last but not least, it doesn't overwrite the old version but that still remains installed and usable, apparently.
                            Right now I can't use this in its current version with these issues.
                              inteloide
                              Hello Pherim,
                              Sorry that this version doesn't worked as required for you. I'll try to correct this asap.
                              • always asks on startup if I want to use my system's language
                                That's strange : do you have a file BGSketchup_Components_manager.ini in your plugin folder ?
                              • it says in the window that there is a new version available although I have the latest :
                                It should be solved now
                              • then the custom toolbars I built with Toolbar Editor don't load anymore.
                                I tested on my computer, on SU 2014 and 2015 : it works perfectly...
                              • it doesn't overwrite the old version but that still remains installed and usable, apparently :
                                Yes, I forgot to tell that previous version should be removed...
                              Please keep me informed.
                              Best regards
                              Inteloide
                                inteloide
                                Well, I correct some little things :
                                  Actually, on SU2014, after some use the icon disappeared... On SU2015 it's ok. Also I noticed that due to language change issue, the icon disappear from Toolbar editor because button name is translated in your language. So, when bug for language will be solved, your toolbar will remains.
                                Inteloide
                                  Pherim
                                  About the toolbars: It's not like they don't work at all, but they are not loaded properly, some are missing a few symbols, others are missing all of them. When I disable this plugin with Sketchucation Plugin manager, they work again.
                                  Oh, and yeah, it's SU 2015.
                                  No, I don't.
                                    inteloide
                                    Hello Pherim,
                                    Thank you for your explainations.
                                    About toolbar editor, I'll contact plugin author to try understand where the issue comes.
                                    About translation issue, if you don't have the ini file, this means that your options are not solved.
                                    Could you make a search for file BGSketchup_Composants.ini (sorry I made a mistake in previous file name) ?
                                    You may find this file in root folder of plugins files : C:\Users*Pherim*\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
                                    Or in :
                                    C:\Users*Pherim*\AppData\Local\Temp
                                    If this file doesn't exist, this means that Sketchup don't have permission to modify this folder.
                                    If this file exists, please send it to me (after you change your translation option and close Sketchup).
                                    Thank you
                                    Regards
                                    Inteloide
                                      Pherim
                                      Alright, I do have this ini. I deleted it before because I thought it belonged to the old version, as you gave me the wrong file name before. When I reactivated the plugin and saved the settings, a new ini was generated, but I had the same issue as before. Then I tried changing the language and then everything worked, the toolbars were loading again, as well. After changing the language back to English, everything still works as it should!
                                      Maybe there is something wrong with the initial creation of the ini, but changing the language back and forth seems to help.
                                        inteloide
                                        Ok Pherim, thank you for this information.
                                        These troubles come from plugin name which was a mix between French and English, therefore I changed it to full English...
                                        That's why you had to delete previous version, and that's why ini file name was with old name (this is still an issue, but if no other users claim, I'll won't change it to avoid anymore issue).
                                        In any case, I hope you will continue to use my plugins ;o)
                                        Inteloide
                                          Pherim
                                          I'm afraid it causes crashes again when I use RoundCorner inside Components.
                                            inteloide
                                            You're right !
                                            I get where the issue comes from. Next version will correct it.
                                            Inteloide
                                            • 7 / 8
