    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.1m Views 585 Watching
    • tinanneT
      tinanne
      @fredo6 said:
      Tinanne
      You seem to have a version of Fredo6_!LibFredo6.rb which is not correct (as it is not correctly encoded).
      Strange, because many users should have this problem too.
      So what do I do from here? I used the Sketchucation plugin to install it and then tried the other types of installs.
      Thanks again for looking into it.
      Executive Director : American Society of Architectural Illustrators
      AIP 30 Competition opens soon. ASAI.org
      Architectural Rendering
      • fredo6F
        Tianne,
        I have republish a version of LibFredo6 - 6.1b - in the PluginStore.
        Can you try it.
        • tinanneT
          tinanne
          @fredo6 said:
          Tianne,
          I republish a version LibFredo6 6.1b on PluginStore. Can you try it.
          I just installed from the plugin store and still getting this error...
          Error Loading File Fredo6_!LibFredo6.rb
          Error: #<ArgumentError: invalid byte sequence in UTF-8>
          C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:206:in block (2 levels) in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:205:in foreach'
          C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:205:in block in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:201:in each'
          C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:201:in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:121:in startup'
          C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:306:in <module:LibFredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in <top (required)>'
          Error Loading File Fredo6_JointPushPull.rb
          Error: #<NameError: uninitialized constant Fredo6::Traductor>
          C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull.rb:25:in <top (required)>'
          Error Loading File Fredo6_RoundCorner.rb
          C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_RoundCorner.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_RoundCorner.rb:25:in <top (required)>'
          Error Loading File Fredo6_ToolsOnSurface.rb
          C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:25:in <top (required)>'
          Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb
          Could not find included file 'C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb'
          Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb
          Error: #<SyntaxError: C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting =>
          defaults = {"dx", 8.feet, "dy", 8.feet, "nx", 4, "ny", 4}
          C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting :: or '[' or '.'
          C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting keyword_end
          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
          C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:in register_extension' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:in module:Grid'
          C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:26:in <module:Samples>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:25:in <top (required)>'
          • fredo6F
            Tinanne,
            You must have an old version of some of my plugins, or some plugins that have their UTF encoding changed for whatever reason.
            Can you check
            • tinanneT
              tinanne
              I'm sorry to be such a pain! I've uninstalled all the Fredo6 plugins and reinstalled using the plugin store and now I get this error.
              • fredo6F
                At least you seem to have no problem with my scripts.
                Try to remove the su_grid plugin which seems faulty
                • tinanneT
                  tinanne
                  A ha! Finally! No more errors. Thank you!
                  • fredo6F
                    Well. Glad you fix it
                    • T
                      teulerguimaraes
                      I use SU2014. Install automatic from SketchupUcation plugin. Help please.
                      http://i59.tinypic.com/2z74y02.jpg
                      • E
                        eozel
                        It gives me same msg, LibFredo6:Folder Libfredo6 not found in directory....
                        I install it, folders (Fredo6_!LibFredo6.rb and Fredo6_!LibFredo6 directory) are seen in plugging directory.(C:\Users****\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins)
                        • fredo6F
                          Might be related to the username if it includes non-ascii characters.
                          This is a known problem with SU, which I hope will be fixed.
                          • E
                            eozel
                            It is probably bucause of username, my pc's username has a character "ö". When i try this plugin on the other pc of mine, it worrked which doesnt contains no asci character. It is difficult change 😄 username directory name.
                            Thanks.
                            • fredo6F
                              @eozel,
                              Thanks for the feedback.
                              2 questions:
                              1. Are you able to run LibFredo6 alone. I mean does it load normally and do you see the menu Windows > LibFredo6 Settings
                              2. Which of my plugins do you use.
                              If it is RoundCorner or Curviloft, and keeping your username, could you try to substitute the following files instead
                              Fredo6_!LibFredo6.rbFredo6_Curviloft.rbFredo6_RoundCorner.rb
                              • fredo6F
                                NEW RELEASE: LibFredo6 v6.2a - 12 Oct 14
                                LibFredo6 6.2a is a release mainly for EdgeInspector 1.2.
                                It also fixes the issue of installation on SU14 when the username includes non-ascii characters
                                See main post of this thread for Download of LibFredo6.
                                • E
                                  eozel
                                  Hi, i installed libfredo 6.2a on my pc which inclued as a username "ö" chracter. Libfredo 6 settings now can be seen in window menu, but when i open skethup it gives an error msg: "you must install Libfredo 6 version 5.2 ....".
                                  • fredo6F
                                    @eozel,
                                    I think I have also to change the top rb file for all plugins (i.e. Fredo6_xxx.rb).
                                    I did it already for the new version of FredoTools (2.1a). Can you check that FredoTools does load correctly.
                                    If so, then I will republish for the other plugins.
                                    • B
                                      Ben Ritter
                                      The download link does not work for me for either one of the plugins.
                                      • fredo6F
                                        Which download link? I only publish via the SCF PLugin Store.
                                        • B
                                          Ben Ritter
                                          OK, thanks. I just thought the yellow "Download" button in your post downloaded the .rb files on some of your other plugins.
                                          Thanks again for sharing.
                                          • E
                                            eozel
                                            As you said, i installed fredotools. It said that "selected extension has been succesfully installed...". When i open skecthup software again it doesnt give an error for "you must install Libfredo 6 version 5.2..." but fredotools doesnt seen anywhere (tools menu, etc.).
                                            Thanks four your supports.
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 112
                                            • 113
                                            • 42 / 113
