    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 10.9m Views 589 Watching
    • tinanneT
      tinanne
      I'm sorry to be such a pain! I've uninstalled all the Fredo6 plugins and reinstalled using the plugin store and now I get this error.
      Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb
      Could not find included file 'C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb'
      Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb
      Error: #<SyntaxError: C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting =>
      defaults = {"dx", 8.feet, "dy", 8.feet, "nx", 4, "ny", 4}
      C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting :: or '[' or '.'
      C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting keyword_end
      C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
      C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:in register_extension' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:in module:Grid'
      C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:26:in <module:Samples>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:25:in <top (required)>'
      Executive Director : American Society of Architectural Illustrators
      AIP 30 Competition opens soon. ASAI.org
      Architectural Rendering
      • fredo6F
        At least you seem to have no problem with my scripts.
        Try to remove the su_grid plugin which seems faulty
        • tinanneT
          tinanne
          A ha! Finally! No more errors. Thank you!
          • fredo6F
            Well. Glad you fix it
            • T
              teulerguimaraes
              I use SU2014. Install automatic from SketchupUcation plugin. Help please.
              http://i59.tinypic.com/2z74y02.jpg
              • E
                eozel
                It gives me same msg, LibFredo6:Folder Libfredo6 not found in directory....
                I install it, folders (Fredo6_!LibFredo6.rb and Fredo6_!LibFredo6 directory) are seen in plugging directory.(C:\Users****\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins)
                • fredo6F
                  Might be related to the username if it includes non-ascii characters.
                  This is a known problem with SU, which I hope will be fixed.
                  • E
                    eozel
                    It is probably bucause of username, my pc's username has a character "ö". When i try this plugin on the other pc of mine, it worrked which doesnt contains no asci character. It is difficult change 😄 username directory name.
                    Thanks.
                    • fredo6F
                      @eozel,
                      Thanks for the feedback.
                      2 questions:
                      1. Are you able to run LibFredo6 alone. I mean does it load normally and do you see the menu Windows > LibFredo6 Settings
                      2. Which of my plugins do you use.
                      If it is RoundCorner or Curviloft, and keeping your username, could you try to substitute the following files instead
                      Fredo6_!LibFredo6.rbFredo6_Curviloft.rbFredo6_RoundCorner.rb
                      • fredo6F
                        NEW RELEASE: LibFredo6 v6.2a - 12 Oct 14
                        LibFredo6 6.2a is a release mainly for EdgeInspector 1.2.
                        It also fixes the issue of installation on SU14 when the username includes non-ascii characters
                        See main post of this thread for Download of LibFredo6.
                        • E
                          eozel
                          Hi, i installed libfredo 6.2a on my pc which inclued as a username "ö" chracter. Libfredo 6 settings now can be seen in window menu, but when i open skethup it gives an error msg: "you must install Libfredo 6 version 5.2 ....".
                          • fredo6F
                            @eozel,
                            I think I have also to change the top rb file for all plugins (i.e. Fredo6_xxx.rb).
                            I did it already for the new version of FredoTools (2.1a). Can you check that FredoTools does load correctly.
                            If so, then I will republish for the other plugins.
                            • B
                              Ben Ritter
                              The download link does not work for me for either one of the plugins.
                              • fredo6F
                                Which download link? I only publish via the SCF PLugin Store.
                                • B
                                  Ben Ritter
                                  OK, thanks. I just thought the yellow "Download" button in your post downloaded the .rb files on some of your other plugins.
                                  Thanks again for sharing.
                                  • E
                                    eozel
                                    As you said, i installed fredotools. It said that "selected extension has been succesfully installed...". When i open skecthup software again it doesnt give an error for "you must install Libfredo 6 version 5.2..." but fredotools doesnt seen anywhere (tools menu, etc.).
                                    Thanks four your supports.
                                    • fredo6F
                                      Do you see the menu Windows > LibFredo6 Settings after installing LibFredo6 6.2a.
                                      At least this shows that LibFredo6 is correctly installed
                                      Maybe a snapshot of your Plugin directory would also help.
                                      • E
                                        eozel
                                        I see menu Windows > LibFredo6 Settings after installing LibFredo6 6.2a. But after i install extensions like curviloft, roundcornet, it give error msg ""you must install Libfredo 6 version 5.2..". I installed fredotools too as you said me, it doesnt give an error for "you must install Libfredo 6 version 5.2..." but fredotools doesnt seen anywhere (tools menu, etc.
                                        thanks.
                                          I've seen the same sort of message in the past. The solution that worked for me was to go to the Plugins folder and delete the LibFredo6 files including the folders. Then reinstall the fresh version from the Pluginstore.
                                          Evidently, some file wasn't getting overwritten when the newer version was installed over the old.
                                          • E
                                            eozel
                                            Thanks but I try to it more than 2 times, additionally i uninstalled sketchup and delete all files related with it. My problem comes from asci chracter of computer username. With new update of libfredo 6, libfredo 6 settings has been seen under windows menu. But plugings gives error whicg i said before msg.
                                            Additionally, another computer of mine (which hasn't got asci chracter of username) which i use libfredo 6 and most of plugins. But when i install shapes pluging, it start to give load error msg:
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 113
                                            • 114
                                            • 42 / 114
