    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.1m Views 585 Watching
    • tinanneT
      tinanne
      @fredo6 said:
      @tinanne said:
      I have tried to use the Sketchucation Plugin, download, install, copy paste the latest version but I keep getting errors. Any help on what I may be doing wrong?
      Could you be more precise on the error you get.
      Thanks for the help!
      Error Loading File Fredo6_!LibFredo6.rb
      Error: #<ArgumentError: invalid byte sequence in UTF-8>
      C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:206:in block (2 levels) in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:205:in foreach'
      C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:205:in block in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:201:in each'
      C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:201:in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:121:in startup'
      C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:306:in <module:LibFredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in <top (required)>'
      Error Loading File Fredo6_JointPushPull.rb
      Error: #<NameError: uninitialized constant Fredo6::Traductor>
      C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull.rb:25:in <top (required)>'
      Error Loading File Fredo6_RoundCorner.rb
      C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_RoundCorner.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_RoundCorner.rb:25:in <top (required)>'
      Error Loading File Fredo6_ToolsOnSurface.rb
      C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:25:in <top (required)>'
      Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb
      Could not find included file 'C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb'
      Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb
      Error: #<SyntaxError: C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting =>
      defaults = {"dx", 8.feet, "dy", 8.feet, "nx", 4, "ny", 4}
      C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting :: or '[' or '.'
      C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting keyword_end
      C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
      C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:in register_extension' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:in module:Grid'
      C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:26:in <module:Samples>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:25:in <top (required)>'
      Executive Director : American Society of Architectural Illustrators
      AIP 30 Competition opens soon. ASAI.org
      Architectural Rendering
        I'll look into that Fredo but I don't see why it should get installed in a different directory either via the Pluginstore (which is pointing to ~/User/Library/.../SketchUp 2014/Plugins) or via Install Extension.
        • fredo6F
          Tinanne
          You seem to have a version of Fredo6_!LibFredo6.rb which is not correct (as it is not correctly encoded).
          Strange, because many users should have this problem too.
          • fredo6F
            NEW RELEASE: LibFredo6 v6.1b - 22 Sep 14
            LibFredo6 6.1b is a release mainly for VisuHole 1.0.
            I republish it because there seems to be a problem with the encoding of the main rb file.
            See main post of this thread for Download of LibFredo6.
            • tinanneT
              tinanne
              @fredo6 said:
              Tinanne
              So what do I do from here? I used the Sketchucation plugin to install it and then tried the other types of installs.
              Thanks again for looking into it.
              • fredo6F
                Tianne,
                I have republish a version of LibFredo6 - 6.1b - in the PluginStore.
                Can you try it.
                • tinanneT
                  tinanne
                  @fredo6 said:
                  Tianne,
                  I republish a version LibFredo6 6.1b on PluginStore. Can you try it.
                  I just installed from the plugin store and still getting this error...
                  • fredo6F
                    Tinanne,
                    You must have an old version of some of my plugins, or some plugins that have their UTF encoding changed for whatever reason.
                    Can you check
                    • tinanneT
                      tinanne
                      I'm sorry to be such a pain! I've uninstalled all the Fredo6 plugins and reinstalled using the plugin store and now I get this error.
                      • fredo6F
                        At least you seem to have no problem with my scripts.
                        Try to remove the su_grid plugin which seems faulty
                        • tinanneT
                          tinanne
                          A ha! Finally! No more errors. Thank you!
                          • fredo6F
                            Well. Glad you fix it
                            • T
                              teulerguimaraes
                              I use SU2014. Install automatic from SketchupUcation plugin. Help please.
                              http://i59.tinypic.com/2z74y02.jpg
                              • E
                                eozel
                                It gives me same msg, LibFredo6:Folder Libfredo6 not found in directory....
                                I install it, folders (Fredo6_!LibFredo6.rb and Fredo6_!LibFredo6 directory) are seen in plugging directory.(C:\Users****\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins)
                                • fredo6F
                                  Might be related to the username if it includes non-ascii characters.
                                  This is a known problem with SU, which I hope will be fixed.
                                  • E
                                    eozel
                                    It is probably bucause of username, my pc's username has a character "ö". When i try this plugin on the other pc of mine, it worrked which doesnt contains no asci character. It is difficult change 😄 username directory name.
                                    Thanks.
                                    • fredo6F
                                      @eozel,
                                      Thanks for the feedback.
                                      2 questions:
                                      1. Are you able to run LibFredo6 alone. I mean does it load normally and do you see the menu Windows > LibFredo6 Settings
                                      2. Which of my plugins do you use.
                                      If it is RoundCorner or Curviloft, and keeping your username, could you try to substitute the following files instead
                                      Fredo6_!LibFredo6.rbFredo6_Curviloft.rbFredo6_RoundCorner.rb
                                      • fredo6F
                                        NEW RELEASE: LibFredo6 v6.2a - 12 Oct 14
                                        LibFredo6 6.2a is a release mainly for EdgeInspector 1.2.
                                        It also fixes the issue of installation on SU14 when the username includes non-ascii characters
                                        • E
                                          eozel
                                          Hi, i installed libfredo 6.2a on my pc which inclued as a username "ö" chracter. Libfredo 6 settings now can be seen in window menu, but when i open skethup it gives an error msg: "you must install Libfredo 6 version 5.2 ....".
                                          • fredo6F
                                            @eozel,
                                            I think I have also to change the top rb file for all plugins (i.e. Fredo6_xxx.rb).
                                            I did it already for the new version of FredoTools (2.1a). Can you check that FredoTools does load correctly.
                                            If so, then I will republish for the other plugins.
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 112
                                            • 113
                                            • 42 / 113
