    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • E Offline
      eozel
      @fredo6 said:
      @eozel,
      Could you show a screenshort of the "check For Updates" of LibFredo6.
      Also, can you check the footprint of plugins in the SU Plugins directory where you installed.
      • fredo6F Offline
        Eozel,
        Thanks. There is also a Trace log utility in the LibFredo6 menu.
        Could you check or send me the txt or a snapshot after expanding the list.
        Also the date of last check (1 Jan 1970) seems to have a problem. I have to check
        • E Offline
          eozel
          @fredo6 said:
          Eozel,
          1413369931.22969;Fredo6_!LibFredo6.rb:71: in `log'
          DATE / TIME: 2014-10-15 13:45:31 +0300
          SKETCHUP VERSION: 14.1.1282
          RUBY_PLATFORM: i386-mingw32
          LOG FILE: LibFredo6Trace_14_1413369931228.txt
          1413369931.22969;Fredo6_!LibFredo6.rb:113: in `startup'
          LibFredo6: Starting up Fredo6_!LibFredo6.rb
          1413369931.319277;Fredo6_!LibFredo6.rb:265: in `dir_appdata'
          Temp Files directory: C:/Users/EMREZE~1/AppData/Local/Temp
          1413369931.351414;Fredo6_!LibFredo6.rb:266: in `dir_appdata'
          Default Parameters folder: C:/Users/EMREZE~1/AppData/Local/LIBFREDO6_DATA_Dir/DefaultParameters
          1413369931.385449;Fredo6_!LibFredo6.rb:173: in `startup'
          LibFredo6: Beginning of loading Cycle***+
          1413369931.4218082;Fredo6_!LibFredo6.rb:180: in `startup'
          LibFredo6 Core: Fredo6_!LibFredo6/Lib6Core.rb successfully loaded
          1413369931.5345228;Lib6Core.rb:992: in `load_full_rubies'
          LibFredo6 6.2a: Ruby files loaded [69 ms]
          1413369931.56119;Lib6Core.rb:921: in `effective_load_part2'
          LibFredo6 6.2a: Startup (creating menus and icons) [10 ms]
          1413369931.586445;Fredo6_!LibFredo6.rb:189: in `startup'
          LibFredo6: End of loading Cycle***-
          1413369938.4396129;Lib6Plugin.rb:150: in `load_body'
          Lib6PluginDialogs.rb: Loading body code from body_Lib6PluginDialogs.rb [33 ms]
          1413369938.539354;Lib6Core.rb:85: in `use_single_library'
          Lib6G6.rb: Loading body code from body_Lib6G6.rb [80 ms]
          1413369938.580538;Lib6Core.rb:85: in `use_single_library'
          Lib6Translate.rb: Loading body code from body_Lib6Translate.rb [20 ms]
          1413369938.621686;Lib6Core.rb:85: in `use_single_library'
          Lib6Spline.rb: Loading body code from body_Lib6Spline.rb [20 ms]
          1413369938.673656;Lib6Core.rb:85: in `use_single_library'
          Lib6WebHtml.rb: Loading body code from body_Lib6WebHtml.rb [30 ms]
          1413369938.770474;Lib6Core.rb:85: in `use_single_library'
          Lib6Tool.rb: Loading body code from body_Lib6Tool.rb [77 ms]
          1413369938.835396;Lib6Core.rb:85: in `use_single_library'
          Lib6Algo.rb: Loading body code from body_Lib6Algo.rb [40 ms]
          1413369938.882689;Lib6Core.rb:85: in `use_single_library'
          Lib6Contour.rb: Loading body code from body_Lib6Contour.rb [23 ms]
          1413369938.916536;Lib6Core.rb:85: in `use_single_library'
          Lib6Offset3d.rb: Loading body code from body_Lib6Offset3d.rb [15 ms]
          1413369938.9848142;Lib6Core.rb:85: in `use_single_library'
          Lib6Transform.rb: Loading body code from body_Lib6Transform.rb [49 ms]
          1413369939.032744;Lib6Core.rb:85: in `use_single_library'
          Lib6Mark.rb: Loading body code from body_Lib6Mark.rb [22 ms]
          1413369939.0687091;Lib6Plugin.rb:150: in `load_body'
          Lib6WebJS.rb: Loading body code from body_Lib6WebJS.rb [17 ms]
          1413369939.1184819;Lib6Plugin.rb:150: in `load_body'
          Lib6WebWdlg.rb: Loading body code from body_Lib6WebWdlg.rb [25 ms]
          1413369939.164896;Lib6Plugin.rb:150: in `load_body'
          Lib6WebXTable.rb: Loading body code from body_Lib6WebXTable.rb [25 ms]
          • fredo6F Offline
            Very strange.
