    [Plugin] SketchUcation Tools 2.6.1
    127 Posts 32 Posters 103.8k Views 32 Watching
    • erkanE Offline
      erkan
      @tig said:
      It looks like one of your IT guys "is protecting you from yourself".
      You need FULL read/write/modify permissions to your User's Plugins folder, AND these must also apply to the folder's contents.
      I suspect that there is some subtle limiter set up by them [perhaps under 'Advanced' ?] which you might not appreciate viewing the Properties > Security listings ?
      Perhaps it could also be Firewall related ?
      You'll need to have some meaningful discussions with your IT guys...
      Good luck.
      Thanks TIG I'm waiting for them to try out some options to test.
      PS: Can you also set up [or get IT to set up] your SketchUp.exe to always run as administrator - under Properties > Compatibility - this might help too...
      I was able to set it up, didn't help much so far.
        leminilab
        The plug-in doesn't seem detect my Sketchup Make 2015. Is it normal (not implemented yet) or is there something I must do to fix this?
        Oh, and before I forget: the bundle option is a hit! Thanks a lot for that! ๐Ÿ‘
        • "Live every day as if it were your last and then some day you'll be right."
        • "ThomThom rules!!!"
        • KrisidiousK Offline
          Krisidious
          it's ready and should be the first plugin you install. you are installing it from the downloaded file in 2015 correct?
          By: Kristoff Rand
            leminilab
            Yes. Downloaded here http://sketchucation.com/resources/plugin-store-download and installed from Window/Preferences/Extensions menu.
            But Make 2015 doesn't show in the Bundle tab:
            • BoxB Offline
              What is this then?
                leminilab
                It's a bundle I created of my installed plugins in SU8.
                • BoxB Offline
                  I don't have my pc here to check but I think you won't have a bundle if you haven't used the tool to install any plugins. So on a new install you would download the su8 bundle and that would become the current 2015 bundle until you edit or add to it.
                    I guess you are expecting to see 'Bundle' named 'LEMINLAB-PROD-15' ?
                    Have you tried restarting SketchUp ?
                    In v2015 what does you're 'My Installs' tab show ?
                    If it's empty there is no Bundle.
                    Try installing a Plugins and re-check the 'My Installs' and the 'Bundles'...
                    If no joy can you try copy+paste this snippet into the Ruby Console + <enter>
                    puts;puts(SCF_Dialog.getMyPlugins.split('|').join("\n"))
                    This will tell us what is getting sent to the server...
                    It ought to star with your Computer-Name:SketchUp-Version
                    Then a list of available installed v2015 Plugins in order [both enabled and disabled]...
                    If still no joy then we need to get Gรกbor onto it server-side...
                      leminilab
                      • Yes
                      • It's empty ๐Ÿ˜ž
                      • When I try to Autoinstall a plug-in (like extrude tools for example ;p), nothing happens on screen.
                      • I got this:
                        Error: #<SyntaxError: <main>: syntax error, unexpected tIDENTIFIER, expecting end-of-input
                        SketchUp:1:in `eval'
                      • How bad is it, doc? ๐Ÿ˜„
                      P.S.: I love this "Great!!! All of your plugins are up to date." message! ๐Ÿ˜„
                        We might be able to save you ๐Ÿ˜‰
                        More diagnosis needed...
                        Can you open Internet Explorer, ensure its version is up to date, then empty its cache.
                        Now restart SketchUp and retry the SketchUcation PluginStore dialog - any luck AutoInstalling something ?
                        Can you use the item under the menu Plugins [now renamed Extensions in v2015] > SketchUcation submenu item to 'Open Plugins Folder'.
                        It should open something like:
                        C:\Users\YOUR_USER_NAME\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
                        Are there any files in it ?
                        If you go up one folder to .../SketchUp and use Properties > Security > Edit does every entry listed have FULL read/write/modify permissions setup?
                        Change them if necessary, apply/OK...
                        Try AutoInstalling again...
                        Also open the SketchUcation > Plugins Manager dialog.
                        Is the folder listed in the top-bar ?
                        Are there any contents ?
                        Report back ๐Ÿค“
                          leminilab
                          Report back ๐Ÿค“
                          • Cache emptied. Not working.
                          • All permissions granted. Not working.
