    [Plugin] (TIG) Rotate Plan View v1.1 20110316
    54 Posts 17 Posters 51.5k Views 17 Watching
      I would agree. The plugin is not installed correctly. The folder and the rb file should be in the Plugins directory instead. Makes me wonder how you went about installing the plugin and why you did it that way.
      • the_slothT
        the_sloth
        Thank you. That was helpful. The reason I kept Rotate Plan View in its folder is that there are other ruby scripts that seem to operate fine from within folders (see image below). Anyway, thanks again for the response.
        correct install location
          How are you going about installing plugins?
          • pbacotP
            It looks to me that these files should not be in a folder, but be in the "Plugins" folder itself.
            Edit: woops TIGtools is not file but folder, so I mean that folder should be in the Plugins folder. Sorry.
            • the_slothT
              the_sloth
              Typically I just drag the files into my plugins folder.
              • BoxB
                You might find the pluginstore useful. And it would be nice if your profile version matched your problem version. SU2014 in your profile but SU8 in the question.
                  Ah, I see. It's no wonder, then. You should be using Install Extension, and the SCF plugin store.
                  • the_slothT
                    the_sloth
                    You bring up a good point. In profile you can only choose one version. I use SU 8 at work (network license), 2013 at home (personal license), and occasionally SU2014 Make when there are no licenses at work. I would bet there are others who use multiple version of SketchUp as well.
                    I will read this later today: http://sketchucation.com/resources/tutorials/108-installing-sketchup-plugins
                    Thanks for the help.
                    • BoxB
                      I was referring to this
                      http://sketchucation.com/resources/plugin-store-download
                      • the_slothT
                        the_sloth
                        This is very cool. Thanks for sharing. I haven't used SU for some time in a serious fashion and am excited to be getting back into it
                          jimmylomax
                          This is great! Many thanks. Is there a known way to achieve this from another perspective (e.g. I'd like to make an ISO image)?
                            Look up my iso axo script...
                            https://sketchucation.com/pluginstore?pln=axo_iso
                              db11
                              A very useful little plugin.
                              @TIG: Is it possible to provide the same capability for the other ortho views? I'd like to be able to rotate front and side views in the same way.
                              I searched for another extension that could do it, but didn't locate one.
                                It's a very very old, but [perhaps overly] simple script.
                                If you read the code it resets the Plan-view camera's 'UP' to be the Z_AXIS [Top view], and then transforms it around that axis by the specified angle.
                                To make a version to say look 'Front' along the green axis you'd use the Y_AXIS and so on...
                                Just try copying the RB file ../Plugins/Rotatefrontview.rb***, editing it and substituting the Y_AXIS for the Z_AXIS [in two places]...
                                Use a plain-text editor like Notepad++ on PC or TextWrangler on MAC.
                                ***Name these new RB files logically e.g. Rotateplanview.rb==> Rotatefrontview.rb and also remember to change the other parts of the code to match - e.g. ' Class' name and associated lines of code setting up the cmd to suit, each time replacing [Pp]lan with [Ff]ront etc.
                                Change the Toolbar [copied] PNG names too...
                                BUT don't worry about the Toolbar code otherwise, because it only kicks in when there PNG images for the buttons exist.
                                Unless you recreate the PNG files inside the ../Plugins/TIGtools subfolder there will be no matching Toolbar buttons made - but the View menu items will always get created...
                                To make all 5 other possible ortho views, just substitute the Z_AXIS [Top] for X_AXIS [Right], Y_AXIS [Front], and their .reverse equivalents [Left & Back] + Z_AXIS.reverse [Bottom]...
                                  db11
                                  Thanks TIG for taking the time to describe the proper approach. Sounds fairly straightforward, so I'll give it a try this weekend.
                                    db11
                                    I made the modifications and produced 'Rotate____view' for the various views. Saved me a lot of trouble of rotating viewports in LayOut for a bunch of parts on a material list. So thanks for the directions β€” it was even simpler than I thought.
                                    But it did make me think: wouldn't it be possible to make a single plugin "RotateCurrentView"?
                                    If there a way to auto-poll for the current view, then wouldn't it be relatively simple to use a CASE statement to assign the correct axes relative to the current view?
                                    The produced versions do the trick fine, but it would be cool to consolidate multiple plugins (and their corresponding menu items) into a single one.
                                      db11
                                      ...I should add that it would be fun to try to make those modifications myself (assuming the approach is valid).
                                      A fair while back I had started teaching myself Ruby and made a couple of super simple plugins for my own use. Then I got busy with paid work and dropped the effort. I've probably forgotten much of what I had learned, but I have been meaning to get back to it β€” and this might be a fun re-entry (especially since most of the work is already done).
                                      • 3 / 3
