    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • fredo6F Offline
      @eozel,
      Thanks for the feedback.
      2 questions:
      1. Are you able to run LibFredo6 alone. I mean does it load normally and do you see the menu Windows > LibFredo6 Settings
      2. Which of my plugins do you use.
      If it is RoundCorner or Curviloft, and keeping your username, could you try to substitute the following files instead
      Fredo6_!LibFredo6.rbFredo6_Curviloft.rbFredo6_RoundCorner.rb
      • fredo6F Offline
        NEW RELEASE: LibFredo6 v6.2a - 12 Oct 14
        LibFredo6 6.2a is a release mainly for EdgeInspector 1.2.
        It also fixes the issue of installation on SU14 when the username includes non-ascii characters
        See main post of this thread for Download of LibFredo6.
        • E Offline
          eozel
          Hi, i installed libfredo 6.2a on my pc which inclued as a username "ö" chracter. Libfredo 6 settings now can be seen in window menu, but when i open skethup it gives an error msg: "you must install Libfredo 6 version 5.2 ....".
          • fredo6F Offline
            @eozel,
            I think I have also to change the top rb file for all plugins (i.e. Fredo6_xxx.rb).
            I did it already for the new version of FredoTools (2.1a). Can you check that FredoTools does load correctly.
            If so, then I will republish for the other plugins.
              Ben Ritter
              The download link does not work for me for either one of the plugins.
              • fredo6F Offline
                Which download link? I only publish via the SCF PLugin Store.
                  Ben Ritter
                  OK, thanks. I just thought the yellow "Download" button in your post downloaded the .rb files on some of your other plugins.
                  Thanks again for sharing.
                  • E Offline
                    eozel
                    As you said, i installed fredotools. It said that "selected extension has been succesfully installed...". When i open skecthup software again it doesnt give an error for "you must install Libfredo 6 version 5.2..." but fredotools doesnt seen anywhere (tools menu, etc.).
                    Thanks four your supports.
                    • fredo6F Offline
                      Do you see the menu Windows > LibFredo6 Settings after installing LibFredo6 6.2a.
                      At least this shows that LibFredo6 is correctly installed
                      Maybe a snapshot of your Plugin directory would also help.
                      • E Offline
                        eozel
                        I see menu Windows > LibFredo6 Settings after installing LibFredo6 6.2a. But after i install extensions like curviloft, roundcornet, it give error msg ""you must install Libfredo 6 version 5.2..". I installed fredotools too as you said me, it doesnt give an error for "you must install Libfredo 6 version 5.2..." but fredotools doesnt seen anywhere (tools menu, etc.
                        thanks.
                          I've seen the same sort of message in the past. The solution that worked for me was to go to the Plugins folder and delete the LibFredo6 files including the folders. Then reinstall the fresh version from the Pluginstore.
                          Evidently, some file wasn't getting overwritten when the newer version was installed over the old.
                          • E Offline
                            eozel
                            Thanks but I try to it more than 2 times, additionally i uninstalled sketchup and delete all files related with it. My problem comes from asci chracter of computer username. With new update of libfredo 6, libfredo 6 settings has been seen under windows menu. But plugings gives error whicg i said before msg.
                            Additionally, another computer of mine (which hasn't got asci chracter of username) which i use libfredo 6 and most of plugins. But when i install shapes pluging, it start to give load error msg:
                              Uninstalling and reinstalling sketchUp was an unneeded step.
                              As for the Shapes plugin, where did you get it?
                              • E Offline
                                eozel
                                While other plugings works well for the shapes plugin, it gives load error msg another computer of mine when sketchup is opennig.
                                  That didn't answer my question. 😒
                                  Just forget I asked about it.
                                  • E Offline
                                    eozel
                                    SketchUp Plugins | PluginStore | SketchUcation
                                    SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                    (sketchucation.com)
                                    • fredo6F Offline
                                      @eozel,
                                      At the moment, only LibFredo6 and FredoTools has been corrected for the problem of non-ascii characters.
                                      So are you sure you dont find it?
                                      • the menu is under Tools > FredoTools
                                      • there is a toolbar with a single icon showing F6
                                        (sketchucation.com)
                                        Try the version from the Extension Warehouse instead.
                                        • E Offline
                                          eozel
                                          @fredo6 said:
                                          @eozel,
                                          There is no fredotools.
                                          • fredo6F Offline
                                            @eozel,
                                            Could you show a screenshort of the "check For Updates" of LibFredo6.
                                            Also, can you check the footprint of plugins in the SU Plugins directory where you installed.
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 109
                                            • 110
                                            • 59 / 110
