    SketchUp 2015 is 64bit
    302 Posts 74 Posters 34.8k Views 74 Watching
    • JonFarJ Offline
      JonFar
      @tt_su said:
      @JonFar: What does your OpenGL preferences in SU look like? I have nVidia card on my private computer and I have noticed that on fresh install I tend to end up with AA settings which isn't listed in SU's Preferences. In fact it looks like the AA is higher than the 4x SU offer. While it looks nicer I always felt it didn't perform as well. After switching AA to 4x and restarting it was working better. Just a stab in the dark here.
      thanks for the sugestion, but no, there is no visible change and i tried all the listed options
      but dont worry about that, as the guys said, i have an APU, i cant expect it to perform like it an F1 racing car πŸ˜„
      • Al HartA Offline
        Al Hart
        @tt_su said:
        @numerobis said:
        But copying geometry could be improved... πŸ˜‰
        Yea - we really want to improve geometry creation. The FaceFinder improvements in SU2015 was one step into that.
        Multiple Threads
        We, Render Plus, have written a couple of CAD Systems - and still support ARRIS Cad which is out there somewhere.
        We have given a lot of thought to how to use multiple threads in a CAD system. The basic problem is that in order to use more than one thread you have to be able to do two things at once.
        So, it is almost impossible to multi-thread a ruby routine which is doing something. (But not fully impossible) But somehwat easier to multi-thread time consuming operations in the C-code.
        One relatively easy thing would be to improve searching the database for a particular object - because you could start 2 or 4 or more searches at once - each in its own thread looking at 1/2, 1/4 or whatever of the database - and vastly improve search times. But search times are typically such a small part of the overall CAD experience that it wouldn't help much.
        But when you find a particularly slow operation like copying geometry, you might be able to multi thread it and speed it up. This is more complex because each thread is adding stuff to the database, so you have to let each thread make its changes and then clean it up afterwards. But it might be a fine challenge for some SketchUp programmers.
        Al Hart
        IRender nXt from Render Plus
          d12dozr
          @SU team, thanks for a great release. Glad to see Trimble taking the program in a fresh direction.
          http://goo.gl/f7ooYh
          • david_hD Offline
            david_h
            I just got it and installed. I'm really late to the game. .. .again. Any tricks or traps to bringing over my plugins folder from V8?
            (yes. .. I was still on V8 πŸ’š )
            • BoxB Offline
              DON'T copy over old plugins.
              Install the sketchucation plugin and then auto install all new from there.
                Boy! You sure are late to the game. πŸ˜‰ As Box said, don't. Simple as that.
                • david_hD Offline
                  david_h
                  Yeah. . .I was afraid of that. Darn it. πŸ˜’
                  • david_hD Offline
                    david_h
                    And that is why I didn't upgrade with 13, 14, whatever. I didn't want to slog thru all the plugsin and crap .. .again. Looks like a fun day for me!
                    D
                    • BoxB Offline
                      With the plugin store you can just work away and install them as you find you need them.
                      • david_hD Offline
                        david_h
                        Yeah. I know. But I'm not good at this. Kinda Ironic for a "Top Sketchucator" n'st-ce pas? πŸ’š
                        • hellnbakH Offline
                          hellnbak
                          Hey, if I can do it, anybody can πŸ˜†
                          And it's really worth the effort!
                          • david_hD Offline
                            david_h
                            So I am doin' the whole "Plugin store Thing"(thanks Rich for the video) I did know that much. But it gives an "Extensions" directory rather than the good ol' plugins tab.
                            what about old but beloved little plugins with .rb extensions.. Can I just move them into the extensions directory? I can't just create a plugins directory it seems. And do i need to re-download and re-isntall my renderers? Podium, twilight, thea. .. etc etc etc? Thanks for the help
                            and the patience. I'm just out of practice. I don't do this much anymore. Version 8 you know. πŸ˜„
                            D
                              driven
                              @david_h said:
                              ... Version 8 you know. πŸ™‚
                              definitely start fresh and download everything new...
                              have fun
                              • BoxB Offline
                                To put it simply,
                                Plugins are now called extensions.
                                Use the Plugin Store from within SU to install whatever plugins you want from there.
                                Use the Extension Warehouse from within SU to install anything you want from there.
                                Any other plugins from elsewhere should be install in the appropriate manner.
                                .rb dropped into the plugin folder.
                                .rbz installed via the preferences/extension window
                                .zip unzipped into the plugin folder
                                .exe via their own installer
                                The default plugin folder can now be found at
                                C:\Users\YourUserName\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
                                Renderers will need to be reinstalled, some don't have updates yet.
                                Some plugins won't work, but most are being updated or there is something similar available.
                                • david_hD Offline
                                  david_h
                                  Thanks Guys. I appreciate it.
                                  D
                                  • Chris FullmerC Offline
                                    SketchUp 2015 changed the name of the "Plugins" menu to be the "Extensions" menu. No real difference, we're just working towards getting all our developers to register their 'plugins' as 'extensions'. It is not actually related to whether an extension is distributed as just a .rb file, or a .rbz or a .zip. Its just some calls they have to make in their code. Point is, don't be alarmed by the Extensions menu, its just a name change πŸ˜„ Old .rb files will still shot up in that menu, even though they used to show up in the Plugins menu.
                                    It is very hit-or-miss as to which ooold .rb plugins can be copied over and still work. That is why you really really have to install them via the Extension Warehouse, the SketchUcation plugin store, or smustard, just so you make sure you are getting the most recent version. Then if you still have some .rb extensions that you can't live without, just copy them into your plugins folder like you used to. Just do it sin small batches. If one doesn't work, it might pop up a loading error. then you'll know which one failed, and you won't be able to carry that one forward. In that case, all you can do is track down the author and try to get an update, or try a different plugin with same functionality.
                                    @david_h said:
                                    And do i need to re-download and re-install my renderers? Podium, twilight, thea. .. etc etc etc? Thanks for the help
                                    These are are ones that you will most definitely have to re-download their newest version, that is specifically compatible with SU 2015. Most extensions that have their own installers do things to your system that simply copying their plugin files from one version of SU to the next is bound to fail. So yeah, a good rule of thumb is that if it has its own installer, it definitely cannot simply be copied.
                                    Hope that helps!
                                    • david_hD Offline
                                      david_h
                                      Hey Chris! thanks for the reply. I feel like a newbie today. Cuz. .I kinda am.
                                      I am resigned to just reload everything. I'll muddle thru somehow. πŸ˜„
                                      https://www.youtube.com/watch?v=2O8gTIr4lys
                                      So .. .Chris. . .they treatin' ya okay over there in the land of Sketchup? You likin' that new gig?
                                      • quimQ Offline
                                        quim
                                        "Ons Gaan Nou Braai" an old South African Expression for we going to have a party (BBQ).
                                        Eish dis x64 is moving. loving it.
                                        WEBSITE http://www.q-prodesigns.co.za
                                          D
                                          Think of it as a good opportunity to do some housekeeping. Don't install those old plugins you never used anyway.
                                          • david_hD Offline
                                            david_h
                                            That is true. I am doing a lot of housekeeping on plugins. I think I was up to 24,764. I only use about 12.
                                            • 15
                                            • 16
                                            • 3 / 16
