    SketchUp 2015 is 64bit
    302 Posts 74 Posters 43.7k Views 74 Watching
    • soloS Offline
      So all existing plugins must be adapted again ❓
      Yup, now you need the 64 bit version, enjoy, see this as a spring cleaning in autumn.
        Only if they used binary libraries. Most will work as is.
        I had two which needed updating; TT_Lib and Vertex Tools. Compatible versions are on PluginStore and ExtensionWarehouse.
          Anton_S
          Those that use a .dll, or .so in their plugin have to be future proofed. Some were future proofed before SU2015 was set public. Yet, there are many plugins that don't depend on a compiled c extension or dll, which don't need to be upgraded.
            Under OSX it's .bundle.
              And this version under 64 steroïds is only valuable for the Pro version ❓
                If you ever experienced crashes because you ran out of memory this will be of use. Out of the box it's currently rare people hit this limit, but users of render engines which run inside the SketchUp process could easily hit the 32bit limit and find good use of 64bit.
                  yes but this 64 version is also for the Make version or not ? 😉
                  • pbacotP Offline
                    It's available for the Make version
                      Thx for the info! ☀
                        driven
                        SketchUp now starts with a 30 day trial of SketchUp Pro.
                        which is nice...
                        • jeff hammondJ Offline
                          nice work @suTeam.. much appreciated 👍
                          • BoxB Online
                            Two things well worth pointing out.
                            It restores the thumbnails function in Explorer
                            and
                            it can easily be set not to be the default Skp opener, in other words it doesn't ride rough shod over your choice of version. You can install it to test it out and still retain your preferred version as default.
                              Cool function! 😉
                              • andybotA Offline
                                andybot
                                which is nice...
                                interesting, no more 8 hour trial period? That's too bad imo.
                                • MsketcherM Offline
                                  Msketcher
                                  I'm really excited about the LayOut label tool AutoText features too. It can now read things like dynamic component attributes from your models. I'm trying to get it to be able to read dimension info from windows, so the label tool automatically shows the correct dimensions on windows from inside the layout document. A lot of hidden potential here...
                                    driven
                                    I believe the majority of people use up the 8hrs in a day or two...
                                    now that you can't instal both at the same time and switch just for the pro features, I think it's a good move.
                                    I prefer 30 days to test any software before purchase...
                                    • soloS Offline
                                      See the added RAM in SU.
                                      • KrisidiousK Offline
                                        Krisidious
                                        Glass Chapel... Nice.
                                        By: Kristoff Rand
                                        • andybotA Offline
                                          andybot
                                          😳 good move for Trimble I guess. 👊
                                            Msketcher
                                            I can barely fit your screenshot across my screens. I had to scroll over, and over, and over. I'm jealous of your screen size 😄
                                            • 15
                                            • 16
                                            • 2 / 16
