    [Plugin] SketchUcation Tools 2.6.1
    127 Posts 32 Posters 103.8k Views 32 Watching
      leminilab
      It's a bundle I created of my installed plugins in SU8.
      • "Live every day as if it were your last and then some day you'll be right."
      • "ThomThom rules!!!"
      • BoxB Offline
        I don't have my pc here to check but I think you won't have a bundle if you haven't used the tool to install any plugins. So on a new install you would download the su8 bundle and that would become the current 2015 bundle until you edit or add to it.
          I guess you are expecting to see 'Bundle' named 'LEMINLAB-PROD-15' ?
          Have you tried restarting SketchUp ?
          In v2015 what does you're 'My Installs' tab show ?
          If it's empty there is no Bundle.
          Try installing a Plugins and re-check the 'My Installs' and the 'Bundles'...
          If no joy can you try copy+paste this snippet into the Ruby Console + <enter>
          puts;puts(SCF_Dialog.getMyPlugins.split('|').join("\n"))
          This will tell us what is getting sent to the server...
          It ought to star with your Computer-Name:SketchUp-Version
          Then a list of available installed v2015 Plugins in order [both enabled and disabled]...
          If still no joy then we need to get GΓ‘bor onto it server-side...
            leminilab
            • Yes
            • It's empty 😞
            • When I try to Autoinstall a plug-in (like extrude tools for example ;p), nothing happens on screen.
            • I got this:
              Error: #<SyntaxError: <main>: syntax error, unexpected tIDENTIFIER, expecting end-of-input
              SketchUp:1:in `eval'
            • How bad is it, doc? πŸ˜„
            P.S.: I love this "Great!!! All of your plugins are up to date." message! πŸ˜„
              We might be able to save you πŸ˜‰
              More diagnosis needed...
              Can you open Internet Explorer, ensure its version is up to date, then empty its cache.
              Now restart SketchUp and retry the SketchUcation PluginStore dialog - any luck AutoInstalling something ?
              Can you use the item under the menu Plugins [now renamed Extensions in v2015] > SketchUcation submenu item to 'Open Plugins Folder'.
              It should open something like:
              C:\Users\YOUR_USER_NAME\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
              Are there any files in it ?
              If you go up one folder to .../SketchUp and use Properties > Security > Edit does every entry listed have FULL read/write/modify permissions setup?
              Change them if necessary, apply/OK...
              Try AutoInstalling again...
              Also open the SketchUcation > Plugins Manager dialog.
              Is the folder listed in the top-bar ?
              Are there any contents ?
              Report back πŸ€“
                leminilab
                Report back πŸ€“
                • Cache emptied. Not working.
                • All permissions granted. Not working.
                • I can't open the Plugins Manager.
                  πŸ˜•
                  Can you tell us what your Users user-name is ?
                  Next...
                  Find the SketchUp.exe icon in the 2015 Programs folder.
                  Change its Properties > Compatibility > Run As Administrator... to ON [tick]... OK.
                  Try again...
                    leminilab
                    Next...
                    Try again...
                    • My user name is leminilab:
                    • Changed compatibility to run as Admin.
                      I now get a message from Windows when I launch Make 2015 ("Do you want the following program to allow changes to this computer?").
                      But it's still not working. 😒
                      That last part sounds like a Filewall issue.
                      Make sure SketchUp 2015 is set to allow it to make changes and access the Internet...
                      Can you download an RBZ from the PluginStore page - linked above.
                      Then install it using the Preferences > Extensions > Install button in v2015.
                      Does its file[s] appear in the Users Plugins folder.
                      Does it then appear in the Plugins Manager and My-Installs ?
                      This is weird... πŸ˜•
                        leminilab
                        I enabled Sketchup in Windows Firewall.
                        The "More infoΓ© and "Donate" buttons work. But Autoinstall doesn't.
                        The install tab is blank.
                        • FrederikF Offline
                          Frederik
                          Donate a little and see if that fixes it... πŸ˜†
                          Cheers
                          Kim Frederik
                            You have a 'Download' button in the page - I did NOT mean the dialog [which has the AutoInstall button]...
                            Or is something blocking your browser and its ability to access the Internet and 'Download' files too - are you using Internet Explorer to access sketchUcation.com ?
