    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • E Offline
      eozel
      @fredo6 said:
      @eozel,
      At the moment, only LibFredo6 and FredoTools has been corrected for the problem of non-ascii characters.
      So are you sure you dont find it?
      • the menu is under Tools > FredoTools
      • there is a toolbar with a single icon showing F6
      There is no fredotools.
      • fredo6F Offline
        @eozel,
        Could you show a screenshort of the "check For Updates" of LibFredo6.
        Also, can you check the footprint of plugins in the SU Plugins directory where you installed.
        • E Offline
          eozel
          @fredo6 said:
          @eozel,
          • fredo6F Offline
            Eozel,
            Thanks. There is also a Trace log utility in the LibFredo6 menu.
            Could you check or send me the txt or a snapshot after expanding the list.
            Also the date of last check (1 Jan 1970) seems to have a problem. I have to check
            • E Offline
              eozel
              @fredo6 said:
              Eozel,
              1413369931.22969;Fredo6_!LibFredo6.rb:71: in `log'
              DATE / TIME: 2014-10-15 13:45:31 +0300
              SKETCHUP VERSION: 14.1.1282
              RUBY_PLATFORM: i386-mingw32
              LOG FILE: LibFredo6Trace_14_1413369931228.txt
              1413369931.22969;Fredo6_!LibFredo6.rb:113: in `startup'
              LibFredo6: Starting up Fredo6_!LibFredo6.rb
              1413369931.319277;Fredo6_!LibFredo6.rb:265: in `dir_appdata'
              Temp Files directory: C:/Users/EMREZE~1/AppData/Local/Temp
              1413369931.351414;Fredo6_!LibFredo6.rb:266: in `dir_appdata'
              Default Parameters folder: C:/Users/EMREZE~1/AppData/Local/LIBFREDO6_DATA_Dir/DefaultParameters
              1413369931.385449;Fredo6_!LibFredo6.rb:173: in `startup'
              LibFredo6: Beginning of loading Cycle***+
              1413369931.4218082;Fredo6_!LibFredo6.rb:180: in `startup'
              LibFredo6 Core: Fredo6_!LibFredo6/Lib6Core.rb successfully loaded
              1413369931.5345228;Lib6Core.rb:992: in `load_full_rubies'
              LibFredo6 6.2a: Ruby files loaded [69 ms]
              1413369931.56119;Lib6Core.rb:921: in `effective_load_part2'
              LibFredo6 6.2a: Startup (creating menus and icons) [10 ms]
              1413369931.586445;Fredo6_!LibFredo6.rb:189: in `startup'
              LibFredo6: End of loading Cycle***-
              1413369938.4396129;Lib6Plugin.rb:150: in `load_body'
              Lib6PluginDialogs.rb: Loading body code from body_Lib6PluginDialogs.rb [33 ms]
              1413369938.539354;Lib6Core.rb:85: in `use_single_library'
              Lib6G6.rb: Loading body code from body_Lib6G6.rb [80 ms]
              1413369938.580538;Lib6Core.rb:85: in `use_single_library'
              Lib6Translate.rb: Loading body code from body_Lib6Translate.rb [20 ms]
              1413369938.621686;Lib6Core.rb:85: in `use_single_library'
              Lib6Spline.rb: Loading body code from body_Lib6Spline.rb [20 ms]
              1413369938.673656;Lib6Core.rb:85: in `use_single_library'
              Lib6WebHtml.rb: Loading body code from body_Lib6WebHtml.rb [30 ms]
              1413369938.770474;Lib6Core.rb:85: in `use_single_library'
              Lib6Tool.rb: Loading body code from body_Lib6Tool.rb [77 ms]
              1413369938.835396;Lib6Core.rb:85: in `use_single_library'
              Lib6Algo.rb: Loading body code from body_Lib6Algo.rb [40 ms]
              1413369938.882689;Lib6Core.rb:85: in `use_single_library'
              Lib6Contour.rb: Loading body code from body_Lib6Contour.rb [23 ms]
              1413369938.916536;Lib6Core.rb:85: in `use_single_library'
              Lib6Offset3d.rb: Loading body code from body_Lib6Offset3d.rb [15 ms]
              1413369938.9848142;Lib6Core.rb:85: in `use_single_library'
              Lib6Transform.rb: Loading body code from body_Lib6Transform.rb [49 ms]
              1413369939.032744;Lib6Core.rb:85: in `use_single_library'
              Lib6Mark.rb: Loading body code from body_Lib6Mark.rb [22 ms]
              1413369939.0687091;Lib6Plugin.rb:150: in `load_body'
              Lib6WebJS.rb: Loading body code from body_Lib6WebJS.rb [17 ms]
              1413369939.1184819;Lib6Plugin.rb:150: in `load_body'
              Lib6WebWdlg.rb: Loading body code from body_Lib6WebWdlg.rb [25 ms]
              1413369939.164896;Lib6Plugin.rb:150: in `load_body'
              Lib6WebXTable.rb: Loading body code from body_Lib6WebXTable.rb [25 ms]
              • fredo6F Offline
                Very strange.