            Could you do 2 things:
            1. Type the following commands in the RubyConsole and tell me the result
              LibFredo6.sudir
              LibFredo6.path
              LibFredo6.folder
              LibFredo6.appdata_dir
              LibFredo6.defparam_dir
              defined?(FredoTools)
            2. Remove the Fredo6_Fredotools.rb file (it is of no use actually, just for EWH compliance), exit and restart SU and see if you see FredoTools now
            Thanks and sorry for these problems. You support is helpful
            • E Offline
              eozel
              @fredo6 said:
              Very strange.
                LibFredo6.sudir
                LibFredo6.path
                LibFredo6.folder
              LibFredo6.sudir
              C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins
              LibFredo6.path
              C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6
              LibFredo6.folder
              Fredo6_!LibFredo6
              nil
              1. I removed Fredo6_Fredotools.rb file, exited and restarted SU. But there is not fredotools.
              I think there is another problem on my pc or windows settings, etc.
              Thanks for your supports
              • fredo6F Offline
                Thanks.
                Could you show the footprint of the Fredo6_FredoTools folder. You may simply have a file missing (with extension .plugin).
                • E Offline
                  eozel
                  @fredo6 said:
                  Thanks.
                  • fredo6F Offline
                    Eozel,
                    I think I found the problem.
                    To be sure, could you copy the attached file into the Fredo6!_LibFredo6 subfolder and restart SU
                    Lib6Core.rb
                    Thanks in advance
                    • E Offline
                      eozel
                      @fredo6 said:
                      Eozel,
                      [attachment=2:3s9bb5jv]<!-- ia2 -->Lib6Core.rb<!-- ia2 -->[/attachment:3s9bb5jv]
                      Thanks in advance
                      Fredotools now can ben seen in tools menu:)).
                      After than i install roundcorner it is working too but when opening the SU it give error below.
                      Then i install Su draw parametric shape 2.27 but it gives error too which is given below. Error Loading File C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/shapes.rb
                      Error: cannot load such file -- C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/parametric.rb
                      C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                      C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/shapes.rb:8:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                      C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:24:in register_extension'
                      C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:24:in <module:Shapes>' C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:12:in module:JWM'
                      C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:11:in `<top (required)>'
                      Curviloft gives errors too.
                      • fredo6F Offline
                        Eozel,
                        Thanks very much. We are progressing
                        1. for Parametric shapes, this can be a similar problem with non-ascii characters, but that's not a plugin of mine
                        2. For RoundCorner and possibly Curviloft, could you replace the following files in the SU Plugins directory
                          Fredo6_RoundCorner.rbFredo6_Curviloft.rb
                        3. For Curviloft, there may be an additional problem.
                        Anyway, once this is solved, I will republish the scripts.
                        Thanks again
                        • E Offline
                          eozel
                          @fredo6 said:
                          Eozel,
                            [attachment=2:36qnwv6n]<!-- ia2 -->Fredo6_RoundCorner.rb<!-- ia2 -->[/attachment:36qnwv6n][attachment=1:36qnwv6n]<!-- ia1 -->Fredo6_Curviloft.rb<!-- ia1 -->[/attachment:36qnwv6n]
                          Thanks again
                          Curviloft gives following error after i replaced the Fredo6_Curviloft.rb. Round cornet works with no problem.
