    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 231.7k Views 85 Watching
    • C
      cesaro36
      Hi Piet
      Since the last UI interface I can't get my sections to update (no section name change). These are the errors shown:
      Error: #<ArgumentError: 'DarkRed' not valid values in list.>
      C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/listbox.rb:238:in value=' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSpanel.rb:583:in block in create'
      C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:82:in call' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:82:in block in trigger_event'
      C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:78:in each' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:78:in trigger_event'
      C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:358:in event_control_callback' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:312:in callback_handler'
      C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:270:in block in add_callback' -e:1:in call'
      • P
        pgarmyn
        @cesaro36 said:
        Hi Piet
        What is your SU version, what windows or mac version ?
        It seems that 'DarkRed' (Sketchup color or material) doesn't exist on your computer.
        What happens if you make a material 'DarkRed' before opening the RichSection panel?
        • P
          pgarmyn
          RichSection UPDATE 0.5.3 is published on the Sketchucation PLUGINSTORE HERE
          Release Notes for RichSection V0.5.3
          • bugs on panel removed (?)
          • to prevent issues on Mac : don't open multiple models; close and reopen the RS-panel when opening a model
          • B
            bimbachi
            hello,
            (mac version) i'm having only 2 materials default and black?
            shall i change something ?
            • P
              pgarmyn
              @bimbachi said:
              hello,
              Hy bimbachi
              To load automatically 14 predefined hatches
              • In RichSection/settings : Load materials .... :
                replace "materials/RichSection-v0.3/#default.mat.skp"
                by "materials/RichSection-v0.3/RS_V0_14.mat.skp"
              • For new models : 14 materials will be loaded at the first RS creation
              • In models with RichSections : delete the "#default" material and create a new RichSection
              • C
                caronte01
                Hi Piet,
                I've been using your latest version.
                I'm having some issues:
                The main rs dialog contracts to a size smaller than it's intended one. Text overlaps, and some buttons will dissapear. This happens a lot when creating new rs, not when editing existing ones.
                Section name has to be changed two times, when creating rs. The first time will default to #00x. The second time, the corrresponding layer will change it's name, the section has to be renamed manually. In setttings, I have rs create 1 scene, with section hidden, and camera aligned.
                I have to change layer visibility so the layer with the rs group is visible. I remember doing this for different views that used the rs (perspective sections for example), but not for the main rs scene.
                Once the scene and rs name is changed, I have to manually delete the original layer, (#00x)
                Running win 10, x64
                • B
                  bimbachi
                  ok thanks,
                  but now I have list of all hatch materials , hoever they dont show on sections when selected 😕
                  [sup:3ntsc15e][/sup:3ntsc15e]
                  @pgarmyn said:
                  @bimbachi said:
                  hello,
                  Hy bimbachi
                  • P
                    pgarmyn
                    @bimbachi said:
                    ok thanks,
                    You will have to change the names of th materials (or make a copy with another name).
                    Read the documentation (pdf in first post). Frome page 4:
                    [dir=ltr:24wchjke]If the selected option for 'RichSection section material name' is 'prefix+layername, default',
                    then the following section-materials will be asigned :
                    If a group (or componentinstance) is in layer 'Layer1' and the prefix is '#' : Then the plugin will look for the RS material '#Layer1'. If it exist in the Model (<=> in the library), it will be assigned. If not, the RS material assigned to the cut-face will be 'default' witch means that the RS material of the Component(instance) or Group containing this nested element will be used. If no corresponding RS material can be found, the default RS material will be used.[/dir:24wchjke]
                    • P
                      pgarmyn
                      @caronte01 said:
                      Hi Piet,
                      Running win 10, x64
                      Dialog to small : Webdialogs are running on internet explorer (IE version 10? on windows 8, and not win 10?)
                      I have IE 9 i think, i will test with IE10 to find a solution.
                      RS name not correct after creation: behaviour of Webdialogs is not always logic : before closing the panel, you will have to leave the inputfield by selecting another control on the same panel or by using the tabulation button.
                      RS layers are defined 'switched off in new scenes' : to use them in another scene you will have to update once the scene after creation.
                      The programmers API can't purge layers, nor styles. Thus i can't clean up.