                            It's also affecting the PluginStore downloads and the related download and AutoInstall via the dialog within SketchUp, which uses Internet Explorer [incidentally, what version do you use?].
                            Try and reset your IE Internet Options to use the default settings, perhaps they are too strict ?
                            Have you also emptied the IE cache as I suggested previously...
                              leminilab
                              πŸ˜†
                              I did download the .rbz and installed it from the Window/Preferences/Extensions Menu.
                              I'm using Firefox but the plugin seems to be able to connect to internet because I can see the list of plugins when I click the Sketchucation Plugin Store button.
                              IE version is 11.0.9600.17358. I did empty the cache.
                              I really don't think it's a browser-related issue: it works fine with my SU 8 version. πŸ˜•
                              I really don't want this to take too much energy from anyone: I can still install my plugins manually! πŸ˜„
                                The dialog can receive data from the server, but downloading the file seems to be the issue [which then fails to AutoLoad through the dialog].
                                If you try the AutoLoad download with the Ruby Console open are there any error messages.
                                You ought to get some useful error-dialogs but maybe the unforeseen peculiar set of circumstances is not calling those...
                                Can you also try this in the Ruby Console [copy/paste+<enter>] - it will open the temporary destination folder for the downloaded RBZ file...
                                UI.openURL("file:///#{SCF::TEMPDIR}")
                                It should open the temp folder, pathed something like:
                                C:/Users/Leminlab/AppData/Local/Temp/SCF
                                Try to AutoInstall a Plugin from the dialog.
                                If that folder shows no RBZ being added to it [perhaps very briefly], then the download is failing.
                                But if it shows an RBZ arriving [even fleetingly] then the installer is failing to process the RBZ.
                                If it leaves an RBZ in that folder... then can you rename it with a .ZIP suffix and try opening it - are its contents OK, or is it 'corrupted' ?
                                  leminilab
                                  Here's the Ruby Console message when I try an Autoinstall:
                                  Error: #<NoMethodError: undefined method downcase' for nil:NilClass> c:/users/leminilab/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:442:in block in custom_plugins'
                                  c:/users/leminilab/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:439:in each' c:/users/leminilab/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:439:in custom_plugins'
                                  c:/users/leminilab/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:461:in autoinstall_dlg' c:/users/leminilab/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:405:in set_autoinstall_choice'
                                  c:/users/leminilab/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:73:in block in new' SketchUp:1:in call'
                                  No rbz downloaded in the C:\Users\leminilab\AppData\Local\Temp\SCF folder.
                                    That error report is very helpful.
                                    It is failing on this:
                                    pd = Sketchup.find_support_file("Plugins")
                                    Can you then try this:
                                    pd.downcase
                                    Can you try it in the Ruby Console a report back...
                                    It seems strange that your SketchUp cannot find your Plugins folder ?
                                      leminilab
                                      pd.downcase
                                      C:/Users/leminilab/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins
                                      pd.downcase
                                      I should have mentioned I have created a symbolic link for C:\Program Files\SketchUp\SketchUp 2015\Tools pointing to a folder on another hard drive. I thougt this Tools folder was containing the rubies. Could this be the cause of all this?
                                        leminilab
                                        Yep, the symbolic link was the cause! I deleted it, repaired the installation and it's working now!
                                        Sorry for the trouble...
                                        But making a symbolic link from C:\Users\leminilab\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins to another location doesn't work anymore though...
                                        Thanks a lot TIG!
                                          Aaargh!
                                          The SketchUp/Tools folder just comes with a few files that SketchUp needs by default.
                                          It should never contain your own files.
                                          It also has limited permissions by default.
                                          Your User's Plugins folder [in the AppData path] is where all Plugin files are installed by default.
                                          Your symbolic link messing on might have messed up something...
                                          If you have messed around with the folders, then little wonder that SketchUp can't find it in the SCF dialog code... πŸ˜’
                                          Although weirdly using the snippet in the Console seemed to work as expected.
                                          In the rbs code it's 'Nil' so it fails...
                                          Is your User's Plugins folder an ordinary folder or a 'link' ?
                                            leminilab
                                            @tig said:
                                            Aaargh!
                                            I tried both: ordinary folder works, symbolic link doesn't.
                                            • 2 / 7