                Could you do 2 things:
                1. Type the following commands in the RubyConsole and tell me the result
                  LibFredo6.sudir
                  LibFredo6.path
                  LibFredo6.folder
                  LibFredo6.appdata_dir
                  LibFredo6.defparam_dir
                  defined?(FredoTools)
                2. Remove the Fredo6_Fredotools.rb file (it is of no use actually, just for EWH compliance), exit and restart SU and see if you see FredoTools now
                Thanks and sorry for these problems. You support is helpful
                • E Offline
                  eozel
                  @fredo6 said:
                  Very strange.
                    LibFredo6.sudir
                    LibFredo6.path
                    LibFredo6.folder
                  LibFredo6.sudir
                  C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins
                  LibFredo6.path
                  C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6
                  LibFredo6.folder
                  Fredo6_!LibFredo6
                  nil
                  1. I removed Fredo6_Fredotools.rb file, exited and restarted SU. But there is not fredotools.
                  I think there is another problem on my pc or windows settings, etc.
                  Thanks for your supports
                  • fredo6F Offline
                    Thanks.
                    Could you show the footprint of the Fredo6_FredoTools folder. You may simply have a file missing (with extension .plugin).
                    • E Offline
                      eozel
                      @fredo6 said:
                      Thanks.
                      • fredo6F Offline
                        Eozel,
                        I think I found the problem.
                        To be sure, could you copy the attached file into the Fredo6!_LibFredo6 subfolder and restart SU
                        Lib6Core.rb
                        Thanks in advance
                        • E Offline
                          eozel
                          @fredo6 said:
                          Eozel,
                          [attachment=2:3s9bb5jv]<!-- ia2 -->Lib6Core.rb<!-- ia2 -->[/attachment:3s9bb5jv]
                          Thanks in advance
                          Fredotools now can ben seen in tools menu:)).
                          After than i install roundcorner it is working too but when opening the SU it give error below.
                          Then i install Su draw parametric shape 2.27 but it gives error too which is given below. Error Loading File C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/shapes.rb
                          Error: cannot load such file -- C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/parametric.rb
                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                          C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/shapes.rb:8:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:24:in register_extension'
                          C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:24:in <module:Shapes>' C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:12:in module:JWM'
                          C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:11:in `<top (required)>'
                          Curviloft gives errors too.
                          • fredo6F Offline
                            Eozel,
                            Thanks very much. We are progressing
                            1. for Parametric shapes, this can be a similar problem with non-ascii characters, but that's not a plugin of mine
                            2. For RoundCorner and possibly Curviloft, could you replace the following files in the SU Plugins directory
                              Fredo6_RoundCorner.rbFredo6_Curviloft.rb
                            3. For Curviloft, there may be an additional problem.
                            Anyway, once this is solved, I will republish the scripts.
                            Thanks again
                            • E Offline
                              eozel
                              @fredo6 said:
                              Eozel,
                                [attachment=2:36qnwv6n]<!-- ia2 -->Fredo6_RoundCorner.rb<!-- ia2 -->[/attachment:36qnwv6n][attachment=1:36qnwv6n]<!-- ia1 -->Fredo6_Curviloft.rb<!-- ia1 -->[/attachment:36qnwv6n]
                              Thanks again
                              Curviloft gives following error after i replaced the Fredo6_Curviloft.rb. Round cornet works with no problem.
