    2015 crashing windows explorer
    37 Posts 13 Posters 14.4k Views 13 Watching
    • FrederikF
      Frederik
      Strange...
      I haven't experienced a single crash with SU2015 64-bit...
      What OS do you have??
      What IE version do you have??
      Can you replicate it easily??
      If yes, please write the steps that cause the crash...
      Cheers
      Kim Frederik
      • BoxB
        It sounds like it could be a graphics card issue.
        I remember some time back there was an issue with thumbnails causing explorer crashes.
        Try looking for ThumbsUp.dll in the sketchup directory at C:\Program Files\SketchUp\SketchUp 2015 and renaming it to OldThumbsUp.dllx so that it wont be recognised and see if that fixes the problem. You might need to reboot.
        If it doesn't work change the name back before you forget.
        • sketch3d.deS
          sketch3d.de
          @gmthompson said:
          Dell optiplex780
          do you use a nVidia Quadro video card?
          • GMthompsonG
            GMthompson
            @sketch3d.de said:
            @gmthompson said:
            Dell optiplex780
            sure enough Quadro NVS 420
            you can learn something everyday by paying attention
            • GMthompsonG
              GMthompson
              sounds like a shot ....i actually read this elsewhere this morning
                rv1974
                WE (W7 64bit, GTX video card) keeps crashing constantly.
                What saddens me even more is SU'15 killed XnView thumbnails.
                Tried the Box's recipe with DLL trick- it did not help. πŸ˜’
                • jo-keJ
                  jo-ke
                  I have the same problem since installing SU2015 on three different PCs. All are WIN7...
                  http://www.zz7.de
                  • bazB
                    baz
                    I have a brand new install of win 7 64 bit. Explorer crashes randomly on selecting a SU file. And even the task manager has trouble getting out of it. And no thumbs, of course.
                    NVIDIA GeForce GTX 770
                    • jo-keJ
                      jo-ke
                      Seems to be a known problem:
                      Site Not Found - Discourse
                      (forums.sketchup.com)
                      I've got three different machines with different installations and grafic cards but all are WIN 7 64 bit
                      I hope there is a solution soon.
                      http://www.zz7.de
                      • GMthompsonG
                        GMthompson
                        renaming thumbsup fixed the problem
                        • jo-keJ
                          jo-ke
                          Ok, i will have a look and try to do that...
                          http://www.zz7.de
                          • BoxB
                            Also uptick Redefine thumbnail on save in model info.
                            • jo-keJ
                              jo-ke
                              renaming the dll didn't help.
                              What else can I do?
                              http://www.zz7.de
                                rv1974
                                disable two Thumbsup.dll files (one in SU root, 2nd- in the LO directory). and restart, of course.
                                it'd 'fix' for sure.
                                • jo-keJ
                                  jo-ke
                                  I've found this one:
                                  where's the another one?
                                  Edit:
                                  Ah, you meant Layout... found it!
                                  Thank you
                                  http://www.zz7.de
                                  • BoxB
                                    @jo-ke said:
                                    Edit:
                                    Thank you
                                    Did it fix your problem?
                                    If so,
                                    Does this mean disabling the two ThumbsUp.dll is the right thing to suggest to people with Explorer Crashes?
                                    • jo-keJ
                                      jo-ke
                                      I don't have thumbnails anymore... 😞
                                      This is really a bad suggestion!
                                      I need thumbnails, bcause I have thousands of models and I don't know each name of it.
                                      Is this really the solution of that problem?
                                      http://www.zz7.de
                                        rv1974
                                        After disabling those Thumsups XnView still display skps nicely (+and supports drag'n'drop).
                                        • BoxB
                                          I'm not suggesting that it is a solution. There is obviously a problem and disabling the thumbnails has been suggested as a workaround to stop explorer crashing. If that is the case then it helps to work out where the bug is.
                                          So the question still remains, did disabling those two files, while rendering the thumbnails unviewable, stop the Explorer Crashing issue in your system?
                                          • Jean-FrancoJ
                                            Jean-Franco
                                            same situation as described by Baz.
                                            Jean-Franco
