    2015 crashing windows explorer
    37 Posts 13 Posters 13.4k Views 13 Watching
    • GMthompsonG Offline
      GMthompson
      I have been having an issue of windows explorer crashing whenever i open a file,
      the files are previous files made from 2014
      My machine Specs are
      Dell optiplex780
      Intel 2 Q9650 @ 3.00GHZ
      64 bit
      No rants just throwing it out there
      you can learn something everyday by paying attention
      • FrederikF Offline
        Frederik
        Strange...
        I haven't experienced a single crash with SU2015 64-bit...
        What OS do you have??
        What IE version do you have??
        Can you replicate it easily??
        If yes, please write the steps that cause the crash...
        Cheers
        Kim Frederik
        • BoxB Offline
          It sounds like it could be a graphics card issue.
          I remember some time back there was an issue with thumbnails causing explorer crashes.
          Try looking for ThumbsUp.dll in the sketchup directory at C:\Program Files\SketchUp\SketchUp 2015 and renaming it to OldThumbsUp.dllx so that it wont be recognised and see if that fixes the problem. You might need to reboot.
          If it doesn't work change the name back before you forget.
          • sketch3d.deS Offline
            sketch3d.de
            @gmthompson said:
            Dell optiplex780
            do you use a nVidia Quadro video card?
              GMthompson
              @sketch3d.de said:
              @gmthompson said:
              Dell optiplex780
              sure enough Quadro NVS 420
                GMthompson
                sounds like a shot ....i actually read this elsewhere this morning
                  rv1974
                  WE (W7 64bit, GTX video card) keeps crashing constantly.
                  What saddens me even more is SU'15 killed XnView thumbnails.
                  Tried the Box's recipe with DLL trick- it did not help. ๐Ÿ˜’
                  • jo-keJ Offline
                    jo-ke
                    I have the same problem since installing SU2015 on three different PCs. All are WIN7...
                    http://www.zz7.de
                    • bazB Offline
                      baz
                      I have a brand new install of win 7 64 bit. Explorer crashes randomly on selecting a SU file. And even the task manager has trouble getting out of it. And no thumbs, of course.
                      NVIDIA GeForce GTX 770
                      • jo-keJ Offline
                        jo-ke
                        Seems to be a known problem:
                        Sketchup 2015 Install crashes Windows Explorer
                        Iโ€™ve had at least 6 SU crashes over the last two days (since installing). Iโ€™m also getting Windows Explorer crashes when I try to delete a SU file. Seems like a Windows Shell violation - the Explorer crash goes away whโ€ฆ
                        SketchUp Community (forums.sketchup.com)
                        I've got three different machines with different installations and grafic cards but all are WIN 7 64 bit
                        I hope there is a solution soon.
                        http://www.zz7.de
                          GMthompson
                          renaming thumbsup fixed the problem
                          • jo-keJ Offline
                            jo-ke
                            Ok, i will have a look and try to do that...
                            http://www.zz7.de
                            • BoxB Offline
                              Also uptick Redefine thumbnail on save in model info.
                              • jo-keJ Offline
                                jo-ke
                                renaming the dll didn't help.
                                What else can I do?
                                http://www.zz7.de
                                  rv1974
                                  disable two Thumbsup.dll files (one in SU root, 2nd- in the LO directory). and restart, of course.
                                  it'd 'fix' for sure.
                                  • jo-keJ Offline
                                    jo-ke
                                    I've found this one:
                                    where's the another one?
                                    Edit:
                                    Ah, you meant Layout... found it!
                                    Thank you
                                    http://www.zz7.de
                                    • BoxB Offline
                                      @jo-ke said:
                                      Edit:
                                      Thank you
                                      Did it fix your problem?
                                      If so,
                                      Does this mean disabling the two ThumbsUp.dll is the right thing to suggest to people with Explorer Crashes?
                                      • jo-keJ Offline
                                        jo-ke
                                        I don't have thumbnails anymore... ๐Ÿ˜ž
                                        This is really a bad suggestion!
                                        I need thumbnails, bcause I have thousands of models and I don't know each name of it.
                                        Is this really the solution of that problem?
                                        http://www.zz7.de
                                          rv1974
                                          After disabling those Thumsups XnView still display skps nicely (+and supports drag'n'drop).
                                          • BoxB Offline
                                            I'm not suggesting that it is a solution. There is obviously a problem and disabling the thumbnails has been suggested as a workaround to stop explorer crashing. If that is the case then it helps to work out where the bug is.
                                            So the question still remains, did disabling those two files, while rendering the thumbnails unviewable, stop the Explorer Crashing issue in your system?
