    SketchUp 2015 is 64bit
    302 Posts 74 Posters 96.5k Views 74 Watching
    • KrisidiousK Offline
      Krisidious
      OMG.... It's sooo fast.
      By: Kristoff Rand
        Anton_S
        Wow! We can actually check off something in the 2014 wishlist! 😍
        • utilerU Offline
          utiler
          @krisidious said:
          Well, hello Steve... Nice to meet you.
          And he rides a trumphy....my sort of bloke!! 👍
          Well done to the Trimble team once again. Glad to see 64Bit has become a reality!!!!
          Just Curious...
            So all existing plugins must be adapted again ❓
              Krisidious
              I've only tried Vue Exporter so far and it does not work in 2015.
              My first plugin was Sketchucation tools of course.
              By: Kristoff Rand
              • soloS Offline
                Yup, now you need the 64 bit version, enjoy, see this as a spring cleaning in autumn.
                  Only if they used binary libraries. Most will work as is.
                  I had two which needed updating; TT_Lib and Vertex Tools. Compatible versions are on PluginStore and ExtensionWarehouse.
                    Anton_S
                    Those that use a .dll, or .so in their plugin have to be future proofed. Some were future proofed before SU2015 was set public. Yet, there are many plugins that don't depend on a compiled c extension or dll, which don't need to be upgraded.
                      Under OSX it's .bundle.
                        And this version under 64 steroïds is only valuable for the Pro version ❓
                          If you ever experienced crashes because you ran out of memory this will be of use. Out of the box it's currently rare people hit this limit, but users of render engines which run inside the SketchUp process could easily hit the 32bit limit and find good use of 64bit.
                            yes but this 64 version is also for the Make version or not ? 😉
                            • pbacotP Offline
                              It's available for the Make version
                                Thx for the info! ☀
                                  driven
                                  SketchUp now starts with a 30 day trial of SketchUp Pro.
                                  which is nice...
                                  • jeff hammondJ Offline
                                    nice work @suTeam.. much appreciated 👍
                                    • BoxB Offline
                                      Two things well worth pointing out.
                                      It restores the thumbnails function in Explorer
                                      and
                                      it can easily be set not to be the default Skp opener, in other words it doesn't ride rough shod over your choice of version. You can install it to test it out and still retain your preferred version as default.
                                        Cool function! 😉
                                        • andybotA Offline
                                          andybot
                                          which is nice...
                                          interesting, no more 8 hour trial period? That's too bad imo.
                                          • MsketcherM Offline
                                            Msketcher
                                            I'm really excited about the LayOut label tool AutoText features too. It can now read things like dynamic component attributes from your models. I'm trying to get it to be able to read dimension info from windows, so the label tool automatically shows the correct dimensions on windows from inside the layout document. A lot of hidden potential here...
                                            • 15
                                            • 16
                                            • 1 / 16
