    [Plugin] SketchUcation Tools 2.6.1
    127 Posts 32 Posters 99.2k Views 32 Watching
    • erkanE Offline
      erkan
      I've asked Gรกbor to look into this too...
      Have you got SketchUp / sketchUcation.com allowed in your Firewall settings ?
      Firewall is managed centrally by IT I'll ask this; any specific port should be asking?
      Have you definitely set the User's Plugins folder Properties > Security > Edit permission to FULL, for each of those listed and applied/OK ?
      As you can see in my previous screenshot I have the Full access already, I can't change as it's managed by IT. I will definitely ask for a fresh update on that from IT.
      Have the permissions trickled down to all subfolders and files within that Plugins folder ?
      N/A
      If you open the SketchUcation tools Plugins Manager can you see the contents of the User's Plugins folder ?
      Yes
      Can you change them [e.g. disable one] ?
      Nope
      If you exit SketchUp and try again have those changes been kept ?
      N/A
      Can you send be by PM a screen shot showing all of your files/subfolders within Plugins ๐Ÿ˜•
      Coming right up in your PM inbox
        It looks like one of your IT guys "is protecting you from yourself".
        You need FULL read/write/modify permissions to your User's Plugins folder, AND these must also apply to the folder's contents.
        I suspect that there is some subtle limiter set up by them [perhaps under 'Advanced' ?] which you might not appreciate viewing the Properties > Security listings ?
        Perhaps it could also be Firewall related ?
        You'll need to have some meaningful discussions with your IT guys...
        Good luck.
        PS: Can you also set up [or get IT to set up] your SketchUp.exe to always run as administrator - under Properties > Compatibility - this might help too...
          Jim
          How are you determining if a folder has "FULL Read/Write security permissions?"
          • erkanE Offline
            erkan
            Right click on the folder Plugins, then properties as shown in the above screenshot.
            • erkanE Offline
              erkan
              Good luck.
              Thanks TIG I'm waiting for them to try out some options to test.
              I was able to set it up, didn't help much so far.
                leminilab
                The plug-in doesn't seem detect my Sketchup Make 2015. Is it normal (not implemented yet) or is there something I must do to fix this?
                Oh, and before I forget: the bundle option is a hit! Thanks a lot for that! ๐Ÿ‘
                • "Live every day as if it were your last and then some day you'll be right."
                • "ThomThom rules!!!"
                • KrisidiousK Offline
                  Krisidious
                  it's ready and should be the first plugin you install. you are installing it from the downloaded file in 2015 correct?
                  By: Kristoff Rand
                    leminilab
                    Yes. Downloaded here http://sketchucation.com/resources/plugin-store-download and installed from Window/Preferences/Extensions menu.
                    But Make 2015 doesn't show in the Bundle tab:
                    • BoxB Offline
                      What is this then?
                        leminilab
                        It's a bundle I created of my installed plugins in SU8.
                        • BoxB Offline
                          I don't have my pc here to check but I think you won't have a bundle if you haven't used the tool to install any plugins. So on a new install you would download the su8 bundle and that would become the current 2015 bundle until you edit or add to it.
                            I guess you are expecting to see 'Bundle' named 'LEMINLAB-PROD-15' ?
                            Have you tried restarting SketchUp ?
                            In v2015 what does you're 'My Installs' tab show ?
                            If it's empty there is no Bundle.
                            Try installing a Plugins and re-check the 'My Installs' and the 'Bundles'...
                            If no joy can you try copy+paste this snippet into the Ruby Console + <enter>
                            puts;puts(SCF_Dialog.getMyPlugins.split('|').join("\n"))
                            This will tell us what is getting sent to the server...
                            It ought to star with your Computer-Name:SketchUp-Version
                            Then a list of available installed v2015 Plugins in order [both enabled and disabled]...
                            If still no joy then we need to get Gรกbor onto it server-side...
                              leminilab
                              • Yes
                              • It's empty ๐Ÿ˜ž
                              • When I try to Autoinstall a plug-in (like extrude tools for example ;p), nothing happens on screen.
                              • I got this:
                                Error: #<SyntaxError: <main>: syntax error, unexpected tIDENTIFIER, expecting end-of-input
                                SketchUp:1:in `eval'
                              • How bad is it, doc? ๐Ÿ˜„
                              P.S.: I love this "Great!!! All of your plugins are up to date." message! ๐Ÿ˜„
                                We might be able to save you ๐Ÿ˜‰
                                More diagnosis needed...
                                Can you open Internet Explorer, ensure its version is up to date, then empty its cache.
                                Now restart SketchUp and retry the SketchUcation PluginStore dialog - any luck AutoInstalling something ?
                                Can you use the item under the menu Plugins [now renamed Extensions in v2015] > SketchUcation submenu item to 'Open Plugins Folder'.
                                It should open something like:
                                C:\Users\YOUR_USER_NAME\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
                                Are there any files in it ?
                                If you go up one folder to .../SketchUp and use Properties > Security > Edit does every entry listed have FULL read/write/modify permissions setup?
                                Change them if necessary, apply/OK...
                                Try AutoInstalling again...
                                Also open the SketchUcation > Plugins Manager dialog.
                                Is the folder listed in the top-bar ?
                                Are there any contents ?
                                Report back ๐Ÿค“
                                  leminilab
                                  Report back ๐Ÿค“
                                  • Cache emptied. Not working.
                                  • All permissions granted. Not working.
                                  • I can't open the Plugins Manager.
                                    ๐Ÿ˜•
                                    Can you tell us what your Users user-name is ?
                                    Next...
                                    Find the SketchUp.exe icon in the 2015 Programs folder.
                                    Change its Properties > Compatibility > Run As Administrator... to ON [tick]... OK.
                                    Try again...
                                      leminilab
                                      Next...
                                      Try again...
                                      • My user name is leminilab:
                                      • Changed compatibility to run as Admin.
                                        I now get a message from Windows when I launch Make 2015 ("Do you want the following program to allow changes to this computer?").
                                        But it's still not working. ๐Ÿ˜ข
                                        That last part sounds like a Filewall issue.
                                        Make sure SketchUp 2015 is set to allow it to make changes and access the Internet...
                                        Can you download an RBZ from the PluginStore page - linked above.
                                        Then install it using the Preferences > Extensions > Install button in v2015.
                                        Does its file[s] appear in the Users Plugins folder.
                                        Does it then appear in the Plugins Manager and My-Installs ?
                                        This is weird... ๐Ÿ˜•
                                          leminilab
                                          I enabled Sketchup in Windows Firewall.
                                          The "More infoรฉ and "Donate" buttons work. But Autoinstall doesn't.
                                          The install tab is blank.
                                          • FrederikF Offline
                                            Frederik
                                            Donate a little and see if that fixes it... ๐Ÿ˜†
                                            Cheers
                                            Kim Frederik
                                            • 2 / 7
