    [Plugin][$] S4u_Transformer
    28 Posts 12 Posters 19.2k Views 12 Watching
    • hdpvH Offline
      hdpv
      S4u_Transformer v1.1.0
      Select groups or components for Transformer(Scale,Move,Rotate,Color)
      Trial and Purchase : http://extensions.sketchup.com/en/content/s4u-transformer
      Video tutorial:
      http://youtu.be/oWnmTdX43C0?list=PLfw9P5m29pNSoIzRSAIfTmX_7AiXmTiue
      Suforyou
      http://www.sketchupforyou.com
      • JQLJ Offline
        JQL
        Breathtaking...
        www.casca.pt
        Visit us on facebook!
        • KrisidiousK Offline
          Krisidious
          I have no idea what I would do with it... But I like it.
          By: Kristoff Rand
          • pep75P Offline
            pep75
            One of the best plugins for Sketchup in years!!
              smuncky
              wow! this is touching into rhino territory.
              • hdpvH Offline
                hdpv
                Thank all!
                it's the same a game πŸ˜„
                Suforyou
                • BoxB Offline
                  It's a great plugin but it has the annoying persistent toolbar problem. Could you look at adjusting it for your next update.
                  @tig said:
                  If an author has made his tool's loading code 'unfriendly' it will always open its toolbar, even if you last exited with that toolbar closed...
                  For example if a plugin has the overly simple code:
                  tb.show
                  Which always opens the toolbar, irrespective of your wishes !
                  To open a toolbar only if the user previously exited with it open [OR it's the first time it's used, e.g. a new installation] the loader code needs adjusting to read something like:
                  tb.show **if tb.get_last_state.abs == 1** # TB_VISIBLE/NEVER
                  Which is the code used by the SketchUcation toolbar...
                  • StinkieS Offline
                    Stinkie
                    Wow. πŸ‘
                    • hdpvH Offline
                      hdpv
                      tb.show
                      maybe on Mac,on Win is no problem
                      I fix for next update,
                      Suforyou
                      • BoxB Offline
                        I don't have a mac.
                        • hdpvH Offline
                          hdpv
                          i don't know this error,but this code is OK
                          "tb.show if tb.get_last_state.abs == 1"
                          Suforyou
                          • BoxB Offline
                            I know nothing about coding so I gave you a quote from Tig when the issue came up before.
                            I just wanted to point out that your Plugin's toolbar was always popping up whether open or closed previously. I've just installed and tested your Slice plugin and it doesn't do it, so that suggest there is a difference in the code.
                            I don't mean this as a criticism, simply a bug fix.
                            • hdpvH Offline
                              hdpv
                              no difference in the code.I use Sketchup 2014,win64
                              this bug fix is no expect. πŸ˜„
                              Suforyou
                              • HornOxxH Offline
                                HornOxx
                                hi HDPV,
                                first thank you for this great tool!
                                I have used it for some time and it worked great so far, but since a few days I get the message
                                that I should do an update as soon as I use the plugin (please see screenshot). This is the only plugin that causes this error by now.
                                I run SketchUp 2013 Pro and SketchUp 8 Free on Win7 64bit. I get this message on both versions.
                                any help is appreciated - thank you
                                never trust a skinny cook
                                • hdpvH Offline
                                  hdpv
                                  Sorry HornOxx, This trial is expired.
                                  Suforyou
                                    Could you change the wording in the message? That message doesn't indicate at all that the trial period has expired and that the user needs to pay up or discontinue the plugin. Perhaps you could change the message to something like, "Thank you for trying S4u_Transformer. The trial period has ended. Please go to [your website] to purchase the a license."
                                    • HornOxxH Offline
                                      HornOxx
                                      Sorry - how embarrassing to me!! πŸ˜‰ I didnΒ΄t even notice that this is a purchase-plugin.
                                      Regards to All
                                      • hdpvH Offline
                                        hdpv
                                        Thanks Dave!
                                        Suforyou
                                          Berserk
                                          This is incredible
                                            pipinek
                                            To the Author (S4U).
                                            Should it be any discount, upgrade price for the v1 users?
                                            If yes how can one apply it?