                              • fredo6F Offline
                                Eozel,
                                Thanks.
                                For Curviloft, It may be due to a problem of installation in the Fredo6_Curviloft subfolder. Can you check that you have the following footprint.
                                Also, can you check the Trace Log as it should indicate an error on loading the bootstrap_Curviloft.rb file
                                • E Offline
                                  eozel
                                  @fredo6 said:
                                  Eozel,
                                  Thanks.
                                  [attachment=1:1fbh2u6z]<!-- ia1 -->Curviloft 1.png<!-- ia1 -->[/attachment:1fbh2u6z]
                                  1413537183.466945;Fredo6_!LibFredo6.rb:71: in `log'
                                  DATE / TIME: 2014-10-17 12:13:03 +0300
                                  LOG FILE: LibFredo6Trace_14_1413537183465.txt
                                  1413537183.465944;Fredo6_!LibFredo6.rb:113: in `startup'
                                  1413537183.5357492;Fredo6_!LibFredo6.rb:265: in `dir_appdata'
                                  1413537183.5638778;Fredo6_!LibFredo6.rb:266: in `dir_appdata'
                                  1413537183.589764;Fredo6_!LibFredo6.rb:173: in `startup'
                                  1413537183.646673;Fredo6_!LibFredo6.rb:180: in `startup'
                                  1413537183.840369;Lib6Core.rb:992: in `load_full_rubies'
                                  LibFredo6 6.2a: Ruby files loaded [96 ms]
                                  1413537183.888124;Lib6Core.rb:921: in `effective_load_part2'
                                  LibFredo6 6.2a: Startup (creating menus and icons) [24 ms]
                                  1413537184.057875;Lib6Core.rb:992: in `load_full_rubies'
                                  Curviloft 1.3a: Ruby files loaded [71 ms]
                                  1413537184.080328;Lib6Core.rb:913: in rescue in block in effective_load_part2' ?Curviloft 1.3a: Error starting up plugin (creating menus and icons) undefined method startup' for F6_Curviloft:Module [in Lib6Core.rb - #`block in effective_load_part2(): line 909]
                                  1413537185.629963;Lib6Core.rb:992: in `load_full_rubies'
                                  FredoTools 2.1a: Ruby files loaded [33 ms]
                                  1413537185.659319;Lib6Plugin.rb:150: in `load_body'
                                  Lib6Material.rb: Loading body code from body_Lib6Material.rb [3 ms]
                                  1413537185.7227268;Lib6Core.rb:921: in `effective_load_part2'
                                  FredoTools 2.1a: Startup (creating menus and icons) [67 ms]
                                  1413537185.820959;Lib6Core.rb:963: in `load_bootstrap_rubies'
                                  RoundCorner 2.6a: Bootstrap Ruby files loaded [3 ms]
                                  1413537185.8898308;Lib6Core.rb:921: in `effective_load_part2'
                                  RoundCorner 2.6a: Startup (creating menus and icons) [42 ms]
                                  1413537185.916391;Fredo6_!LibFredo6.rb:189: in `startup'
                                  1413537200.377671;Lib6Plugin.rb:150: in `load_body'
                                  Lib6PluginDialogs.rb: Loading body code from body_Lib6PluginDialogs.rb [28 ms]
                                  1413537200.46688;Lib6Core.rb:85: in `use_single_library'
                                  Lib6G6.rb: Loading body code from body_Lib6G6.rb [68 ms]
                                  1413537200.5250602;Lib6Core.rb:85: in `use_single_library'
                                  Lib6Translate.rb: Loading body code from body_Lib6Translate.rb [34 ms]
                                  1413537200.5839438;Lib6Core.rb:85: in `use_single_library'
                                  Lib6Spline.rb: Loading body code from body_Lib6Spline.rb [35 ms]
                                  1413537200.637125;Lib6Core.rb:85: in `use_single_library'
                                  1413537200.757068;Lib6Core.rb:85: in `use_single_library'
                                  Lib6Tool.rb: Loading body code from body_Lib6Tool.rb [100 ms]
                                  1413537200.841938;Lib6Core.rb:85: in `use_single_library'
                                  Lib6Algo.rb: Loading body code from body_Lib6Algo.rb [60 ms]
                                  1413537200.901935;Lib6Core.rb:85: in `use_single_library'
                                  Lib6Contour.rb: Loading body code from body_Lib6Contour.rb [36 ms]
                                  1413537200.941764;Lib6Core.rb:85: in `use_single_library'
                                  Lib6Offset3d.rb: Loading body code from body_Lib6Offset3d.rb [18 ms]
                                  1413537201.013798;Lib6Core.rb:85: in `use_single_library'
                                  Lib6Transform.rb: Loading body code from body_Lib6Transform.rb [48 ms]
