    OSX Yosemite is coming...Problems?
    43 Posts 15 Posters 6.0k Views 15 Watching
    • jeff hammondJ Offline
      @mike lucey said:
      I'm going to tread softly with regard to upgrading to Yosemite until all the wrinkles are ironed out.
      remember apple started doing a public beta with the operating system this year.. so a lot of the wrinkles are already ironed out..
      i welcome the public beta if they're going to continue doing yearly releases of the OS.. otherwise, it's wait til .2 or .3... then by that time, another 10.x release is almost ready πŸ˜‰
        driven
        If your running SU v13, Yosemite, may create additional bugsplats as it no longer includes Ruby 1.8...
        SU v13 does run, but some plugins that do call that directly may cause bugsplats...
        so, update to v14 on Mavericks, get everything stable then switch to Yosemite...
        or do both at the same time, it seems fairly stable.
        • TandemT Offline
          Tandem
          Few important topics on the SketchUp forum for anyone considering upgrading to Yosemite or buying a new Mac:
          Should I upgrade to OS X Yosemite?
          Crash after updating Mac OS X
          How Soon Till SketchUp Works with Yosemite
          • mariochaM Offline
            mariocha
            @driven said:
            @driven said:
            There is an issue with 3DText and attempting to open the Fonts window...
            Narrowed this down to simply trying to open the Font Dialog
            Well, here, it did crash on first attempt, opening 2 debug windows asking for password ( I cancelled), but once SU reopened works fine. Could it be one of your font is bad ?
            I had a problem customizing the top toolbar thought. I could not drag any element to it. Again quit and relaunch solved it.
            But non-SU-native icons, i.e. icons of plugins, do not stay up there after quitting SU. Even after closing window and reopening. 😞
            update: I've tested SU for 1 1/2 hour and everything else seems ok, including my plugins.
            update: Tested on my laptop, all is fine. (French version on both machines)
            %(#008000)[Mario C.
              driven
              SketchUp v2015 is Yosemite compatible, and noticeably faster...
              Worth upgrading to both in my opinion...
              • mariochaM Offline
                mariocha
                Yessss !!! SU 2015 finally corrects the icons not sticking in the top toolbar !!
                Transferred my plugins and only one load error; 3Dxconnexion (v.10-2-0_r1807). It's in the root Library. Maybe I did something wrong.
                %(#008000)[Mario C.
                  driven
                  @mariocha said:
                  ... Maybe I did something wrong.
                  No it's a 32bit .bundle, so remove the bundle, it my work as I think it's 64bit by default...
                  or so you need to see if they have a special SU 64bit version available yet...
                    slbaumgartner
                    I read on SketchUp Community that 3DConnection have yet to release a Yosemite-compatible driver, but supposedly it is coming soon...
                    • mariochaM Offline
                      mariocha
                      I hope so cause, although removing the .bundle does prevent the error message, the device is still not functional.
                      %(#008000)[Mario C.
                        driven
                        I had to buy a new mouse for Yosemite, but that's not quite the same thing...
                        do you use it with other 64bit programs?
                        i.e. do you have the regular mac driver installed?
                        • mariochaM Offline
                          mariocha
                          Well, yes. Is there another one than the regular OS X driver I mentioned earlier (v.10-2-0_r1807) ?
                          I'm using a Space Navigator. It works in Google earth, 64bit ?, I do not know.
                          Update: a new driver is available ; 3DxWareMac_v10-2-1_r1861.dmg
                          %(#008000)[Mario C.
                            cacowan
                            I have the problem that I can't get SketchUp to open a "finder" style window on Yosemite. Sketchup 2015. Completely wiped the computer a week ago and did a clean install of Yosemite because the 2011 Macbook Pro was taking 5 minutes to boot up. Now SketchUp won't open a window to find textures, files to open, components to add to library... nothing without shutting down the program each time, and then I can only get ONE instance of a "finder" window to open before it hangs again. This didn't happen prior to the clean install, so I don't know if it was a function of the previous OS (Maverics, Lion, etc) being on the hard drive, or previous versions of SketchUp being there. It also crashed with every attempt at using a font outside of Arial for an extruded font today. I can't add textures, or open texture libraries. I can't add components from a library or open other libraries without quitting SketchUp and restarting each time. I've got the same issue with Layout. Can't insert a file because it won't open a "finder" window to locate it without closing the program and re-starting it. MADNESS!!!!
                              driven
                              First have you tried relaunching 'Finder' [ Alt + Right Click 'Finder' in 'Dock']...
                              Is 'Finder' working from other Apps? i.e. try 'Preview' and any non-Apple app...
                              Is SU installed in the Default location? i.e. Applications folder
                              Was SU a 'fresh' download and install?
                              If you open SU, and then use menu 'File' >> 'Open', is that working?
                              We need to ascertain if it's Finder or SU that's failing...
                              • tuna1957T Offline
                                tuna1957
                                F.W.I.W. , the 2011 macbook pros have a history of frying the logic board/ graphics cards. I know from personal experiance! I wonder if that issue could be contributing to your problems?
                                  cacowan
                                  I've seen the same problem described better on another site. Same conditions... A clean Yosemite OS. And a new download of Sketchup. It's not "Finder" that's crashing. It's the "in program " access to the file system. So in Layout, it won't create the window that accesses the file list more than once. In sketchup, it won't create the window that accesses a texture list or when you want to add a local component library... It won't create the window that accesses the file system to locate the reference file more than once.
                                  I've rolled back to Maverics until this is solved. I wonder... Just prior to wiping the computer there was a OS Yosemite update. It included a security update and it might be what slowed the startup on my Mac. On reinstalling Sketchup on Mac , there's always that caution that you're opening a program that is downloaded from the internet. What if it's the OS interfering with the program accessing the file system because it's not recognizing the app author?
                                    slbaumgartner
                                    Most strange! This is not happening to me with the latest Yosemite and SU, so obviously it is something specific to your system...but what? Have you looked in the console logs to see if there is a flood of messages when these things happen?
                                    I doubt a security issue over the app author would slow things down. When I've seen such problems, there is a dialog that pops up and blocks the app completely until you give permission to proceed.
                                    • 2 / 3