                          • fredo6F Offline
                            Eozel,
                            Thanks.
                            For Curviloft, It may be due to a problem of installation in the Fredo6_Curviloft subfolder. Can you check that you have the following footprint.
                            Also, can you check the Trace Log as it should indicate an error on loading the bootstrap_Curviloft.rb file
                            • E Offline
                              eozel
                              @fredo6 said:
                              Eozel,
                              Thanks.
                              [attachment=1:1fbh2u6z]<!-- ia1 -->Curviloft 1.png<!-- ia1 -->[/attachment:1fbh2u6z]
                              1413537183.466945;Fredo6_!LibFredo6.rb:71: in `log'
                              DATE / TIME: 2014-10-17 12:13:03 +0300
                              LOG FILE: LibFredo6Trace_14_1413537183465.txt
                              1413537183.465944;Fredo6_!LibFredo6.rb:113: in `startup'
                              1413537183.5357492;Fredo6_!LibFredo6.rb:265: in `dir_appdata'
                              1413537183.5638778;Fredo6_!LibFredo6.rb:266: in `dir_appdata'
                              1413537183.589764;Fredo6_!LibFredo6.rb:173: in `startup'
                              1413537183.646673;Fredo6_!LibFredo6.rb:180: in `startup'
                              1413537183.840369;Lib6Core.rb:992: in `load_full_rubies'
                              LibFredo6 6.2a: Ruby files loaded [96 ms]
                              1413537183.888124;Lib6Core.rb:921: in `effective_load_part2'
                              LibFredo6 6.2a: Startup (creating menus and icons) [24 ms]
                              1413537184.057875;Lib6Core.rb:992: in `load_full_rubies'
                              Curviloft 1.3a: Ruby files loaded [71 ms]
                              1413537184.080328;Lib6Core.rb:913: in rescue in block in effective_load_part2' ?Curviloft 1.3a: Error starting up plugin (creating menus and icons) undefined method startup' for F6_Curviloft:Module [in Lib6Core.rb - #`block in effective_load_part2(): line 909]
                              1413537185.629963;Lib6Core.rb:992: in `load_full_rubies'
                              FredoTools 2.1a: Ruby files loaded [33 ms]
                              1413537185.659319;Lib6Plugin.rb:150: in `load_body'
                              Lib6Material.rb: Loading body code from body_Lib6Material.rb [3 ms]
                              1413537185.7227268;Lib6Core.rb:921: in `effective_load_part2'
                              FredoTools 2.1a: Startup (creating menus and icons) [67 ms]
                              1413537185.820959;Lib6Core.rb:963: in `load_bootstrap_rubies'
                              RoundCorner 2.6a: Bootstrap Ruby files loaded [3 ms]
                              1413537185.8898308;Lib6Core.rb:921: in `effective_load_part2'
                              RoundCorner 2.6a: Startup (creating menus and icons) [42 ms]
                              1413537185.916391;Fredo6_!LibFredo6.rb:189: in `startup'
                              1413537200.377671;Lib6Plugin.rb:150: in `load_body'
                              Lib6PluginDialogs.rb: Loading body code from body_Lib6PluginDialogs.rb [28 ms]
                              1413537200.46688;Lib6Core.rb:85: in `use_single_library'
                              Lib6G6.rb: Loading body code from body_Lib6G6.rb [68 ms]
                              1413537200.5250602;Lib6Core.rb:85: in `use_single_library'
                              Lib6Translate.rb: Loading body code from body_Lib6Translate.rb [34 ms]
                              1413537200.5839438;Lib6Core.rb:85: in `use_single_library'
                              Lib6Spline.rb: Loading body code from body_Lib6Spline.rb [35 ms]
                              1413537200.637125;Lib6Core.rb:85: in `use_single_library'
                              1413537200.757068;Lib6Core.rb:85: in `use_single_library'
                              Lib6Tool.rb: Loading body code from body_Lib6Tool.rb [100 ms]
                              1413537200.841938;Lib6Core.rb:85: in `use_single_library'
                              Lib6Algo.rb: Loading body code from body_Lib6Algo.rb [60 ms]
                              1413537200.901935;Lib6Core.rb:85: in `use_single_library'
                              Lib6Contour.rb: Loading body code from body_Lib6Contour.rb [36 ms]
                              1413537200.941764;Lib6Core.rb:85: in `use_single_library'
                              Lib6Offset3d.rb: Loading body code from body_Lib6Offset3d.rb [18 ms]
                              1413537201.013798;Lib6Core.rb:85: in `use_single_library'
                              Lib6Transform.rb: Loading body code from body_Lib6Transform.rb [48 ms]
                              1413537201.0753632;Lib6Core.rb:85: in `use_single_library'
                              Lib6Mark.rb: Loading body code from body_Lib6Mark.rb [34 ms]
