    [Plugin] SketchUcation Tools 2.6.1
    127 Posts 32 Posters 95.7k Views 32 Watching
      It looks like one of your IT guys "is protecting you from yourself".
      You need FULL read/write/modify permissions to your User's Plugins folder, AND these must also apply to the folder's contents.
      I suspect that there is some subtle limiter set up by them [perhaps under 'Advanced' ?] which you might not appreciate viewing the Properties > Security listings ?
      Perhaps it could also be Firewall related ?
      You'll need to have some meaningful discussions with your IT guys...
      Good luck.
      PS: Can you also set up [or get IT to set up] your SketchUp.exe to always run as administrator - under Properties > Compatibility - this might help too...
        Jim
        How are you determining if a folder has "FULL Read/Write security permissions?"
        • erkanE Offline
          erkan
          Right click on the folder Plugins, then properties as shown in the above screenshot.
          • erkanE Offline
            erkan
            Good luck.
            Thanks TIG I'm waiting for them to try out some options to test.
            I was able to set it up, didn't help much so far.
              leminilab
              The plug-in doesn't seem detect my Sketchup Make 2015. Is it normal (not implemented yet) or is there something I must do to fix this?
              Oh, and before I forget: the bundle option is a hit! Thanks a lot for that! πŸ‘
              • "Live every day as if it were your last and then some day you'll be right."
              • "ThomThom rules!!!"
              • KrisidiousK Offline
                Krisidious
                it's ready and should be the first plugin you install. you are installing it from the downloaded file in 2015 correct?
                By: Kristoff Rand
                  leminilab
                  Yes. Downloaded here http://sketchucation.com/resources/plugin-store-download and installed from Window/Preferences/Extensions menu.
                  But Make 2015 doesn't show in the Bundle tab:
                  • BoxB Offline
                    What is this then?
                      leminilab
                      It's a bundle I created of my installed plugins in SU8.
                      • BoxB Offline
                        I don't have my pc here to check but I think you won't have a bundle if you haven't used the tool to install any plugins. So on a new install you would download the su8 bundle and that would become the current 2015 bundle until you edit or add to it.
                          I guess you are expecting to see 'Bundle' named 'LEMINLAB-PROD-15' ?
                          Have you tried restarting SketchUp ?
                          In v2015 what does you're 'My Installs' tab show ?
                          If it's empty there is no Bundle.
                          Try installing a Plugins and re-check the 'My Installs' and the 'Bundles'...
                          If no joy can you try copy+paste this snippet into the Ruby Console + <enter>
                          puts;puts(SCF_Dialog.getMyPlugins.split('|').join("\n"))
                          This will tell us what is getting sent to the server...
                          It ought to star with your Computer-Name:SketchUp-Version
                          Then a list of available installed v2015 Plugins in order [both enabled and disabled]...
                          If still no joy then we need to get GΓ‘bor onto it server-side...
                            leminilab
                            • Yes
                            • It's empty 😞
                            • When I try to Autoinstall a plug-in (like extrude tools for example ;p), nothing happens on screen.
                            • I got this:
                              Error: #<SyntaxError: <main>: syntax error, unexpected tIDENTIFIER, expecting end-of-input
                              SketchUp:1:in `eval'
                            • How bad is it, doc? πŸ˜„
                            P.S.: I love this "Great!!! All of your plugins are up to date." message! πŸ˜„
                              We might be able to save you πŸ˜‰
                              More diagnosis needed...
                              Can you open Internet Explorer, ensure its version is up to date, then empty its cache.
                              Now restart SketchUp and retry the SketchUcation PluginStore dialog - any luck AutoInstalling something ?
                              Can you use the item under the menu Plugins [now renamed Extensions in v2015] > SketchUcation submenu item to 'Open Plugins Folder'.
                              It should open something like:
                              C:\Users\YOUR_USER_NAME\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
                              Are there any files in it ?
                              If you go up one folder to .../SketchUp and use Properties > Security > Edit does every entry listed have FULL read/write/modify permissions setup?
                              Change them if necessary, apply/OK...
                              Try AutoInstalling again...
                              Also open the SketchUcation > Plugins Manager dialog.
                              Is the folder listed in the top-bar ?
                              Are there any contents ?
                              Report back πŸ€“
                                leminilab
                                Report back πŸ€“
                                • Cache emptied. Not working.
                                • All permissions granted. Not working.
                                • I can't open the Plugins Manager.
                                  πŸ˜•
                                  Can you tell us what your Users user-name is ?
                                  Next...
                                  Find the SketchUp.exe icon in the 2015 Programs folder.
                                  Change its Properties > Compatibility > Run As Administrator... to ON [tick]... OK.
                                  Try again...
                                    leminilab
                                    Next...
                                    Try again...
                                    • My user name is leminilab:
                                    • Changed compatibility to run as Admin.
                                      I now get a message from Windows when I launch Make 2015 ("Do you want the following program to allow changes to this computer?").
                                      But it's still not working. 😒
                                      That last part sounds like a Filewall issue.
                                      Make sure SketchUp 2015 is set to allow it to make changes and access the Internet...
                                      Can you download an RBZ from the PluginStore page - linked above.
                                      Then install it using the Preferences > Extensions > Install button in v2015.
                                      Does its file[s] appear in the Users Plugins folder.
                                      Does it then appear in the Plugins Manager and My-Installs ?
                                      This is weird... πŸ˜•
                                        leminilab
                                        I enabled Sketchup in Windows Firewall.
                                        The "More infoΓ© and "Donate" buttons work. But Autoinstall doesn't.
                                        The install tab is blank.
                                        • FrederikF Offline
                                          Frederik
                                          Donate a little and see if that fixes it... πŸ˜†
                                          Cheers
                                          Kim Frederik
                                            You have a 'Download' button in the page - I did NOT mean the dialog [which has the AutoInstall button]...
                                            Or is something blocking your browser and its ability to access the Internet and 'Download' files too - are you using Internet Explorer to access sketchUcation.com ?
                                            It's also affecting the PluginStore downloads and the related download and AutoInstall via the dialog within SketchUp, which uses Internet Explorer [incidentally, what version do you use?].
                                            Try and reset your IE Internet Options to use the default settings, perhaps they are too strict ?
                                            Have you also emptied the IE cache as I suggested previously...
                                            • 2 / 7
