    Right triangle given hypotenuse and one side?
    11 Posts 6 Posters 1.2k Views 6 Watching
    • C
      carlouss09
      Hi fellas!
      I'm working on a really large and complex model and I've come across with what, at first, may seem a easy problem.
      Well, I'm trying to draw a right triangle from the hypotenuse and one side, but I know no angles (except the 90º one, of course).
      I've tried to draw a circle with the known side as the radius, with the center on one end of the hypotenuse and then draw a line from the other end tangent to the circle, but this method is slow and inaccurate.
      Then I drew a random right triangle and by using pythagoras theorem scale it on the second side axis, but I'd have to do this 73 times in the model and I'd go crazy...
      Do you know any plugin or easier way to solve this?
      Thank you in advance,
      C.
        Trigonometry works for me. 😉
        Or how about this?
        This could be done graphically with Fredo's Rotate tool in the FredoScale suite.
        • cottyC
          cotty
          Nice solution, Dave.
          my SketchUp gallery
            Thank you sir.
              slbaumgartner
              Dave, you omitted to mention that the third side is first constructed perpendicular to the other one. Same question and a similar answer were posted on SketchUp Community - great minds! The method posted there uses only the built-in arc tools not Fredo's, but requires an extra step or two.
                It was an intentional omission. 😉 I figured it was clear enough given the topic of the thread. The method would work for non-right triangles as well. Of course a non-right triangle doesn't have a hypotenuse.
                • BoxB
                  As nice a solution as Dave's is I think with 73 of them you'd be faster doing the calc for the third side, (very simple with Dave's calculator link), then simply draw 73 rectangles with the two dimensions and split them on the diagonal.
                  You need to go a few decimal places or you'll be out by a few mm over several m.
                    Good point, Box. I thought the 73 times things was number of tries to get it right. 😉
                    • BoxB
                      You might be right, I often confused Trombones with Virgins. Hang on now that was 76 of one and 4 n 20 of the other.......I guess the 73 triangles are in the percussion section
                        What about the blackbird pie?
                        • simon le bonS
                          simon le bon
                          Hi dear SketchUppers,
                          A second solution which gives the same result
                          This alternative way is a bit longer to achieve because you need to delete the circle and clean cpoints and clines, but this ancient TIG's set of tools although poorly known can bring great services.
                          The plugin used is TIG's TrueTangents v3.0
                          The tool used is True Intersections.
                          http://sketchucation.com/forums/viewtopic.php?p=160780#p160780
                          http://sketchucation.com/pluginstore?pln=TrueTangents
                          Cheers,
                          Simon