                          • I can't open the Plugins Manager.
                            ๐Ÿ˜•
                            Can you tell us what your Users user-name is ?
                            Next...
                            Find the SketchUp.exe icon in the 2015 Programs folder.
                            Change its Properties > Compatibility > Run As Administrator... to ON [tick]... OK.
                            Try again...
                              leminilab
                              Next...
                              Try again...
                              • My user name is leminilab:
                              • Changed compatibility to run as Admin.
                                I now get a message from Windows when I launch Make 2015 ("Do you want the following program to allow changes to this computer?").
                                But it's still not working. ๐Ÿ˜ข
                                That last part sounds like a Filewall issue.
                                Make sure SketchUp 2015 is set to allow it to make changes and access the Internet...
                                Can you download an RBZ from the PluginStore page - linked above.
                                Then install it using the Preferences > Extensions > Install button in v2015.
                                Does its file[s] appear in the Users Plugins folder.
                                Does it then appear in the Plugins Manager and My-Installs ?
                                This is weird... ๐Ÿ˜•
                                  leminilab
                                  I enabled Sketchup in Windows Firewall.
                                  The "More infoรฉ and "Donate" buttons work. But Autoinstall doesn't.
                                  The install tab is blank.
                                  • FrederikF Offline
                                    Frederik
                                    Donate a little and see if that fixes it... ๐Ÿ˜†
                                    Cheers
                                    Kim Frederik
                                      You have a 'Download' button in the page - I did NOT mean the dialog [which has the AutoInstall button]...
                                      Or is something blocking your browser and its ability to access the Internet and 'Download' files too - are you using Internet Explorer to access sketchUcation.com ?
                                      It's also affecting the PluginStore downloads and the related download and AutoInstall via the dialog within SketchUp, which uses Internet Explorer [incidentally, what version do you use?].
                                      Try and reset your IE Internet Options to use the default settings, perhaps they are too strict ?
                                      Have you also emptied the IE cache as I suggested previously...
                                        leminilab
                                        ๐Ÿ˜†
                                        I did download the .rbz and installed it from the Window/Preferences/Extensions Menu.
                                        I'm using Firefox but the plugin seems to be able to connect to internet because I can see the list of plugins when I click the Sketchucation Plugin Store button.
                                        IE version is 11.0.9600.17358. I did empty the cache.
                                        I really don't think it's a browser-related issue: it works fine with my SU 8 version. ๐Ÿ˜•
                                        I really don't want this to take too much energy from anyone: I can still install my plugins manually! ๐Ÿ˜„
                                          The dialog can receive data from the server, but downloading the file seems to be the issue [which then fails to AutoLoad through the dialog].
                                          If you try the AutoLoad download with the Ruby Console open are there any error messages.
                                          You ought to get some useful error-dialogs but maybe the unforeseen peculiar set of circumstances is not calling those...
                                          Can you also try this in the Ruby Console [copy/paste+<enter>] - it will open the temporary destination folder for the downloaded RBZ file...
                                          UI.openURL("file:///#{SCF::TEMPDIR}")
                                          It should open the temp folder, pathed something like:
                                          C:/Users/Leminlab/AppData/Local/Temp/SCF
                                          Try to AutoInstall a Plugin from the dialog.
                                          If that folder shows no RBZ being added to it [perhaps very briefly], then the download is failing.
                                          But if it shows an RBZ arriving [even fleetingly] then the installer is failing to process the RBZ.
                                          If it leaves an RBZ in that folder... then can you rename it with a .ZIP suffix and try opening it - are its contents OK, or is it 'corrupted' ?
                                            leminilab
                                            Here's the Ruby Console message when I try an Autoinstall:
                                            Error: #<NoMethodError: undefined method downcase' for nil:NilClass> c:/users/leminilab/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:442:in block in custom_plugins'
                                            c:/users/leminilab/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:439:in each' c:/users/leminilab/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:439:in custom_plugins'
                                            c:/users/leminilab/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:461:in autoinstall_dlg' c:/users/leminilab/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:405:in set_autoinstall_choice'
                                            c:/users/leminilab/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:73:in block in new' SketchUp:1:in call'
                                            No rbz downloaded in the C:\Users\leminilab\AppData\Local\Temp\SCF folder.
                                            • 2 / 7