                                  1413537201.0753632;Lib6Core.rb:85: in `use_single_library'
                                  Lib6Mark.rb: Loading body code from body_Lib6Mark.rb [34 ms]
                                  1413537201.117089;Lib6Plugin.rb:150: in `load_body'
                                  Lib6WebJS.rb: Loading body code from body_Lib6WebJS.rb [19 ms]
                                  1413537201.184042;Lib6Plugin.rb:150: in `load_body'
                                  Lib6WebWdlg.rb: Loading body code from body_Lib6WebWdlg.rb [43 ms]
                                  1413537201.233104;Lib6Plugin.rb:150: in `load_body'
                                  Lib6WebXTable.rb: Loading body code from body_Lib6WebXTable.rb [20 ms]
                                  • fredo6F Offline
                                    Eozel,
                                    It seems Ruby 2.0 is a disaster when the path contains non-ascii charcaters and many functions are impacted.
                                    If you know how to do it, could you edit the file Curviloft.plugin which is in Fredo6_Curviloft subfolder and at the end remove the line "BOOTSTRAP = bootstrap_Curviloft"
                                    • fredo6F Offline
                                      NEW RELEASE: LibFredo6 v6.3a - 19 Oct 14
                                      LibFredo6 6.3a is a release mainly for supporting username with non-ascii characters in SU14.
                                      If this is your case, you will need also to upgrade all my scripts which I am republishing.
                                      Note that non-ascii usernames are normally supported since Sketchup 2014, but there were bugs in Ruby 2.0.
                                      See main post of this thread for Download of LibFredo6.
                                      • E Offline
                                        eozel
                                        @fredo6 said:
                                        Eozel,
                                        Thanks for your all supports, with removing of the line, Curviloft works fine.
                                        Fredotoposhape gives error when SU start "You must install Libfredo 6 version 5.2 or higher to run fredo6_toposhaper".
                                        Also, Have you got any shape plugin which works fine?
                                        • fredo6F Offline
                                          Eozel,
                                          I re-released all my plugins for non-ascii usernames.
                                          Please upgrade to LibFredo6 6.3 and latest versions of my plugins. I hope it will work for you now.
                                          • V Offline
                                            vivo44
                                            Hello Fredo,
                                            Je viens d'installer SKP14 ainsi que tous mes plugins via le menu Extensions de SKP (le SCF me dit qu'il ne sait pas unziper..)
                                            J'ai toujours un message d'erreur au lancement de SKP:
                                            "Erreur de chargement du fichier Fredo6_!LibFredo6.rb
                                            Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in match' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in block (2 levels) in load_from_config'
                                            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in each' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in block in load_from_config'
                                            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in foreach' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in load_from_config'
                                            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in block in load_all_plugins' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in each'
                                            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in load_all_plugins' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:772:in load_from_config'
                                            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:188:in startup' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:335:in module:LibFredo6'
                                            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in `<top (required)>'"
                                            Qu'est-ce que j'ai fait de mal?? šŸ˜ž
                                            Merci pour ton aide! Et bravo pour ton travail!
                                            • 95
                                            • 96
                                            • 97
                                            • 98
                                            • 99
                                            • 109
                                            • 110
                                            • 97 / 110
