    [Plugin] (TIG) Rotate Plan View v1.1 20110316
    54 Posts 17 Posters 50.2k Views 17 Watching
      seasdes
      This post may have a workaround unless others know of a better way
      http://sketchucation.com/forums/viewtopic.php?f=15&t=50685&p=457482&hilit=scene#p457496
      Using Sketchup Pro 2019
        Make a Scene-tab to remember the plan-view camera as you have just made it... then after you zoom/pan/orbit and have mess it up, you simply click on the Scene-tab and that view is restored...
          @seasdes said:
          If you click on the middle mouse button and drag (identically) the view will change. I would like to stop that from happening.
          Thanks Dave
          "identically" I don't think that word means what you think it means.
          As I said and now TIG has said, create a scene after setting the view. Then when you've changed the view by clicking on the middle mouse button and dragging (orbiting) you can return to it.
          Or if you don't want the view to change, don't press the middle mouse button and drag.
            seasdes
            Sorry Dave I meant 'accidentally'. I have corrected the typo. Another senior moment.
              seasdes
              This is a wonderful tool. I was made aware of it by Dave.
              Is there a way to lock the scene so that it cannot be accidentally dragged away from its intended orientation?
              • the_slothT Offline
                the_sloth
                For some reason, I am having a hard time installing this script.
                When I run from Ruby Console I get the following message:
                Rotateplanview.rb
                Error: #<NoMethodError: undefined method `rb' for Rotateplanview:Class>
                (eval)
                I also do not see the Toolbar under View > Toolbars > ___. I believe I have it installed correctly.
                install location screenshot
                There are many other scripts in my plugin folder that are working properly. I have restarted SU8 several times. I am sure I am missing something simple.
                Thanks in advance.
                  I would agree. The plugin is not installed correctly. The folder and the rb file should be in the Plugins directory instead. Makes me wonder how you went about installing the plugin and why you did it that way.
                    the_sloth
                    Thank you. That was helpful. The reason I kept Rotate Plan View in its folder is that there are other ruby scripts that seem to operate fine from within folders (see image below). Anyway, thanks again for the response.
                    correct install location
                      How are you going about installing plugins?
                      • pbacotP Offline
                        It looks to me that these files should not be in a folder, but be in the "Plugins" folder itself.
                        Edit: woops TIGtools is not file but folder, so I mean that folder should be in the Plugins folder. Sorry.
                          the_sloth
                          Typically I just drag the files into my plugins folder.
                          • BoxB Offline
                            You might find the pluginstore useful. And it would be nice if your profile version matched your problem version. SU2014 in your profile but SU8 in the question.
                              Ah, I see. It's no wonder, then. You should be using Install Extension, and the SCF plugin store.
                                the_sloth
                                You bring up a good point. In profile you can only choose one version. I use SU 8 at work (network license), 2013 at home (personal license), and occasionally SU2014 Make when there are no licenses at work. I would bet there are others who use multiple version of SketchUp as well.
                                I will read this later today: http://sketchucation.com/resources/tutorials/108-installing-sketchup-plugins
                                Thanks for the help.
                                • BoxB Offline
                                  I was referring to this
                                  http://sketchucation.com/resources/plugin-store-download
                                    the_sloth
                                    This is very cool. Thanks for sharing. I haven't used SU for some time in a serious fashion and am excited to be getting back into it
                                      jimmylomax
                                      This is great! Many thanks. Is there a known way to achieve this from another perspective (e.g. I'd like to make an ISO image)?
                                        Look up my iso axo script...
                                        https://sketchucation.com/pluginstore?pln=axo_iso
                                          db11
                                          A very useful little plugin.
                                          @TIG: Is it possible to provide the same capability for the other ortho views? I'd like to be able to rotate front and side views in the same way.
                                          I searched for another extension that could do it, but didn't locate one.
                                            It's a very very old, but [perhaps overly] simple script.
                                            If you read the code it resets the Plan-view camera's 'UP' to be the Z_AXIS [Top view], and then transforms it around that axis by the specified angle.
                                            To make a version to say look 'Front' along the green axis you'd use the Y_AXIS and so on...
                                            Just try copying the RB file ../Plugins/Rotatefrontview.rb***, editing it and substituting the Y_AXIS for the Z_AXIS [in two places]...
                                            Use a plain-text editor like Notepad++ on PC or TextWrangler on MAC.
                                            ***Name these new RB files logically e.g. Rotateplanview.rb==> Rotatefrontview.rb and also remember to change the other parts of the code to match - e.g. ' Class' name and associated lines of code setting up the cmd to suit, each time replacing [Pp]lan with [Ff]ront etc.
                                            Change the Toolbar [copied] PNG names too...
                                            BUT don't worry about the Toolbar code otherwise, because it only kicks in when there PNG images for the buttons exist.
                                            Unless you recreate the PNG files inside the ../Plugins/TIGtools subfolder there will be no matching Toolbar buttons made - but the View menu items will always get created...
                                            To make all 5 other possible ortho views, just substitute the Z_AXIS [Top] for X_AXIS [Right], Y_AXIS [Front], and their .reverse equivalents [Left & Back] + Z_AXIS.reverse [Bottom]...
                                            • 3 / 3