                      • C
                        cesaro36
                        Sorry the lack of feedback PiGa.
                        I'm having issues with version 0.5.3
                        Can't change the properties of the default created richsection.
                        Error: #<NoMethodError: undefined method attribute_dictionary' for nil:NilClass> c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:2330:in optionsRShRetrieve'
                        c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:2083:in updateRichSection1' c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:3593:in changeOptionsRSh'
                        C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSpanel.rb:381:in block in create' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:82:in call'
                        C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:82:in block in trigger_event' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:78:in each'
                        C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:78:in trigger_event' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:364:in event_control_callback'
                        C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:318:in callback_handler' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:276:in block in add_callback'
                        -e:1:in `call'
                        SKUPro2014
                        Win8
                        regards
                        Before trying to update richsection name and options
                        After
                        • P
                          pgarmyn
                          @cesaro36
                          Strange, I have also Win 8 and SU2014, without that problem.
                          Did you try to change the settings before creating the section?
                          Are you updating a RichSection created with an older plugin version?
                          What parameter did you modifiy?
                          Did you changed options in the menu plugings/RichSection/settings ?
                          If so, can you reset the settings for user and model and try again?
                          • P
                            pgarmyn
                            @Santiago(caronte01) @cesaro36 @bimbachi and all the others : thanks for testing ! ❗
                            ➡ RichSection has been updated : Release Notes for RichSection V0.5.4
                            bugfix : renaming RS after creation
                            bugfix : changing properties of RS
                            bugfix : other ...
                            disabled (not working on this moment) : creating RS from existing section
                            also tested on Mac : known bug on Mac: RSpanel not working when opening other model, opening 2nd model : Workaround : close panel before (or after) opening new file
                            @ Santiago
                            About modal and non modal RS-panel : To avoid the problem of the main window losing focus, the next version of my plugin will open the RS-panel after having placed the sectionplane.
                            • P
                              pgarmyn
                              [url][/url]also TESTED and working on Sketchup 2015 & Windows 8
                              • KrisidiousK
                                Krisidious
                                I tested it too... Working and working very quickly.
                                By: Kristoff Rand
                                • C
                                  caronte01
                                  Hi Piet,
                                  Quick test of the latest version updating some plans done a while ago. This latest version seems to update noticeably faster, and the small info dialog does not collapse onto itself as before. I´ll try and do a more in depth test later.
                                  Santiago
                                  • P
                                    pgarmyn
                                    @Krisidious and @Caronte01
                                    thanks for testing,
                                    still working on it
                                    • L
                                      ltchest
                                      Is it possible to create b&w architectural drawings with this sectioning tool ? The idea would be that you can have a textured model, but when it goes into layout, you get purely black & white drawings with the customised section fill patterns. That would be great.
                                      Sketchup 21.2.332 (windows 10.0.19043 Build 19043)
                                      RTX2070 + GTX1080, Driver 472.12
                                      • P
                                        pgarmyn
                                        For the sectioned part, you can apply B&W fill patterns. It's possible to have different sets of section materials applied in the same model by using different prefixes :
                                        With prefix # in RichSection parameters : section material #layername1 will be applied to groups and components in layer layername1, material #layername2 to groups and components in layer layername2 (with option : by layer, default)
                                        With prefix #1 in RIchSection parameters : materials #1layername1 #1layername2 etc.... will be applied (option : by layer, default)
                                        • L
                                          ltchest
                                          OK - I am not yet a user of RichSection (I fell in with the other offering out there - and am having problems with it). From what I can gather, it sounds like if my model is all textured with materials (because I am also using the same model to produce realistic renderings) then the section drawings are going to be rendered with those textures & colours - except you have control only over the fill patterns that are applied where the section cuts any objects - so they are not going to be black & white architectural drawings. You would have to remove all those textures / colours from the model ?
                                          • P
                                            pgarmyn
                                            Fill patterns are in fact native Sketchup textures. There is no way to threat them separately: Switch of textures in the style setting will also switch off the fill pattern. All plugins creating fill patterns will have the same behavior.
                                            A B&W option is missing in LO.
                                            A workaround is to export bitmaps from SU and convert them to B&W
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 15 / 20