                              1413537201.117089;Lib6Plugin.rb:150: in `load_body'
                              Lib6WebJS.rb: Loading body code from body_Lib6WebJS.rb [19 ms]
                              1413537201.184042;Lib6Plugin.rb:150: in `load_body'
                              Lib6WebWdlg.rb: Loading body code from body_Lib6WebWdlg.rb [43 ms]
                              1413537201.233104;Lib6Plugin.rb:150: in `load_body'
                              Lib6WebXTable.rb: Loading body code from body_Lib6WebXTable.rb [20 ms]
                              • fredo6F Offline
                                Eozel,
                                It seems Ruby 2.0 is a disaster when the path contains non-ascii charcaters and many functions are impacted.
                                If you know how to do it, could you edit the file Curviloft.plugin which is in Fredo6_Curviloft subfolder and at the end remove the line "BOOTSTRAP = bootstrap_Curviloft"
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v6.3a - 19 Oct 14
                                  LibFredo6 6.3a is a release mainly for supporting username with non-ascii characters in SU14.
                                  If this is your case, you will need also to upgrade all my scripts which I am republishing.
                                  Note that non-ascii usernames are normally supported since Sketchup 2014, but there were bugs in Ruby 2.0.
                                  See main post of this thread for Download of LibFredo6.
                                  • E Offline
                                    eozel
                                    @fredo6 said:
                                    Eozel,
                                    Thanks for your all supports, with removing of the line, Curviloft works fine.
                                    Fredotoposhape gives error when SU start "You must install Libfredo 6 version 5.2 or higher to run fredo6_toposhaper".
                                    Also, Have you got any shape plugin which works fine?
                                    • fredo6F Offline
                                      Eozel,
                                      I re-released all my plugins for non-ascii usernames.
                                      Please upgrade to LibFredo6 6.3 and latest versions of my plugins. I hope it will work for you now.
                                      • V Offline
                                        vivo44
                                        Hello Fredo,
                                        Je viens d'installer SKP14 ainsi que tous mes plugins via le menu Extensions de SKP (le SCF me dit qu'il ne sait pas unziper..)
                                        J'ai toujours un message d'erreur au lancement de SKP:
                                        "Erreur de chargement du fichier Fredo6_!LibFredo6.rb
                                        Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                        C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in match' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in block (2 levels) in load_from_config'
                                        C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in each' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in block in load_from_config'
                                        C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in foreach' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in load_from_config'
                                        C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in block in load_all_plugins' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in each'
                                        C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in load_all_plugins' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:772:in load_from_config'
                                        C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:188:in startup' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:335:in module:LibFredo6'
                                        C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in `<top (required)>'"
                                        Qu'est-ce que j'ai fait de mal?? šŸ˜ž
                                        Merci pour ton aide! Et bravo pour ton travail!
                                        • fredo6F Offline
                                          Il semblerait qu'il reste des vieux fichiers (pas au format UTF8) dans la directory Plugins. Peux tu faire le menage ou montrer la liste des fichiers / directories dans le repertoire Plugins de Sketchup
                                          • V Offline
                                            vivo44
                                            Ok voici la liste, je traine des pluggins depuis 6 ans donc c'est possible...mais je ne comprends pas lesquels!
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 109
                                            • 110
                                            • 20 / 110
