    Right triangle given hypotenuse and one side?
    11 Posts 6 Posters 1.3k Views 6 Watching
      Trigonometry works for me. 😉
      Or how about this?
      This could be done graphically with Fredo's Rotate tool in the FredoScale suite.
      • cottyC
        cotty
        Nice solution, Dave.
        my SketchUp gallery
          Thank you sir.
            slbaumgartner
            Dave, you omitted to mention that the third side is first constructed perpendicular to the other one. Same question and a similar answer were posted on SketchUp Community - great minds! The method posted there uses only the built-in arc tools not Fredo's, but requires an extra step or two.
              It was an intentional omission. 😉 I figured it was clear enough given the topic of the thread. The method would work for non-right triangles as well. Of course a non-right triangle doesn't have a hypotenuse.
              • BoxB
                As nice a solution as Dave's is I think with 73 of them you'd be faster doing the calc for the third side, (very simple with Dave's calculator link), then simply draw 73 rectangles with the two dimensions and split them on the diagonal.
                You need to go a few decimal places or you'll be out by a few mm over several m.
                  Good point, Box. I thought the 73 times things was number of tries to get it right. 😉
                  • BoxB
                    You might be right, I often confused Trombones with Virgins. Hang on now that was 76 of one and 4 n 20 of the other.......I guess the 73 triangles are in the percussion section
                      What about the blackbird pie?
                      • simon le bonS
                        simon le bon
                        Hi dear SketchUppers,
                        A second solution which gives the same result
                        This alternative way is a bit longer to achieve because you need to delete the circle and clean cpoints and clines, but this ancient TIG's set of tools although poorly known can bring great services.
                        The plugin used is TIG's TrueTangents v3.0
                        The tool used is True Intersections.
                        http://sketchucation.com/forums/viewtopic.php?p=160780#p160780
                        http://sketchucation.com/pluginstore?pln=TrueTangents
                        Cheers,
                        Simon
