[Plugin] SketchUcation Tools 2.6.1
Hi TIG, thanks for yuor help, please find my answers to your questions.
What version of SketchUp ?
2014
Can you Auto-Install an RBZ using Preferences > Extensions > Install button ?
Yes@unknownuser said:
Can you Auto-Install an RBZ using the SketchUcation toolset's submenu 'Archive Installer' ?
No, I get the same error, also when I go to the website http://sketchucation.com/plugin/123-plugin clicking Download link won't conclude, the browser keep on "Waiting for plugin.sketchucation.com" I'm feeling stuck in 2014, good thing that I haven't removed SU 8 and performing some operations over there.@unknownuser said:
Is this message just with the PluginStore dialog within SketchUp ?
Does your Windows User name include any unusual characters - like accents or Cyrillic ?
No@unknownuser said:
I can't make out the name in the top of the dialog - it looks to have something between the two parts of the User-Name ?
There's a dot after the name, Name.Surname@domain.com This cannot be edited as it's a part of the corporate IT environment.
Can you copy/paste this text into the Ruby Console, + <enter> and post the result...
Sketchup.find_support_file "Plugins"
Result C:/Users/Name.Surname/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins@unknownuser said:
Can you also try this...
File.exist?(Sketchup.find_support_file "Plugins")
trueWhat do you think?
I've asked Gรกbor to look into this too...
Have you got SketchUp / sketchUcation.com allowed in your Firewall settings ?
Have you definitely set the User's Plugins folder Properties > Security > Edit permission to FULL, for each of those listed and applied/OK ?
Have the permissions trickled down to all subfolders and files within that Plugins folder ?
If you open the SketchUcation tools Plugins Manager can you see the contents of the User's Plugins folder ?
Can you change them [e.g. disable one] ?
If you exit SketchUp and try again have those changes been kept ?
Can you send be by PM a screen shot showing all of your files/subfolders within Plugins
Firewall is managed centrally by IT I'll ask this; any specific port should be asking?@unknownuser said:
As you can see in my previous screenshot I have the Full access already, I can't change as it's managed by IT. I will definitely ask for a fresh update on that from IT.@unknownuser said:
N/A
Coming right up in your PM inbox -
It looks like one of your IT guys "is protecting you from yourself".
You need FULL read/write/modify permissions to your User's Plugins folder, AND these must also apply to the folder's contents.
I suspect that there is some subtle limiter set up by them [perhaps under 'Advanced' ?] which you might not appreciate viewing the Properties > Security listings ?
Perhaps it could also be Firewall related ?
You'll need to have some meaningful discussions with your IT guys...
Good luck.PS: Can you also set up [or get IT to set up] your SketchUp.exe to always run as administrator - under Properties > Compatibility - this might help too...
How are you determining if a folder has "FULL Read/Write security permissions?"
Right click on the folder Plugins, then properties as shown in the above screenshot.
Good luck.Thanks TIG I'm waiting for them to try out some options to test.
I was able to set it up, didn't help much so far.
The plug-in doesn't seem detect my Sketchup Make 2015. Is it normal (not implemented yet) or is there something I must do to fix this?
Oh, and before I forget: the bundle option is a hit! Thanks a lot for that!
it's ready and should be the first plugin you install. you are installing it from the downloaded file in 2015 correct?
Yes. Downloaded here http://sketchucation.com/resources/plugin-store-download and installed from Window/Preferences/Extensions menu.
But Make 2015 doesn't show in the Bundle tab:
What is this then?
It's a bundle I created of my installed plugins in SU8.
I don't have my pc here to check but I think you won't have a bundle if you haven't used the tool to install any plugins. So on a new install you would download the su8 bundle and that would become the current 2015 bundle until you edit or add to it.
I guess you are expecting to see 'Bundle' named 'LEMINLAB-PROD-15' ?
Have you tried restarting SketchUp ?
In v2015 what does you're 'My Installs' tab show ?
If it's empty there is no Bundle.
Try installing a Plugins and re-check the 'My Installs' and the 'Bundles'...If no joy can you try copy+paste this snippet into the Ruby Console + <enter>
puts;puts(SCF_Dialog.getMyPlugins.split('|').join("\n"))This will tell us what is getting sent to the server...
It ought to star with your Computer-Name:SketchUp-Version
Then a list of available installed v2015 Plugins in order [both enabled and disabled]...If still no joy then we need to get Gรกbor onto it server-side...
Yes
It's empty
When I try to Autoinstall a plug-in (like extrude tools for example ;p), nothing happens on screen.
I got this:
Error: #<SyntaxError: <main>: syntax error, unexpected tIDENTIFIER, expecting end-of-input
SketchUp:1:in `eval' -
How bad is it, doc?
P.S.: I love this "Great!!! All of your plugins are up to date." message!
We might be able to save you
More diagnosis needed...Can you open Internet Explorer, ensure its version is up to date, then empty its cache.
Now restart SketchUp and retry the SketchUcation PluginStore dialog - any luck AutoInstalling something ?Can you use the item under the menu Plugins [now renamed Extensions in v2015] > SketchUcation submenu item to 'Open Plugins Folder'.
It should open something like:
C:\Users\YOUR_USER_NAME\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
Are there any files in it ?If you go up one folder to .../SketchUp and use Properties > Security > Edit does every entry listed have FULL read/write/modify permissions setup?
Change them if necessary, apply/OK...Try AutoInstalling again...
Also open the SketchUcation > Plugins Manager dialog.
Is the folder listed in the top-bar ?
Are there any contents ?Report back
- Cache emptied. Not working.
- All permissions granted. Not working.
- I can't open the Plugins Manager.
Can you tell us what your Users user-name is ?Next...
Find the SketchUp.exe icon in the 2015 Programs folder.
Change its Properties > Compatibility > Run As Administrator... to ON [tick]... OK.Try again...
My user name is leminilab:
Changed compatibility to run as Admin.
I now get a message from Windows when I launch Make 2015 ("Do you want the following program to allow changes to this computer?").
But it's still not working.
That last part sounds like a Filewall issue.
Make sure SketchUp 2015 is set to allow it to make changes and access the Internet...Can you download an RBZ from the PluginStore page - linked above.
Then install it using the Preferences > Extensions > Install button in v2015.
Does its file[s] appear in the Users Plugins folder.
Does it then appear in the Plugins Manager and My-Installs ?This is weird...
