    1.5k Posts 471 Posters 3.3m Views 470 Watching
      Toon Master
      Thank you very much!
        littleche
        hi ...
        I have one problem with rounding ...
        how to fix it ?
        Round error.skp
        • fredo6F Offline
          NEW RELEASE: RoundCorner v2.7a - 19 Oct 14
          RoundCorner 2.7a is required for the support of usernames with non-ascii characters in Sketchup 2014
            littleche
            hi fredo ...
            I test my problom with last version of round corner ...
            but I still have the same problem. I'm not overly complicated.I got a lot easier.The film may be able to help :
            test
            MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
            MediaFire (www.mediafire.com)
            • fredo6F Offline
              @littleche said:
              hi fredo ...
              RoundCorner cannot do anything for this model, because it is triangulated.
              The method is to use Subdivision, which you may possibly try with Artisan by Whaat.
                taktakplz
                hi fredo
                the round corner is not working on my su13 but the curviloft and tools on surface is working fine.
                where i can install the higher version of libfredo6?i install it using extension warehouse
                  It's clearly spelled out for you in the first post on the first page of this thread.
                  Which takes you to the first post on the first page of the LibFredo6 thread which has the link you need.
                  Get the SCF Plugin Store tool and use it to auto install your plugins.
                    taktakplz
                    @fredo6 said:
                    @mattiab said:
                    SketchUp crashes each time i try to use this plugin, do you know why?
                    Do you have an old version of Vray?
                    fredo i do have the same problem
                    i have installed V-Ray for SketchUp v1.60.22
                      Remove VRay for SketchUp. It is has been known to cause problems with other plugins. Or at least use the current version of it. The current version appears to be 2.0.
                        taktakplz
                        thanks for the help fredo
                        • cottyC Offline
                          cotty
                          Dave!?
                          my SketchUp gallery
                            littleche
                            thank you fredo for your help .
                            I thought this work is Possible whit your plugin .
                            I hope this Reliability Be included in future versions. 😛
                              goblinteasemaid
                              very nice tool, works on SU6
                              doesnt do groups so you need to group edit or explode
                              and you only get one chance for offset input. Get it wrong and you must revert to sharp edge start - obvious really, no big deal
                              think of the time spent doing it manually YUK
                              thanx mille foix
                              Goblint
                                goblinteasemaid
                                F6 one thing I forgot to mention, I have an annoying issue with the drop down window in Round corners, its squashed up.
                                window problem
                                  marcostakahasi
                                  i'm trying to install. where's the archive?
                                    It's very clearly spelled out in the first post on the first page of this thread.
                                    Don't forget to read and follow the rest of the directions.
                                    • fredo6F Offline
                                      Installation of my Plugins is now done via the SCF Plugin Store.
                                      • fredo6F Offline
                                        You must have a screen with high resolution, analog to Retina screens on Mac.
                                        Nothing to do, because this dépends on Sketchup and these problem of high résolutions screen are not fixed yet.
                                        Possibly you can select the option "Retina screen" in the Default parameters of LibFredo6, but the correction is not guaranteed (see this thread).
                                          gruzdev_f
                                          Install all the instructions.
                                          but what is it?
                                          • TIGT Online
                                            If you read the tool's installation guidance it explains that, as with most of Fredo's tools, it need a set of helper files installed too - 'LibFredo6'
                                            You can get that from the PluginStore...
                                            http://sketchucation.com/pluginstore?pln=LibFredo6
                                            Install it, then restart SketchUp to ensure everything gets reintegrated...
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 73
                                            • 74
                                            • 50 / 74
